Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > Fit Trix > Fit Engine Modifications, Motor Swaps, ECU Tuning
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #21 (permalink)
Old 01-05-2009, 01:07 PM
trancedsailor's Avatar
trancedsailor relies on Rep Points to livetrancedsailor relies on Rep Points to livetrancedsailor relies on Rep Points to livetrancedsailor relies on Rep Points to livetrancedsailor relies on Rep Points to livetrancedsailor relies on Rep Points to livetrancedsailor relies on Rep Points to livetrancedsailor relies on Rep Points to livetrancedsailor relies on Rep Points to livetrancedsailor relies on Rep Points to livetrancedsailor relies on Rep Points to live
Send a message via AIM to trancedsailor
omg kraftwerks + this would be sex!
__________________
For Sale:: Progress swaybar, Weapon R trunk cage, right FX35 retrofit headlight. PM with offer if interested
1994 EG2 B16A3 acquired 9/3/09
  #22 (permalink)
Old 01-05-2009, 01:14 PM
Sugarphreak's Avatar
Sugarphreak relies on Rep Points to liveSugarphreak relies on Rep Points to liveSugarphreak relies on Rep Points to liveSugarphreak relies on Rep Points to liveSugarphreak relies on Rep Points to liveSugarphreak relies on Rep Points to liveSugarphreak relies on Rep Points to liveSugarphreak relies on Rep Points to liveSugarphreak relies on Rep Points to liveSugarphreak relies on Rep Points to liveSugarphreak relies on Rep Points to live
Because of the way this manifold system works you almost need backpressure to make power (as an example, I lost 1whp when I removed the silencer from my exhuast) I would say that a turbo + this manifold would produce some interesting results.
__________________
For a jolt of pure awesome... just click the sugarphreak button!
  #23 (permalink)
Old 01-05-2009, 06:14 PM
DrKelso's Avatar
DrKelso relies on Rep Points to liveDrKelso relies on Rep Points to liveDrKelso relies on Rep Points to liveDrKelso relies on Rep Points to liveDrKelso relies on Rep Points to liveDrKelso relies on Rep Points to liveDrKelso relies on Rep Points to liveDrKelso relies on Rep Points to liveDrKelso relies on Rep Points to liveDrKelso relies on Rep Points to liveDrKelso relies on Rep Points to live
I would really like to see what kind of results this would yield on an FI vehicle.
I just talked to Chris at Weapon*R and he told me that the FINAL version of the intake manifold should be ready in about 3 weeks, which is consistent with what SFactor2 had said earlier. He said that anyone with an older version of the manifold will be able to trade up to the new one. I think he said you'd only have to pay shipping. He said they'd be willing to ship out the replacement manifold first so I can just swap 'em out. I just have to give him a credit card number to keep on hold so that just in case I don't return the old one, they will charge me for the new one.
Wasn't sure if you already knew that but I thought I'd just put it out there.
__________________
WTB: NHBP Sideskirts/Rear lip.
  #24 (permalink)
Old 01-05-2009, 08:31 PM
Been there done that, WR is actually pretty good with their customer service.
__________________
  #25 (permalink)
Old 01-05-2009, 09:23 PM
kylerwho's Avatar
spoon fed
kylerwho relies on Rep Points to livekylerwho relies on Rep Points to livekylerwho relies on Rep Points to livekylerwho relies on Rep Points to livekylerwho relies on Rep Points to livekylerwho relies on Rep Points to livekylerwho relies on Rep Points to livekylerwho relies on Rep Points to livekylerwho relies on Rep Points to livekylerwho relies on Rep Points to livekylerwho relies on Rep Points to live
Send a message via Yahoo to kylerwho
so is there a big differance in size with the wr manifold vs. oem? i plan on going FI within a couple months and i would be willing to buy one of these only if it will help the turbo use cpr on my l15.
__________________
high roller #7
Quote:
Originally Posted by dewthedew View Post
Yeah, I was thinking about you when i made that post. You're insane and I say go for it! you'll have the most badass fit ever.
  #26 (permalink)
Old 01-05-2009, 11:19 PM
One of the cool things about the manifold is the velocity stacks inside, it pumps a ton of air into the engine quickly. The runners are also significantly larger in diameter and very direct for optimum flow.
I think a turbo would yield some interesting gains, it definitely needs some back pressure on the exhuast to make power.
Here is a pic of the pre-production model inside after I used it for a while (it also highlights the need for catch cans). You can see the velocity stacks inside, on the final version of this manifold they are extended out a bit more.
__________________
  #27 (permalink)
Old 01-06-2009, 12:36 AM
DrKelso's Avatar
Quote:
Ya i remember you saying you had already swapped yours. But they said that the new version is different still (i don't know how). Whenever I get around to swapping it I'll post more updates
__________________
  #28 (permalink)
Old 01-06-2009, 02:19 AM
dewthedew's Avatar
Fit Moderator
dewthedew relies on Rep Points to livedewthedew relies on Rep Points to livedewthedew relies on Rep Points to livedewthedew relies on Rep Points to livedewthedew relies on Rep Points to livedewthedew relies on Rep Points to livedewthedew relies on Rep Points to livedewthedew relies on Rep Points to livedewthedew relies on Rep Points to livedewthedew relies on Rep Points to livedewthedew relies on Rep Points to live
Send a message via AIM to dewthedew
but is the final version even worth it? minus whale just go FI.
