short shifters question and answers
Old 02-02-2012, 11:55 PM
FittinglyS1mple's Avatar
There isn't an adapter type piece on the Buddy Club piece. I never set this piece and the factory one next to each other for comparison. Im kind of curious to do so just to see if there's any difference in the actual length of the shifter. Also the bushings in the Buddy Club one are more rigid. A hard plastic it seems like. I don't know. Like I said I've had both the T1R and now this one. This feels a little less notchy to me. Probably a lot has to do with preference too. I'm not exactly sure what Buddy Club did. But whatever it was I'm happy with it. Definitely would never go back to factory after this.
  #182
Old 02-03-2012, 11:17 AM
apexanimal's Avatar
Originally Posted by TPColgett
I've wondered if these make a difference... I found these:
CorSport: Honda - 2007-2008 Honda Fit - 1000.001
Can anyone comment on the effect they have?
https://www.fitfreak.net/forums/fit-...-bushings.html
  #183
Old 03-24-2014, 09:41 PM
kylerwho's Avatar
spoon fed
Info for an old thread.
Installed a T1R shift lever along with skunk2 short shifter kit. Required a 2lbs hammer massage to the metal covering the gas tank but shifts are now very short.
  #184
Old 07-15-2014, 05:06 PM
viperpit07's Avatar
How did you like the skunk 2? I am very interested in it. Good for the money?
  #185
Old 07-16-2014, 12:51 AM
kylerwho's Avatar
spoon fed
the skunk2 helped shorten the throw noticable. the only real complaint I have about them is the set screws they send have a tendancy to work their way loose, even with red locktite. So I removed them and used stainless button head screws instead with locking washers. That seemed to work for me.
Now however I added the T1R short shifter on top of the skunk2 adapter and it is just a ridiculously short throw. I occasionally heard some gears grinding because I was shifting before I could push in the clutch.
  #186
Old 07-17-2014, 07:08 PM
Rollerboots666's Avatar
I was curious how the throw would be if I added the Skunk2 adapter to my Revo short shifter.
  #187
Old 07-17-2014, 09:52 PM
kylerwho's Avatar
spoon fed
im sure it would be really short, however you may run into issues with the shifter hitting the sheet metal above the gas tank. I used a hammer to massage some extra clearance so that it would work.
  #188
Old 07-18-2014, 10:44 PM
Doesn't the Skunk2 kit come with metal spacers that go under the shifter housing?
I know they have the spacers or you can us washer to raise up the housing to clear the shifter from hitting the exhaust or anything else.
  #189
Old 07-19-2014, 12:37 AM
kylerwho's Avatar
spoon fed
yes they do have spacers.
  #190
Old 10-08-2014, 12:58 AM
cnordt24's Avatar
I installed the Revo short shifter over the weekend and I must say I'm impressed. It's less then $90 and it's a nice unit with a smooth short shift, you can definitely feel the difference in the throw over the stock unit.. plus the install was so easy, only took like 15 min.. i highly recommend it ;-)
  #191
Old 10-09-2014, 07:18 PM
viperpit07's Avatar
Bought and installed the skunk 2 kit and i really like it, install was easy for the most part, took alot longer that expected but for the price of it im very happy with it.
cptjon
05-20-2015 07:32 PM
Fit*est
03-23-2012 05:42 PM
CrystalFiveMT
03-06-2010 10:07 AM
No_Skillz
02-17-2009 01:09 PM
xanatos
08-26-2008 11:06 AM
Quick Reply: short shifters question and answers
