Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > Fit Trix > Fit Engine Modifications, Motor Swaps, ECU Tuning
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #101 (permalink)
Old 03-08-2009, 02:40 PM
WRLEO's Avatar
WRLEO is on a distinguished road
Yes it will work on JDM cars..
  #102 (permalink)
Old 03-08-2009, 02:49 PM
porkchop relies on Rep Points to liveporkchop relies on Rep Points to liveporkchop relies on Rep Points to liveporkchop relies on Rep Points to liveporkchop relies on Rep Points to liveporkchop relies on Rep Points to liveporkchop relies on Rep Points to liveporkchop relies on Rep Points to liveporkchop relies on Rep Points to liveporkchop relies on Rep Points to liveporkchop relies on Rep Points to live
will it fit on the ge8
  #103 (permalink)
Old 03-08-2009, 02:53 PM
kylerwho's Avatar
spoon fed
kylerwho relies on Rep Points to livekylerwho relies on Rep Points to livekylerwho relies on Rep Points to livekylerwho relies on Rep Points to livekylerwho relies on Rep Points to livekylerwho relies on Rep Points to livekylerwho relies on Rep Points to livekylerwho relies on Rep Points to livekylerwho relies on Rep Points to livekylerwho relies on Rep Points to livekylerwho relies on Rep Points to live
Send a message via Yahoo to kylerwho
weapon r is working on one for the ge8 last time i heard.
__________________
high roller #7
Quote:
Originally Posted by dewthedew View Post
Yeah, I was thinking about you when i made that post. You're insane and I say go for it! you'll have the most badass fit ever.
  #104 (permalink)
Old 03-08-2009, 02:54 PM
WRLEO's Avatar
Quote:
Still working on that...
  #105 (permalink)
Old 03-18-2009, 12:01 AM
Senior Member
artieman relies on Rep Points to liveartieman relies on Rep Points to liveartieman relies on Rep Points to liveartieman relies on Rep Points to liveartieman relies on Rep Points to liveartieman relies on Rep Points to liveartieman relies on Rep Points to liveartieman relies on Rep Points to liveartieman relies on Rep Points to liveartieman relies on Rep Points to liveartieman relies on Rep Points to live
Would you still be willing to sell me one of the old manifolds? I have an electrical work around so I can block it without cel.
__________________
efi101.com advanced certified tuner
  #106 (permalink)
Old 03-18-2009, 01:28 AM
Sugarphreak's Avatar
Sugarphreak relies on Rep Points to liveSugarphreak relies on Rep Points to liveSugarphreak relies on Rep Points to liveSugarphreak relies on Rep Points to liveSugarphreak relies on Rep Points to liveSugarphreak relies on Rep Points to liveSugarphreak relies on Rep Points to liveSugarphreak relies on Rep Points to liveSugarphreak relies on Rep Points to liveSugarphreak relies on Rep Points to liveSugarphreak relies on Rep Points to live
Quote:
Without the EGR circulating you will end up with a very lean mix, I suspect a lot of unburned fuel gets reintroduced in this process.
__________________
For a jolt of pure awesome... just click the sugarphreak button!
  #107 (permalink)
Old 03-18-2009, 01:34 AM
Senior Member
Quote:
lean is not an issue since i have the ability to correct the a/f ratio...
__________________
  #108 (permalink)
Old 03-18-2009, 02:09 AM
I did as well with mine, but despite that it still felt very bogged down. I think the EGR system plays a more critical part than most people are aware of.
Anyway, just my thoughts on it. I have been running around for almost a year with 2 different versions of this manifold that block the EGR. Since I did the swap out of the header (T1R for WR) & new manifold I have noticed a pretty significant difference in the low end power and this despite the fact my car tune is way too rich right now.
Today I surprised myself, I downshifted to pass somebody and I got way more power than I was expecting. It is strange, from a steady acceleration from 0-60 it seems like the car is laboring pretty hard (still better than stock), but it responds almost unexpectedly to jolts of throttle and then sustained acceleration.
I still need to play around with a few more things, I have a WR SRI intake waiting to be installed (to replace the Fujita CAI) and some new wheels to throw on in about 2 weeks. I also need to spend some quality time with my E-manage, my LM-2 and a laptop. I still have plans to hit the dyno again and see if all these adjustments make a big difference.
__________________
  #109 (permalink)
Old 03-18-2009, 02:29 AM
Senior Member
exhaust gas recirculation is a bad thing for power output...its for emission control and is part of why the fit has the LEV rating...
im using a custom fuel management system and also using the innovate lm wideband
getting the car to run properly without pumping exhaust back into the cylinder will always make more power.
__________________
  #110 (permalink)
Old 03-18-2009, 04:40 AM
gd3kamiwanaB's Avatar
Luvs Dah b00st!
gd3kamiwanaB relies on Rep Points to livegd3kamiwanaB relies on Rep Points to livegd3kamiwanaB relies on Rep Points to livegd3kamiwanaB relies on Rep Points to livegd3kamiwanaB relies on Rep Points to livegd3kamiwanaB relies on Rep Points to livegd3kamiwanaB relies on Rep Points to livegd3kamiwanaB relies on Rep Points to livegd3kamiwanaB relies on Rep Points to livegd3kamiwanaB relies on Rep Points to livegd3kamiwanaB relies on Rep Points to live
yes but pumping exhaust back into the cylinder is also done to cool the cylinder controlling NOX levels. with out an egr system on a modern fuel injected motor the cylinders would over heat causing oil to burn off the walls and lead to scratching of cylinder walls.
