Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > Fit Trix > Fit DIY: Repair & Maintenance
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #61 (permalink)
Old 09-16-2006, 02:00 AM
koolkevin1107's Avatar
koolkevin1107 relies on Rep Points to livekoolkevin1107 relies on Rep Points to livekoolkevin1107 relies on Rep Points to livekoolkevin1107 relies on Rep Points to livekoolkevin1107 relies on Rep Points to livekoolkevin1107 relies on Rep Points to livekoolkevin1107 relies on Rep Points to livekoolkevin1107 relies on Rep Points to livekoolkevin1107 relies on Rep Points to livekoolkevin1107 relies on Rep Points to livekoolkevin1107 relies on Rep Points to live
Send a message via AIM to koolkevin1107
i still don't get what this thing does. I tried my defrosters today and the AC didn't turn on with either modes. First i tried it with the front defroster only and the rear defroster only and both of them running at the same time. Maybe the canadian model does this?
__________________
AIM: koolkev1107
  #62 (permalink)
Old 09-16-2006, 02:41 AM
kkim's Avatar
kkim relies on Rep Points to livekkim relies on Rep Points to livekkim relies on Rep Points to livekkim relies on Rep Points to livekkim relies on Rep Points to livekkim relies on Rep Points to livekkim relies on Rep Points to livekkim relies on Rep Points to livekkim relies on Rep Points to livekkim relies on Rep Points to livekkim relies on Rep Points to live
On my car, I could not get the a/c to turn off in the 2 windshield positions on the rotary switch even if the a/c button was deselected. Mine is a US model.
__________________
2009 Tafetta White FIT Sport MT ~ 15" Konig Megarace (White), 195/55 Dunlop Direzza Sport Z1 Star Spec
2008 Kawasaki Ninja 250R Lime Green
  #63 (permalink)
Old 09-16-2006, 03:01 AM
Frequent FitFreak Poster
Packy is on a distinguished road
It's not your electric wire defrosters they're talking about, it's the windshield vent mode on your fan vent selector. If you have windshield or windshield/foot vents selected, the AC is turned on even though the AC light isn't on.
__________________
SSM Sport AT
  #64 (permalink)
Old 09-16-2006, 09:37 AM
iismileyll is on a distinguished road
you have to be moving forward for the AC to work... sitting in the car idling won't run the compressor hard enough.... well in my opion.
__________________
2007 Honda Fit AT Sport
  #65 (permalink)
Old 09-16-2006, 12:51 PM
vandeetz is on a distinguished road
I bought my fit about 3 weeks ago and the AC has never popped on when i went to defrost. I can still turn it on manually. Whats the deal did they forget to plug in the wire?
I thought it was weird since my RSX always turns the AC on in defrost mode
  #66 (permalink)
Old 09-16-2006, 01:26 PM
it does turn on... the AC light just doesn't go on in defrost mode. Well, unless you push the AC button...
__________________
  #67 (permalink)
Old 09-16-2006, 09:43 PM
FITforKRUG is on a distinguished road
FYI, Most A/C systems will not run with outside temps below about 40 deg. F. There is a low pressure switch in the system that will open to prevent the compressor running. It is possible to go all winter without the compressor running if the temps stay cold even in the defrost mode. So you may think you are running the A/C to lube the seals but you are not if it's cold out.
When its cold out the air can not hold much moisture so the air is very dry when the HVAC system heats up the air to defrost the windows, the a/c is then not needed to dry the air.
  #68 (permalink)
Old 09-16-2006, 11:07 PM
JonasM has a spectacular aura aboutJonasM has a spectacular aura about
I'm not sure that's right (maybe new cars, but not my past Hondas). I've frequently used the A/C in the winter to defrost the inside of the windshield - it goes way faster with the A/C on than just with warm air.
I've always liked the fact that Honda's A/C is not tied to temps - you can use it to dehumidify the air even in cold weather.
JonasM
  #69 (permalink)
Old 09-17-2006, 04:04 AM
Quote:
then why does the ligh turn on in other hondas and my acura?
  #70 (permalink)
Old 09-17-2006, 04:21 AM
kkim's Avatar
Quote:
That's the problem here... the a/c in the FIT was on in the defrost modes even if you had the a/c deselected.... you could never have it off in those modes... now you can!