  #29 (permalink)
Old 01-06-2009, 02:30 AM
kylerwho's Avatar
spoon fed
na is hard to achieve good numbers. i talked with spoon and they told me they only balanced the internals and have the type one tune. no head work. that suprised me.
__________________
high roller #7
  #30 (permalink)
Old 01-06-2009, 08:29 AM
DrKelso's Avatar
Well I don't have to pay for the new version so I might as well give it a shot I just have to send them back my current one. Considering I bought it used, it's actually a pretty good deal
__________________
  #31 (permalink)
Old 01-06-2009, 10:38 PM
Masterdebater's Avatar
Masterdebater relies on Rep Points to liveMasterdebater relies on Rep Points to liveMasterdebater relies on Rep Points to liveMasterdebater relies on Rep Points to liveMasterdebater relies on Rep Points to liveMasterdebater relies on Rep Points to liveMasterdebater relies on Rep Points to liveMasterdebater relies on Rep Points to liveMasterdebater relies on Rep Points to liveMasterdebater relies on Rep Points to liveMasterdebater relies on Rep Points to live
i cant remember if wrleo posted it but i saw somewhere that they were offering a "tune" card that will make it not run lean anymore
  #32 (permalink)
Old 01-06-2009, 11:08 PM
Quote:
Yeah they have a "fuel computer" that will make adjustments, I think they were asking 50$ for it. It sounds like a low cost option to tuning, but I don't know the specific details about it. My question would be if it would run the correct a/f based on elevation and other modifications done to the car.
__________________
  #33 (permalink)
Old 01-06-2009, 11:12 PM
Quote:
The new version is cleaner looking, embossed logo and has a new EGR nipple between the runners on the lower flange. The one I got unfortunately was missing a screw mount near the TB that was on the pre-production model, I let them know and I think they will make the correction to any new ones they produce. Not a big deal, I just used a bit of double sided tape, it is barely even noticeable and the part does not have any kind of load bearing on it.
__________________
  #34 (permalink)
Old 01-07-2009, 04:25 AM
AnlDyxp_GD3's Avatar
AnlDyxp_GD3 relies on Rep Points to liveAnlDyxp_GD3 relies on Rep Points to liveAnlDyxp_GD3 relies on Rep Points to liveAnlDyxp_GD3 relies on Rep Points to liveAnlDyxp_GD3 relies on Rep Points to liveAnlDyxp_GD3 relies on Rep Points to liveAnlDyxp_GD3 relies on Rep Points to liveAnlDyxp_GD3 relies on Rep Points to liveAnlDyxp_GD3 relies on Rep Points to liveAnlDyxp_GD3 relies on Rep Points to liveAnlDyxp_GD3 relies on Rep Points to live
Send a message via AIM to AnlDyxp_GD3
which AF computers do you think are the best for basic bolt-ons? Nothing over kill just for a DD, so not too expensive but will do a good job. Apexi neo, e-manage or f-con? what is this tune chip?
__________________
Tanabe*Mugen*Apexi*Aspec*Blitz*Progress*HFP*Python *T1R*JDM!
  #35 (permalink)
Old 01-07-2009, 01:45 PM
I havn't seen enough hard data for naturaley aspirated tuning systems to know, I went with the E-manage Ultimate because the Fit responded much better to it than the E-manage Blue on turbo setups.
__________________
  #36 (permalink)
Old 01-07-2009, 04:36 PM
ooh isee i see. damn the emanage ultimate is so serious dough though. lol. I may give the apexi afc neo a shot.
__________________
  #37 (permalink)
Old 01-07-2009, 06:52 PM
Yeah my wallet still hurts...
Unless you plan to turbo I think the Apexi Neo is a great way to go.
__________________
  #38 (permalink)
Old 01-07-2009, 07:07 PM
cool. thanks. Maybe I'll pick one up next week. As far as installing the Apexi AF unit, how hard is it? I'm terrible with anything that involves wires. LOL
__________________
  #39 (permalink)
Old 01-07-2009, 08:48 PM
DrKelso's Avatar
from what I understand you just have to tap a few wires here and there and g2g.
__________________
  #40 (permalink)
Old 01-07-2009, 09:27 PM
like i said i know nothing about electrical stuff, so im clueless. LOL
__________________
Reply
Tags
2009, afc, fit, hitch, honda, instal, install, intake, manifold, noblesse, problem, ps, weapon, weaponr, youtube
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Header install question DrKelso Fit Exhaust Systems 3 11-17-2008 07:19 PM
98 accord V6 intake port question Matthew Other Car Related Discussions 0 07-09-2005 02:26 PM
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
