Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > Fit Trix > Fit DIY: Repair & Maintenance
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #121 (permalink)
Old 07-25-2008, 01:22 AM
Sugarphreak's Avatar
Sugarphreak relies on Rep Points to liveSugarphreak relies on Rep Points to liveSugarphreak relies on Rep Points to liveSugarphreak relies on Rep Points to liveSugarphreak relies on Rep Points to liveSugarphreak relies on Rep Points to liveSugarphreak relies on Rep Points to liveSugarphreak relies on Rep Points to liveSugarphreak relies on Rep Points to liveSugarphreak relies on Rep Points to liveSugarphreak relies on Rep Points to live
Mine were easy to install, although being that everything was in Japanese I unfortunately smelled the pack of mystery cleaner while trying to figure out what it was.... it knocked me on my ass like I had been hit with a hammer
So... here is my free tip
1) Do not smell or breath the little packet of adhesive cleaner/prep or whatever it is.
__________________
For a jolt of pure awesome... just click the sugarphreak button!
  #122 (permalink)
Old 12-26-2008, 02:14 PM
trancedsailor's Avatar
trancedsailor relies on Rep Points to livetrancedsailor relies on Rep Points to livetrancedsailor relies on Rep Points to livetrancedsailor relies on Rep Points to livetrancedsailor relies on Rep Points to livetrancedsailor relies on Rep Points to livetrancedsailor relies on Rep Points to livetrancedsailor relies on Rep Points to livetrancedsailor relies on Rep Points to livetrancedsailor relies on Rep Points to livetrancedsailor relies on Rep Points to live
Send a message via AIM to trancedsailor
Anyone have a guide on uninstalling and re-positioning? I put them on wrong originally, they aren't high enough on the door and the right side isn't even ;/
__________________
For Sale:: Progress swaybar, Weapon R trunk cage, right FX35 retrofit headlight. PM with offer if interested
1994 EG2 B16A3 acquired 9/3/09
  #123 (permalink)
Old 09-21-2009, 03:44 PM
methodr's Avatar
methodr relies on Rep Points to livemethodr relies on Rep Points to livemethodr relies on Rep Points to livemethodr relies on Rep Points to livemethodr relies on Rep Points to livemethodr relies on Rep Points to livemethodr relies on Rep Points to livemethodr relies on Rep Points to livemethodr relies on Rep Points to livemethodr relies on Rep Points to livemethodr relies on Rep Points to live
just installed a set on my ge. i would do one side at a time, that way you can line them up and adjust as needed. note: this is for genuine Mugen Ventilated Visors (not Mugen "style").
-first, install the brackets (or buraketto, LOL) in the appropriate areas with the flush side facing the visor.
-then, prep each individual piece of double stick tape with a 2 in. piece of masking tape (to aid in removal of plastic lining).
-roll down the corresponding window and pull down the rubber lining that seats the window until only the top two corners are seated.
-next, prep the area with isopropyl alcohol and 3M PAC Primer and position the visor with brackets clipping onto the inside of the door (so it's positioned under the rubber lining).
-now push lining back into gaps starting from the corners and making your way in.
-roll up the windows and position the visor so it's 2 mm. from the top and 3 mm. from the side where the doors meet.
-follow the above process for all windows.
-pull the masking tape and remove the plastic lining for the double stick tape.
-finally, press firmly along the edges of the visor to create a strong adhesion.
your end product should come out like this...
note: this process is not verbatim from the installation guide. i followed the measurement and improvised a few steps with help from this forum. i hope that this procedure aids in any future installations. hopefully it will persuade some 50/50 buyers to go with the genuine stuff. not only is it mugen and made in japan, but it's functional as well. i got mine from www.jhpusa.com and it took about 30 min. to install by myself. thanks for reading!
__________________
Aloha. Mahalo Gozaimasu.
Reply
Tags
fit, guards, honda, install, instructions, mugen, rain, vents, visor, visors, window
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
