Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > Fit Trix > Fit Engine Modifications, Motor Swaps, ECU Tuning
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #21 (permalink)
Old 07-05-2009, 07:09 PM
FELIXY69's Avatar
FELIXY69 relies on Rep Points to liveFELIXY69 relies on Rep Points to liveFELIXY69 relies on Rep Points to liveFELIXY69 relies on Rep Points to liveFELIXY69 relies on Rep Points to liveFELIXY69 relies on Rep Points to liveFELIXY69 relies on Rep Points to liveFELIXY69 relies on Rep Points to liveFELIXY69 relies on Rep Points to liveFELIXY69 relies on Rep Points to liveFELIXY69 relies on Rep Points to live
Quote:
Originally Posted by leonine View Post
i'm no expert on this subject but just wondering how the water/methanol is cooling the air going in to the engine. If the fluid is hot from being in the engine bay then how is it cooling the air. I know it will cool down the cylinder right but i am concerned about the ecu still showing hot air from the IAT sensor and pulling timing even though it is cooler inside the engine.
Maybe i am way off...probably.
u dont put the tank in the engine bay...duh...i ran this in my gtr and i was able to run higher boost with no problem !
__________________
One Cool Daily Driver
Honda tuning is a LifeStyle
Nissan tuning is to go stupid FAST !
Goals for 2009
Wide Fenders --> DONE
Airbags --> 3/4 DONE
Wide Wheels --> 9.5 +5
~~B00sted Wide Body NobleSSe fit~~
Rep me if you like
thank you !
  #22 (permalink)
Old 07-05-2009, 07:10 PM
FELIXY69's Avatar
but theres a bad side to this as some ppl say they create moisture in the block and will rust inside the motor.....
__________________
Goals for 2009
Rep me if you like
thank you !
  #23 (permalink)
Old 07-05-2009, 08:52 PM
Texas Coyote relies on Rep Points to liveTexas Coyote relies on Rep Points to liveTexas Coyote relies on Rep Points to liveTexas Coyote relies on Rep Points to liveTexas Coyote relies on Rep Points to liveTexas Coyote relies on Rep Points to liveTexas Coyote relies on Rep Points to liveTexas Coyote relies on Rep Points to liveTexas Coyote relies on Rep Points to liveTexas Coyote relies on Rep Points to liveTexas Coyote relies on Rep Points to live
There is condensation occurring inside an engine every time you start it when the weather is cool and it will dissipate after about 6 or 8 miles of driving. One cool thing about water/methanol injection is that it steam cleans the combustion chamber and the steam exits the engine during the exhaust stroke.... If you are putting too much into your intake you are gong to quench the plugs and have to disconnect the coils and crank the engine with the throttle held wide open to clear it.
  #24 (permalink)
Old 07-06-2009, 12:11 AM
Bassplayer's Avatar
Bassplayer relies on Rep Points to liveBassplayer relies on Rep Points to liveBassplayer relies on Rep Points to liveBassplayer relies on Rep Points to liveBassplayer relies on Rep Points to liveBassplayer relies on Rep Points to liveBassplayer relies on Rep Points to liveBassplayer relies on Rep Points to liveBassplayer relies on Rep Points to liveBassplayer relies on Rep Points to liveBassplayer relies on Rep Points to live
Wow great thread with awesome info. My buddy has meth inj on his STi and loves it.
__________________
BUY MY MOTORCYCLE! 2006 SV650 http://www.fitfreak.net/forums/gener...tml#post706958
2008 MR Honda Fit Sport 5MT- DD
2006 Suzuki SV650
1989 CRX LS/vtec
1978 Ford F150
  #25 (permalink)
Old 07-14-2009, 09:38 AM
SWRWKFS's Avatar
SWRWKFS relies on Rep Points to liveSWRWKFS relies on Rep Points to liveSWRWKFS relies on Rep Points to liveSWRWKFS relies on Rep Points to liveSWRWKFS relies on Rep Points to liveSWRWKFS relies on Rep Points to liveSWRWKFS relies on Rep Points to liveSWRWKFS relies on Rep Points to liveSWRWKFS relies on Rep Points to liveSWRWKFS relies on Rep Points to liveSWRWKFS relies on Rep Points to live
yeah, i made an album with some pics of the kit in it (cuz it seemed easier than postin them all in this isnt there a way to just take jpg images and just paste em in this little box....no html blahblah? owell)
And its a Snow Performance Kit.. even tho the name of this thread is AEM...
