I need some torque specs please
Thanks
That was exactly what I needed. Specifically for the brake caliper torque specs listed here
Front Brake Caliper Overhaul
I thank you and the people of the future thank you.
Wouldn't it just be easier to post the actual torque value on the front brake calipers when you are replacing the pads.
And fwiw, none of the links posted in this thread actually show a number.......lololol........z
And I find it hard to believe that little 12mm bolt requires 80 ft lbs.
I know this is a late reply but I was looking into the matter myself. If you click the link there's a small icon bottom left that opens up the diagram showing the parts and torques needed.
So it is
12-22-2018 11:34 PM
MauriceS
09-15-2018 10:49 PM