__________________
- KillerFit #13 -
the companies that built a monster!!!
http://www.japtrix.com/ JapTrix Tuning
http://www.cppistons.com/ CP pistons
http://www.innovativemounts.com/ Innovative
http://www.ultraracing.com.my/ Ultraracing
http://www.rceng.com/ RC fuel Injection
http://www.pauter.com/billet_rods.htm Pauter
http://www.kamispeed.com/ Kami Speed
  #111 (permalink)
Old 03-18-2009, 12:18 PM
Senior Member
Quote:
The cylinders would overheat is way off base...fuel cools the cylinders which is why high horsepower boosted cars run rich...pumping hot exhaust back into the cylinder would not cool it. But by pumping exhaust back into the cylinder your reducing the room for fuel and oxygen which reduces power and heat (you can cause the exact same thing by letting up on gas pedal ). Honda has a lot of different fuel injected engine models without egr on them.
__________________
  #112 (permalink)
Old 03-18-2009, 01:31 PM
Logically you will get no arguement from me, on paper this looks good
I just wasn't getting the results I wanted with it blocked, I was using the E-manage Ultimate tuned by AJRacing. Now that I am running with it flowing I can tell the differance, like I was saying before I suspect there is more going on here than just an efficency process.
Anyway, not looking to debate it. I am just sharing my experience
__________________
  #113 (permalink)
Old 03-19-2009, 03:30 AM
Shaggs2Dope's Avatar
Frequent FitFreak Poster
Shaggs2Dope relies on Rep Points to liveShaggs2Dope relies on Rep Points to liveShaggs2Dope relies on Rep Points to liveShaggs2Dope relies on Rep Points to liveShaggs2Dope relies on Rep Points to liveShaggs2Dope relies on Rep Points to liveShaggs2Dope relies on Rep Points to liveShaggs2Dope relies on Rep Points to liveShaggs2Dope relies on Rep Points to liveShaggs2Dope relies on Rep Points to liveShaggs2Dope relies on Rep Points to live
Damn, thats a nice bunch of goodies, It's gonna be sick when everything is set.
__________________
Aww, they love each other, but are jealous of who gets my attention
  #114 (permalink)
Old 04-04-2009, 11:24 AM
azkikersfit relies on Rep Points to liveazkikersfit relies on Rep Points to liveazkikersfit relies on Rep Points to liveazkikersfit relies on Rep Points to liveazkikersfit relies on Rep Points to liveazkikersfit relies on Rep Points to liveazkikersfit relies on Rep Points to liveazkikersfit relies on Rep Points to liveazkikersfit relies on Rep Points to liveazkikersfit relies on Rep Points to liveazkikersfit relies on Rep Points to live
so wtf up wid dis? it just died out? no one doin any dyno runs or reviews with this manifold ?
__________________
EVIL Prevails when GOOD MEN DO NOTHING
  #115 (permalink)
Old 04-04-2009, 03:16 PM
WRLEO's Avatar
Waiting on these guys.. I gave deals to about 12 people..
This is NOT COOOL..
  #116 (permalink)
Old 04-22-2009, 12:22 PM
Car is tuned, wheels are finally here (tires arived Monday); Dyno is tenatively scheduled for May 17th
__________________
  #117 (permalink)
Old 04-22-2009, 12:47 PM
Senior Member
no before and after dyno runs makes it pointless...and how did you tune it without a dyno? You can get the a/f ratio close street tuning but you cant do timing on the street.
__________________
  #118 (permalink)
Old 04-22-2009, 12:54 PM
Street tuned doing 2nd gear pulls and then adjustments from the logworks graph to the E-manage map to hit my target A/Fr's. Naturally the dyno will also be used to make final adjustments based on the power output.
__________________
  #119 (permalink)
Old 05-02-2009, 01:03 AM
explosivpotato's Avatar
explosivpotato relies on Rep Points to liveexplosivpotato relies on Rep Points to liveexplosivpotato relies on Rep Points to liveexplosivpotato relies on Rep Points to liveexplosivpotato relies on Rep Points to liveexplosivpotato relies on Rep Points to liveexplosivpotato relies on Rep Points to liveexplosivpotato relies on Rep Points to liveexplosivpotato relies on Rep Points to liveexplosivpotato relies on Rep Points to liveexplosivpotato relies on Rep Points to live
Not having EGR is going to throw off your timing. EGR requires a lot of extra timing. Just turning it off will cause you to detonate. The reason it felt bogged is probably because you were bouncing off the knock retard.
EGR doesn't do anything at WOT anyway, so there's really no benefit from turning it off. It improves mileage too, as well as emissions.
__________________
'07 MR Fit Sport MT
T1R Turbo kit, 6psi
AEM F/IC tuned by yours truly!
155hp, 157.1 Ft-Lb
,___,
[O.o]
/)__)
-"--"- ORLY??
Need tuning or troubleshooting assistance?
PM ME!
  #120 (permalink)
Old 05-02-2009, 01:15 AM
The new manifold allows for free flowing EGR
__________________
Reply
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
DIY: P2R Intake Manifold "performance" gasket Fit of RAGE Fit Engine Modifications, Motor Swaps, ECU Tuning 47 02-26-2009 02:06 AM
jdm usdm intake manifold difference Spooling Fit Engine Modifications, Motor Swaps, ECU Tuning 0 08-02-2008 08:45 PM
'80 Civic c v c c 1.5 manifold cloged up.Any solutions? carperson Other Car Related Discussions 0 05-04-2005 12:16 PM
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
