GD3 Rotrex Build
  #81
Old 12-05-2016, 05:57 PM
lakia5524's Avatar
where the rest of the good stuff
  #82
Old 12-09-2016, 07:13 PM
lakia5524's Avatar
nice one of a kind build , so leonine are you using a smaller pulley to get your power other than internals bore size and camupgrades? just curious with the whole max impeller speeds configuring what the 15-60c can be pushed to with out destroying it think its rated to 200 or so hp if only making 60-70 extra on stock at 10psi dose it really take 120-130 to spin it up feel theirs more to give
  #83
Old 12-10-2016, 06:22 AM
leonine's Avatar
Thanks. The 15-60 is rated at close to 240hp on the rotrex tech sheet. Pulleys are the same as the original kit. I am using 2 blowers so I am hoping to be in the 280-320hp range.
But whatever the numbers I will be happy. The motor is built to last and rated at much higher numbers than that.
Lots of pics up on their FB page but here's a few I saved to my phone.
Attached Thumbnails GD3 Rotrex Build-fb_img_1480630697832.jpg   GD3 Rotrex Build-fb_img_1480630709415.jpg   GD3 Rotrex Build-fb_img_1480630694651.jpg   GD3 Rotrex Build-fb_img_1480630668523.jpg   GD3 Rotrex Build-fb_img_1480630652884.jpg
GD3 Rotrex Build-fb_img_1479846327668.jpg   GD3 Rotrex Build-fb_img_1479412595166.jpg   GD3 Rotrex Build-fb_img_1479319531165.jpg   GD3 Rotrex Build-fb_img_1477766345449.jpg
  #84
Old 12-13-2016, 09:45 PM
Bongobennie's Avatar
Bad ass!! Glad this thread found me!
  #85
Old 02-10-2017, 12:36 PM
dgraz0r's Avatar
Your build is being done by JK Motorsports right? I saw it on FB and it's sweeeeeeet.
Any update about the adjustable cam gear?
  #86
Old 02-10-2017, 12:40 PM
leonine's Avatar
It is done and ready to order. Contact Greg and let him know Brian sent you.
  #87
Old 02-11-2017, 06:23 PM
Do you know if he will sell intake manifold or even the flanges? I tried emailing with no luck, maybe they are out racing.
  #88
Old 02-11-2017, 07:06 PM
leonine's Avatar
I'm sure they wish they were out racing. As far as I know they are trying to get my car finished as it has been taking up a bay for a year now. Your best bet is to message them through Facebook.
the engine is in, exhaust, axles and brakes are done. Last I spoke they had to remake some of the intercooler piping due to clearance issues with the radiator reservoir bottle. Also relocated the oil filter.
once that is done they need to route all of the lines for rotrex oil and coolant. Went with braided line and fittings instead of hose and clamp. Then extend the wiring harness to reach the intake manifold.
then start this be bitch up for God's sake and tune!!!! He is not mass producing any of this stuff as the demand is not high bit he will make it. Tell Greg that Brian referred you if you are interested.
the manifold won't be cheap but it is worth it in my opinion. Weapon R charged like 600+ if I recall for a piece of shit sheet metal manifold (I lined up to buy it) and while it made gains it cracked from shitty design under high boost.
the manifold I have will cost more and you will have to extend wires but it is a work of art. My opinion although others may disagree which is fine.
some more pics attached. Going to drive out soon as I have not seen her for a long while.
Attached Thumbnails GD3 Rotrex Build-fb_img_1485968438445.jpg   GD3 Rotrex Build-fb_img_1485963845053.jpg   GD3 Rotrex Build-fb_img_1485560651399.jpg   GD3 Rotrex Build-fb_img_1485467337853.jpg   GD3 Rotrex Build-fb_img_1480785645000.jpg
GD3 Rotrex Build-fb_img_1482592858315.jpg   GD3 Rotrex Build-received_1331395253570231.jpeg   GD3 Rotrex Build-received_1331395316903558.jpeg
  #89
Old 02-11-2017, 08:53 PM
Oh man thats pretty!!!
  #90
Old 02-20-2017, 05:04 AM
devmail's Avatar
That intake manifold IS ART. So the throttle body is on the bottom tho?
  #91
Old 02-20-2017, 08:04 AM
leonine's Avatar
correctamundo
  #92
Old 02-24-2017, 07:02 AM
leonine's Avatar
Some more engine shots now that it is fully assembled.
  #93
Old 02-27-2017, 12:28 AM
idrivemyself's Avatar
I just went through the thread and wow... Can't wait to see the finished product and how it drives!
  #94
Old 05-06-2017, 10:55 PM
lakia5524's Avatar
I like how the manifold is out of the way of the valve cover any dyno vids I want to hear it
  #95
Old 05-16-2017, 05:35 PM
mangosmoody's Avatar
Originally Posted by leonine
correctamundo
any shots of the TB and how it sits? just curious did you have to extend anywires etc?
  #96
Old 05-18-2017, 09:20 PM
leonine's Avatar
No good pics of the TB yet. It is directly under the manifold. The oem fam and shroud was removed and replaced with a higher output one.
the wires needed to be extended to the throttle body but it turned into a major rewire because the builder wanted to tuck everything out of the way.
so still waiting...last I heard a week or so ago he only has to rewire the harness for the ID injectors (not using the honda to ID connectors I guess he wanted it clean). Everything else is done.
I assume that has been done by now so it should be a couple of weeks (I hope) to break in the engine properly and tune.
it's been so long (15 months) I have lost most of the enthusiasm of this build. Hopefully that will be restored when I finally pick it up.
  #97
Old 05-26-2017, 02:50 PM
devmail's Avatar
From the looks of their other work, the results should not disappoint! The front mount intercooler is MASSIVE and menacing! Love it.
  #98
Old 06-20-2017, 03:12 PM
kylerwho's Avatar
spoon fed
So according to Instagram, the build is done and dyno time is coming up.
I want to see that sweet dyno chart!!
  #99
Old 06-20-2017, 05:23 PM
leonine's Avatar
Yup!!! Tomorrow it's going on. Running fine now front blower was replaced cause it was leaking.
hoping for some great numbers
  #100
Old 07-10-2017, 10:53 PM
Myxalplyx's Avatar
Been away for a while and just getting back to this thread.
So.....any numbers? Any 1/4 mile times?
Quick Reply: GD3 Rotrex Build
