Doing your own work on spark plugs?? You NEED this!
For anyone doing R&R work with Fit spark plugs, throw away your old-fashioned spark plug socket. The one with the greasy, slippery, o-ring that is supposed to hold the loose plug inside the socket. Even brand-new sockets like this can lose their hold on a brand new plug and let it drop onto the ground. This causes the ceramic insulator to crack, the plug will leak electricity into the head, and the plug is no good anymore.
Another member just discovered that in his last plug change, the socket o-ring came out of the socket and stayed around the base of the plug until it melted. He can't get the socket back onto the hex head of the plug to remove all of the garbage because of the melted o-ring.
Soooooo- don't risk any of the above. Buy one of these instead, and throw your o-ring spark plug socket away!
Amazon.com: Kastar 528 3/8" Drive Magnetic Spark Plug Socket 5/8": Automotive
Here is the member who did NOT have a magnetic plug socket!--
https://www.fitfreak.net/forums/1st-...et-melted.html
Just solved this problem with 3-4 tiny cylindrical magnets found elsewhere (removed from a gunstig Ikea item).
I just let them stick them on an allen wrench and used it to "fish" the plugs (of course once unscrewed with a standard 16mm socket from which I removed the useless o-ring)
SilverEX15
21
08-02-2020 11:19 PM
justanewbie
02-01-2020 05:12 PM
Deer
10-05-2017 07:28 PM
Bryanfit
19
03-17-2017 02:03 PM
