Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > Fit Trix > Fit Engine Modifications, Motor Swaps, ECU Tuning
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #41 (permalink)
Old 04-30-2009, 01:51 AM
explosivpotato's Avatar
explosivpotato relies on Rep Points to liveexplosivpotato relies on Rep Points to liveexplosivpotato relies on Rep Points to liveexplosivpotato relies on Rep Points to liveexplosivpotato relies on Rep Points to liveexplosivpotato relies on Rep Points to liveexplosivpotato relies on Rep Points to liveexplosivpotato relies on Rep Points to liveexplosivpotato relies on Rep Points to liveexplosivpotato relies on Rep Points to liveexplosivpotato relies on Rep Points to live
OK I did some research and I think I see how they did this.
MAP signal controls timing as well as fuel for our cars. The F/IC allows you to remap the MAP signal based on load / RPM.
By pulling MAP voltage, you effectively pull fuel AND add timing (via the stock maps). You can add the injector pulsewidth back in directly using the main fuel map, and your net result is advanced timing. You'd have to use some sort of OBD 2 monitor / logger to ensure you aren't adding too much / not enough timing, however, as the FIC can't datalog ignition timing.
So, by ghetto-rigging it, you CAN run advanced timing with the F/IC.
Hm... I might try implementing a lean cruise with this... Advanced timing + lean mixtures at cruise loads can make for some ridiculous gas mileage.
__________________
'07 MR Fit Sport MT
T1R Turbo kit, 6psi
AEM F/IC tuned by yours truly!
155hp, 157.1 Ft-Lb
,___,
[O.o]
/)__)
-"--"- ORLY??
Need tuning or troubleshooting assistance?
PM ME!
  #42 (permalink)
Old 05-01-2009, 06:38 PM
im the fit's Avatar
im the fit relies on Rep Points to liveim the fit relies on Rep Points to liveim the fit relies on Rep Points to liveim the fit relies on Rep Points to liveim the fit relies on Rep Points to liveim the fit relies on Rep Points to liveim the fit relies on Rep Points to liveim the fit relies on Rep Points to liveim the fit relies on Rep Points to liveim the fit relies on Rep Points to liveim the fit relies on Rep Points to live
can someone please explain what the load does in map load with the F/ic
__________________
"I rather drive a slow car fast than a fast car slow"
  #43 (permalink)
Old 05-02-2009, 12:29 AM
im the fit's Avatar
and do I need to use the on board map on the fic foe N/A?
__________________
  #44 (permalink)
Old 05-02-2009, 12:51 AM
Manifold pressure is a measurement of engine load. All fuel maps for speed density cars are plotted against RPM and Load (MAP).
And yes, you need the on board MAP sensor. The FIC uses it for the load calculation.
__________________
'07 MR Fit Sport MT
T1R Turbo kit, 6psi
155hp, 157.1 Ft-Lb
,___,
[O.o]
/)__)
-"--"- ORLY??
PM ME!
  #45 (permalink)
Old 05-02-2009, 12:55 AM
im the fit's Avatar
alright one last question before I install on saturday what do I connect that hose to
__________________
  #46 (permalink)
Old 05-02-2009, 12:58 AM
The hose is vacuum line. It's for the MAP sensor nipple on the front of the FIC. It goes to any vacuum source off the intake manifold.
__________________
'07 MR Fit Sport MT
T1R Turbo kit, 6psi
155hp, 157.1 Ft-Lb
,___,
[O.o]
/)__)
-"--"- ORLY??
PM ME!
Reply
Tags
advancing, aem, afc, apexi, cheap, fic, fit, gains, hack, honda, idle, na, neo, problems, timing, tuning
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
AEM F/IC product review! explosivpotato Fit Forced Induction Forum 98 09-21-2009 01:50 PM
FS: Apexi WSII, Megan b-pipe, Fujita SRI GD3_Wagoon For Sale / Want To Buy / Classified Ads for USED Fit Items 58 02-05-2009 11:29 PM
FS: Megan b-pipe & Fujita SRI & Apexi WS II Axleback GD3_Wagoon SoCal Classifieds 41 01-21-2009 10:06 PM
New Apexi Exhaust for the Fit Invision Fit FIT-Vendor Sponsored Group Buys and Sales 16 07-17-2008 12:15 PM
Apexi WS balefire Fit Exhaust Systems 10 06-05-2008 11:45 PM
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