The car goes into be tuned next monday. even tho it was supposed to be today but they rescheduled me..
I don't think it will be much different from the original tune. All i did was up the boost 2psi and put the Meth kit on. I'll just have to wait and see.
  #26 (permalink)
Old 07-22-2009, 06:18 AM
SWRWKFS's Avatar
well the car is tuned and the meth didnt do much for power because advancing timing with the fit's L15A motor did not add any HP. it actually lost a bit when they turned it up the first couple of degrees.
So I got +12hp and +20tq so i now have 156whp and 167wtq
The Fit is also an AT paddleshifter so any more of a gain that this would most likely begin to damage the Transmission, Which was my main concern.
  #27 (permalink)
Old 07-22-2009, 08:05 AM
Well you have got me sold. That is a hell of a power gain from something that will extend the life of your combustion chamber. The system buffers the initial explosion at ignition in addition to cooling and cleaning. It also lowers exhaust temperature reading by the O2 sensor. What are your A/F ratios. and ignition advances when it is squirting juice..... I don't think that it is advised to use more than 50% methanol to avoid a possibility of combustion in the intake manifold which can become a disaster on a boosted motor.... Instead retune with some nitromethane in the mixture with 50% water.... You added more boost so it is no surprise that it couldn't take more timing advance.
  #28 (permalink)
Old 07-22-2009, 09:06 AM
Wave's Avatar
Wave relies on Rep Points to liveWave relies on Rep Points to liveWave relies on Rep Points to liveWave relies on Rep Points to liveWave relies on Rep Points to liveWave relies on Rep Points to liveWave relies on Rep Points to liveWave relies on Rep Points to liveWave relies on Rep Points to liveWave relies on Rep Points to liveWave relies on Rep Points to live
+12hp & +20tq is a nice gain considering the tiny motor we have.
__________________
  #29 (permalink)
Old 07-22-2009, 10:40 AM
I would rather see a larger torque gain than horsepower on a small displacement motor with street gearing any day, and oh so much more on an automatic with such tall gearing.... I would be happier than a possum eating cow shit..... That is big time oozing with happiness. I'll tell you.
  #30 (permalink)
Old 07-26-2009, 07:56 PM
SWRWKFS's Avatar
yeah the fit is running well and i can feel that little extra bit of torque in the later gears, which is a nice feeling
with meth injection before tuning a/f ratio was in mid 13's, and now after tuning its like low12, low 12 ,low 12 then dips alittle to high 11's ... (lol i'm staring at the graph line... not an exact science...eyeballin it like this.....)
basically right around 12, i dont know the exact number.
The snow performance kit uses a vacuum diaphragm switch which uses boost pressure to tell the pump when to turn on. ( and the more expensive kits[cuz i just got stage 1] have like a cool little controller so you can do/set everything up on it in-cabin blah blah coolness...)
I set mine first at like 4 psi, but once the first dyno run was done, they let off the gas and the car bogged n died. lol, i had it putting meth in too early so i adjusted it and it is set to come on at like 4.6-4.8psi, which works awesome.
so if you get the kit just dont set the meth too early and it'll be amazing, cuz the install is pretty darn easy.
Reply
Tags
aem, coolingmist, fluid, honda, injection, kit, labonte, maintenance, meth, methanol, snow, srt, vw, washer, water
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Has anyone tried Water/Meth Injection? dewthedew Fit Forced Induction Forum 11 04-13-2009 10:10 PM
Complete OBD II Codes List sLiVeRwOrM Fit DIY: Repair & Maintenance 13 02-14-2009 06:22 PM
Methanol injection discussion CasopoliS Fit Engine Modifications, Motor Swaps, ECU Tuning 5 12-20-2007 12:29 AM
Methanol bad for Fit (and all Hondas) Edwood General Fit Talk 2 05-24-2006 01:11 PM
90 model civic dx injection operation from factory manual Steve Other Car Related Discussions 8 10-16-2005 12:31 AM
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