__________________
  #71 (permalink)
Old 09-17-2006, 01:56 PM
Keep in mind all this information is in the manual. We're not making up the fact that the AC is on in the defrost modes
__________________
SSM Sport AT
  #72 (permalink)
Old 09-17-2006, 03:22 PM
htewam is on a distinguished road
b17gsr -- Thanks once again for the info. Used your photos and instructions (along with a heavy dose of info from the College Hills guidance on removing the center panel lower cover). I found the info from College Hills, while accurate, is a bit too brief for the first-time DIYer in regards to one or two steps but I didn't manage to break or scratch anything so can't complain too much. By the way... in answer to someone else's post -- I couldn't find ANY way to reach this connector without removing the center panel lower cover -- but its not all that hard.
I used a bit of duct tape to secure the (now disconnected) connector so that it wouldn't rattle around. What's nice about this mod is that it was quick (took me about 30 minutes -- mostly because I took it slow and easy removing the dash parts) AND because it is easily reversed if I don't like the results.
So... two mods down (raising the rear view mirror and now disabling automatic AC on defrost). Now if only the Daytime Running Lights and interval rear wiper would be so easy!
  #73 (permalink)
Old 09-17-2006, 10:23 PM
Spule 4's Avatar
Spule 4 is on a distinguished road
THANKS! If it were not dark out, I would tear into mine tonite.
__________________
Garrett
"Paradise, is exactly like, where you are right now, only much, much, better!"
-Laurie Anderson
  #74 (permalink)
Old 10-20-2006, 11:00 PM
kkim's Avatar
Quote:
Originally Posted by htewam
So... two mods down (raising the rear view mirror and...
Link to the rear view mirror mod?
nm... found it. Rear View Mirror -- alternatives
__________________
  #75 (permalink)
Old 10-20-2006, 11:28 PM
tricolor relies on Rep Points to livetricolor relies on Rep Points to livetricolor relies on Rep Points to livetricolor relies on Rep Points to livetricolor relies on Rep Points to livetricolor relies on Rep Points to livetricolor relies on Rep Points to livetricolor relies on Rep Points to livetricolor relies on Rep Points to livetricolor relies on Rep Points to livetricolor relies on Rep Points to live
I too wanted to remove the Auto AC feature. AC probably sucks away 5 or more Lb-Ft out of the 76 available at the wheels, specialy at low rpm. It is a real annoyance when you seach for power in slow traffic, trying to accelarate into a faster lane.
BTY, my MPV has a feature that temporarely disables the AC during hard accelaration. Would there be such a feature in our AT Fit as well?
  #76 (permalink)
Old 10-21-2006, 12:40 AM
^ Actually, it's not an Auto AC feature, it's just that the Fit turns AC on if you're on the windshield or windshield/foot vent mode. This is because it helps defrosting by removing moisture from the air. So as long as you don't have those vent modes selected and don't have the AC turned on you won't be using the AC
__________________
SSM Sport AT
  #77 (permalink)
Old 10-21-2006, 12:05 PM
Spule 4's Avatar
The wiring of the switch, see the first photo, it is a second switch, bypassing the first one.
__________________
Garrett
-Laurie Anderson
  #78 (permalink)
Old 10-22-2006, 01:01 AM
2hot6ft2's Avatar
2hot6ft2 is a jewel in the rough2hot6ft2 is a jewel in the rough2hot6ft2 is a jewel in the rough2hot6ft2 is a jewel in the rough
Disconnected mine today. Once the lower climate control cover is removed the plug can be easily unpluged.
__________________
07 FIT Taffeta White, 5sp M/T Sport
  #79 (permalink)
Old 11-17-2006, 07:38 PM
eGadgetGeek is on a distinguished road
Disconnected mine last night while doing the interior light mod by koolkevin1107(http://www.fitfreak.net/forums/showp...&postcount=11). Hardest part was getting the cover off without slicing up my hands.
  #80 (permalink)
Old 11-22-2006, 01:08 AM
tershel is on a distinguished road
A/C DEFROST Mode questions,answers, solutions
hey guys i read it somewhere that the a/c runs when you turn on the rear defrost......is that correct?
....if so, how can i fix it so that the a/c doesnt come on when i use my rear defroster.
thanks guys
Reply
Tags
2009, ac, air, cars, civic, cold, conditioning, defrost, disable, fit, honda, improve, lx, mode, popsicetrix, works
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
