The stock Fit fuel system (on the L15A1 anyway) runs at a STATIC 50psi.
There is no fuel pressure regulator like there is in older Honda setups. This means that as the manifold pressure rises, the effective fuel pressure (differential between the fuel rail and the intake charge pressure) drops. At some point the effective pressure will get too low for proper fuel atomization, but at .6 bar (which is I think about.. 8psi?) you won't see this problem. 50-8=42, which is still pretty high, so no worries. Older Hondas ran at a constant relative pressure of about 35psi.
So, to answer your questions:
1. 50psi
2. It will only increase consumption if you cannot retune the injector map to compensate (if you cannot adjust the stock ecu directly/with a piggyback fuel controller, it will throw all sorts of things off - don't do it).
3. 50psi. You're doing a pretty mild setup here, and the only way to adjust the fuel pressure would be to rip out the WHOLE fuel system and replace it with a return-style system like in earlier Hondas.
__________________
'07 MR Fit Sport MT
T1R Turbo kit, 6psi
AEM F/IC tuned by yours truly!
155hp, 157.1 Ft-Lb
,___,
[O.o]
/)__)
-"--"- ORLY??
Need tuning or troubleshooting assistance?
PM ME!
