Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > Fit Trix > Fit Engine Modifications, Motor Swaps, ECU Tuning
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #1 (permalink)
Old 02-28-2008, 04:41 PM
AppleMac*Fit's Avatar
Senior Member
AppleMac*Fit is on a distinguished road
VTEC Switch Possible?
Is it possible to switch on/off VTEC?
I've seen lots of posts inquiring about this topic mingled in with other posts... But has anyone tried it? I would like to be able to switch VTEC off when I am cruising on the highway - and when I hypermile (which is everytime I commute). Then I could switch it back on when I feel like driving more 'spiritedly'.
__________________
NHBP Fit
Mods:Tint (27% sides, 20% rear)... max legal in SC Louder horn, Self-install aux jack, Undercoating, jerry-rigged sound proofing, Rubber floor mats, ScanGauge-II, Lightened gas-foot.
2007 Honda Fit, 1998 Honda Civic EX
Sponsored Links
  #2 (permalink)
Old 02-28-2008, 04:57 PM
eldaino's Avatar
eldaino relies on Rep Points to liveeldaino relies on Rep Points to liveeldaino relies on Rep Points to liveeldaino relies on Rep Points to liveeldaino relies on Rep Points to liveeldaino relies on Rep Points to liveeldaino relies on Rep Points to liveeldaino relies on Rep Points to liveeldaino relies on Rep Points to liveeldaino relies on Rep Points to liveeldaino relies on Rep Points to live
since the fit has 'old school' vtec which only actuates at a certain rpm, (i think the fits' is around the low 5k's) you shouldn't have to worry about it decreasing fuel economy unless you are constantly flooring it. (which would be counter-economical anyway, VTEC or not.)
  #3 (permalink)
Old 02-28-2008, 05:05 PM
CptanPanic is on a distinguished road
Actually with low acceleration vtec kicks on at 3400. But will activate anytime you accelerate real hard.
__________________
  #4 (permalink)
Old 02-28-2008, 06:01 PM
handsdown's Avatar
handsdown is an unknown quantity at this point
vtec is a system for the engine's breathing, it's not as much on/off as it is high/low.
with the sohc L15a, you're either on the gas-sipping cam profile(that keeps one of the four valves closed) or the higher flowing cam profile(that uses all 16). basically, keeping the rpm low and the acceleration down will keep you on the gas-sipping cam profile anyway, so the way to turn vtec "off" is to drive more conservatively/economically. think of the gas pedal as the vtec switch, and don't rev high if you want to save gas. it's pretty much a passive system, it makes things work better (more efficiently), not differently.
if you were to actually turn it "off" so it used the (12 valve cam setting) all the time, you'd have reduced fuel efficiency in high flow situations because the engine would starve itself. vtec on the L15a is economical no matter if it's on or off.
*Edited for correctness, thanks jits*
  #5 (permalink)
Old 02-28-2008, 08:00 PM
jits14's Avatar
jits14 has a spectacular aura aboutjits14 has a spectacular aura about
with a sohc engine, like the l15a thats in the fit, there is only one cam hence the single overhead cam(sohc) title. The "vtec" in the fit offers a 12 valve to 16 valve operation which really is more for fuel economy and performance and is different then a dohc b series or k series engine.
The four extra valves on the l15a open up as the "vtec" kicks in to allow more air into the chamber on each piston. I was wondering if someone has designed some type of modification to open the four extra valves to run all the time so it would run 16 valves.
There is some excellent info in this article that describes the details of the l15a and l13a dsi engines.
The Truly Amazing Honda Fit/Jazz
__________________
_________________________________________________
  #6 (permalink)
Old 03-02-2008, 02:17 PM
nttdemented relies on Rep Points to liventtdemented relies on Rep Points to liventtdemented relies on Rep Points to liventtdemented relies on Rep Points to liventtdemented relies on Rep Points to liventtdemented relies on Rep Points to liventtdemented relies on Rep Points to liventtdemented relies on Rep Points to liventtdemented relies on Rep Points to liventtdemented relies on Rep Points to liventtdemented relies on Rep Points to live
I have an Apex Neo installed and with the sensor check on the VTEC engages anywhere past 2.5k rpm if you go past 15% throttle.
I tried using the VTEC controll of the Neo to see how I could affect VTEC engagement and after flooring it through two gears the check engine would turn on and I'd have to disconnect the battery to reset the ECU. After that little experiment I chose to leave VTEC control OFF on my Neo.
  #7 (permalink)
Old 03-02-2008, 08:13 PM
Senior Member
nttdemented - thanks for the information. So I guess it's not possible.
__________________
NHBP Fit
  #8 (permalink)
Old 03-07-2008, 05:19 PM
AJ PwR Jr.'s Avatar
Premium Honda FIT Vendor
AJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to liveAJ PwR Jr. relies on Rep Points to live
Send a message via AIM to AJ PwR Jr.
The VTEC engages at 3200rpm on the USDm fit , we have tried Apexi Neo, Greddy Emanage and we are not able to lower the VTEC. I guess on K-Pro can do the work.
__________________
A&J Racing International
#155-1991 Savage Rd
Richmond B.C. V6V 0A4
TEL: (604)279-0329
Email: info@aj-racing.com
URL: www.aj-racing.com
Your JDM parts and Honda Tuning Specialist
  #9 (permalink)
Old 03-07-2008, 09:42 PM
bigg_kidd's Avatar
bigg_kidd relies on Rep Points to livebigg_kidd relies on Rep Points to livebigg_kidd relies on Rep Points to livebigg_kidd relies on Rep Points to livebigg_kidd relies on Rep Points to livebigg_kidd relies on Rep Points to livebigg_kidd relies on Rep Points to livebigg_kidd relies on Rep Points to livebigg_kidd relies on Rep Points to livebigg_kidd relies on Rep Points to livebigg_kidd relies on Rep Points to live
dang, once aj's guys come in, everything is explained...well at least to the question i have in mind...gosh i need to visit aj more often, but damm it's a long drive...lol for the USDM FIT, i always felt the vtec engages at 4k rpm, i guess i felt it wrong, i do need k-pro
Reply
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
should i trade in my 2006 jazz vtec for the honda civic vtec 2005 model? tony2006 Other Car Related Discussions 16 11-20-2008 12:15 AM
MIVEC vs. VTEC vs. VVT etc tonyd3773 Other Car Related Discussions 21 02-10-2008 12:22 PM
The difference between VTEC systems Fit of RAGE General Fit Talk 4 03-01-2007 10:03 AM
difference between the jazz vtec in australia and the jazz vtec in south africa? tony2006 Other Car Related Discussions 1 08-27-2006 01:47 AM
Go
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
