Overwhelming gas smell
My '08 Fit with 191,000 miles has developed an overwhelming odor of gasoline in the cabin.
I cannot see any noticeable fuel leaks on the engine. I will dig deeper tomorrow by following fuel tank to intake.
Any others with a similar issue who can give me any tips?
Thanks.
Thanks.
My Honda Fit GE has ~120,000. There is gasoline odor in the cabin and the check engine light is lite. I have the following DTC: P0455, P0456 and P0171. P0455 and P0456 indicate leaks in the EVAP system. Parts are coming in from Bernardi and hopefully my problem should be fixed with the new parts. P0171 is system too lean and might be related to the EVAP leak.
17011-SLN-000 - Canister
36162-RB0-005 – Purge control solenoid valve
17312-SLN-A0l – Canister vent valve
runbikerun
25
04-15-2017 08:37 AM
