Kraftwerks A/T @ 10psi?
#181
Did you bypass the stock AT cooler or do you use both? Did you have Flashpro? Im getting rid of EGR simply because is doesn't fit and hondata lets you delete it.
Here is where my head has been, k24 manifold and TB all because the intake doesn't fit, will have to "lower" the oil cap too. I am getting the Garrett GT2554r and a 6psi wastegate, and air to water intercooler for a nice short intake track.
#182
The K24 is a 2 piece design, I'm using the plenum side and making my own engines side half which will be under 2 inches in length.
#183
Waiting for the pics of the manifold already finished
#184
It might take a month on the manifold, I have 3 projects on the car going at once.... I have a half assed build thread going on HT, come see how I am re-drilling an HKS K20 turbo manifold to bolt right on to the L15
Build thread-1G Insight w/L15a Fit A/T ultimate commuter - Honda-Tech
#185
#186
I'm still trying to figure out where I can get a turbo manifold for my Fit
#188
yes stock fuel pump is fine on 10psi. I would suspect it can handle up to 200hp.
seeyalaterbye
08-19-2016 03:02 PM
dustinb
02-06-2012 05:04 PM
explosivpotato
122
07-08-2011 08:44 PM
pbz08gd3
09-08-2009 03:41 PM
im the fit
45
05-01-2009 11:58 PM
