with AC on, stopped, engine misses
New problem this summer. 2008 Sport Auto, 148K, A/C on, when I come to a stop, engine runs rough. Check engine light came on, codes showed power loss and misfires on each cylinder.
If I turn off AC, or shift into neutral and rev it up a bit, it's okay.
What should I check?
Thanks.
Thanks.
List of causes:
Worn spark plugs and or ignition coils
valves are too tight (loss of compression & torque)
A/c line is restricted
ECU did not see that A/c is on and did not command to throttle body motor to increase engine RPMs
Honestly, I would probably change all the coilpacks, seems to be the most common reason for misfiring. Get all 4 for about 250$ from RockAuto Parts Catalog . Get the Hitachi ones. If you've never changed your spark plugs, I would go ahead and do that too.
While you've removed the coils and plugs, you could go a step further and remove the valve cover and check the valve clearance like the above poster mentioned. Some valves could be out of spec. New plugs and coils and a valve adjustment and I bet it'll run like new!
Perhaps try cleaning your condensor also? Check ErictheCarGuy's tutorial on cleaning the AC condensor. Apparently, a dirty condensor can lead to increased pressure inside the condensor and poor AC performance. Linky:
Thanks for the replies.
All 4 for under $65?
Would you buy them from ebay?? The local auto parts store wanted $65 each - $85 each for Hitachi.
New 4 Pack 07 08 Honda Fit 1 5L L4 Ignition Coil on Plug Coils Pack 30520PWC003 | eBay
I have this problem every now and them, I solve it by spraying throttle body cleaner in the throttle body. I guessing its the cheap gas I use... And the idle air valve that is getting gummed up. idk, but it does solve my problem!
I just fixed this exact same problem with 4 new Beck Arnley coil packs from Amazon for $46 apiece. I read through a bunch of threads on here regarding this issue and the Beck Arnley seem universally acceptable as OEM replacements but for half the cost.
RainierV
11-03-2018 06:54 AM
danielomar91
01-24-2014 11:29 AM
greenmonster2420
10-22-2012 06:00 PM
