braille battery question
i was planning to buy the braille B14115 (only weighs 11.5 pounds), but do i have to worry about the car not being able to start if i have the car off and the radio on for about 1 hour or 2 hours?
the OEM battery has only 310 CCA
the odyssey PC680 battery has only 220 CCA (this battery is recommended with the password JDM intake)
the braille B14115 has 360 CCA
so technically the braille battery should be better than OEM. will i have any other problems with this battery? what else should look for before i buy this battery? what is the reserve capacity for the OEM battery?
