Those with a testpipe.
Old Feb 12, 2009 | 04:50 AM
  #41
Spooling's Avatar
Originally Posted by Sugarphreak
From everything I have heard it increases the sound quite a bit, but also provides a decent gain for the price. I run with my cat in right now, but I do own a T1R testpipe that I had planned to put in... but since then I am instead trying out the WeaponR header which replaces the cat all together.
I think with a N.A. & full header, exhuast and test pipe setup you will find it removes a lot of the back pressure to the point where it might actually lose power. You may want to use it with an intake that flows easily like an SRI or maybe a small chamber like the H-Fit one. I can't offer concrete evidence, but from playing around with my setup over the past two years I believe this will ring true.
You are going to want to watch out if you are running all the I/H/E goodies & test pipe because the Fit will run too lean. Maybe pick up something cheap like an Apexi-Neo to correct it.
I'm not a combustion engineer but how is it possible to run lean if you only modify the exhaust side of things under NA circumstance?
Old Feb 12, 2009 | 08:07 AM
  #42
NIGHTHAWKSI's Avatar
intake as well...
Old Feb 12, 2009 | 12:57 PM
  #43
Sugarphreak's Avatar
Push My Button
Do a search on the AJ-Racing thread, they talk about the car running too lean when you add a test pipe to the I/H/E setup
EDIT:
Here you go, bask in my epic seaching ability
https://www.fitfreak.net/forums/aj-r...questions.html
Actually you were involved in this post... the second post basically is what i was going off of.
Originally Posted by AJ PwR Jr.
All the dynos we performed were running with a stock catalytic convertor. We have dynoed the test pipe and it was and about 2whp across the band. The A/F was lean so adding some more fuel will coodinate to make more power.
Old Feb 12, 2009 | 01:00 PM
  #44
Push My Button
Originally Posted by NIGHTHAWKSI
intake as well...
With the CAI vs Chamber vs SRI I was careful to put in "I think" and "I have no concrete evidence"... just my own obervations when you reduce the backpressure on this engine it seems like the amount of initial resistance to overcome with a CAI seems to impact things a bit.
Take it or leave it, would love for somebody to prove it.
Old Feb 12, 2009 | 01:39 PM
  #45
Spooling's Avatar
EDIT:
I'm looking for technical answers as to why with addition of a test pipe will increase lambda.
Old Feb 12, 2009 | 02:06 PM
  #46
Push My Button
I see your point, unfortonately I don't have an answer. What I do know is that they seem to keep running into this issue whenever they use testpipes.
I can only theorize that significantly reduced backpressure is maybe letting more air pass through the entire system than the ECU is compensating for?
Anyway, just something to be aware of for our OP when considering a test pipe.
Old Feb 12, 2009 | 03:55 PM
  #47
sevenaprils's Avatar
So reading through the whole thread (thanks for posting the link, btw) it seems like yes the fit will lean out, but not to the point of potential catastrophic damages.
I'm running Fujita CAI, A-Spec test pipe, and skunk2 50mm b-pipe/axle back. (So this would be assuming my mods would behave similar to the T1R parts)
I feel less power than before from idle to 2500. By 3000, there is a much more drastic change in feel between VTEC/no VTEC, more than before the test pipe (but with the other mods) and definitely night and day from bone stock.
I'm considering removing the axle-back portion and seeing how it sounds/or if any performance change in the lower RPMs.
If it does, I'll run a stainless pipe from the b-pipe to the rear to look "normal". If not, I'll just deal with it I suppose - boost should be in the future anyway, just not sure when.
Oh, and some non-scientific anecdotal evidence: I run scan gauge - Running on stock parts, using the "Instant Horsepower" gauge, I never got a reading higher then 74.X up through to redline in 2nd gear. With the skunk2 cat back and a couple different intake setups, I got to 84, redlining 2nd. With the test pipe, doing the exact same thing, redline 2nd, I got to 104.
I know the numbers are probably bogus because it's just a scangauge, but the take home message is that to me it seems there is enough of a power increase with the mods (especially the test pipe) to warrant an increased reading from the little SGII. For all I know though I could be making 3 more ponies with all these parts though in reality. But hey, at least it's something.
Uh, Where's the OP in all this anyway? He sort of disappeared after page 1?
Old Feb 12, 2009 | 04:13 PM
  #48
i didnt yet add this in here...but currently the only performance mod to my car is a test pipe. my wideband a/f gauges reads over 18:1 when partial throttle sometimes. it sometimes goes higher and reads "---"
Old Feb 12, 2009 | 05:00 PM
  #49
Push My Button
Where is your wideband sensor tied into?
Old Feb 12, 2009 | 05:59 PM
  #50
That can't be right? I'm assuming your car runs fine? I'm no pro with the who AFR thing but it seems like 18:1 is VERY lean?
What wideband are you using?
I'm thinking of starting off by picking up a regular A/F gauge for the time being, then whenever kraftwerks graces the presence of my engine bay upgrade to a wideband... but is it even worth it to get a narrowband - I keep reading online it's not accurate or really valid because the ratio computed is so broad.
And an off topic question - with JUST the testpipe, is there a performance gain to be felt at all? I'm tempted to play with my exhaust setup until I get the "best" feeling.
Old Feb 12, 2009 | 07:16 PM
  #51
Spooling's Avatar
Lol.
This thread delivers.
Old Feb 13, 2009 | 09:53 AM
  #52
i dont see how it can be wrong. its a AEM UEGO wideband. brand new. and there are no other mods to the engine. it idles at 14.9 and for teh most part is 15.5-16.5 when crusing. but once and a while it flashes to 18 and 2 times ive seen it go "---". im not that worried since the car is mostly stock...its probly supposed to be that way to get good MPG.
Old Feb 13, 2009 | 10:33 PM
  #53
*Garismatic*'s Avatar
Just confirming, what sort of throttle position are you seeing this enormously lean condition? Also, where is the wideband mounted?
Old Feb 14, 2009 | 04:05 PM
  #54
its partial throttle...just enough to maintain a 60mph cruise on the highway in 5th gear. at WOT is is much richer...more lieka 15.5-16.0
wideband is mounted a couple inches before the secondary o2 sensor.
Old Apr 6, 2009 | 07:25 PM
  #55
Koi's Avatar
Koi
Is anyone running I/H/E with test pipe? I'm interested in trying out the cat-delete but all this talk about leaning out too much makes me wonder if anyone's had the whole setup for a while w/o any problems.
Old Apr 14, 2009 | 11:58 PM
  #56
goodyonsen's Avatar
i say dont do it. my test pipe is has caused me nothing but trouble ever since i got it. ill be selling it soon. its a t1r. PM me if interested.
Old Apr 15, 2009 | 03:59 AM
  #57
revd34's Avatar
what kind of problems? mechanical or law enforcement?
btw i'm selling my t1r test pipe. don't need anymore i have the j's test pipe
Old Apr 15, 2009 | 02:36 PM
  #58
Sid 6.7's Avatar
Why so serious?
As a preamble, I am not an engineer nor do I claim to be one. The following is based on my personal experience, study of the subject and logic. So take this with a grain of salt.
The reason the test pipe causes the Fit to go lean, is because the engine runs on a speed density fuel injection system.
Let me explain.
Speed density systems rely on two primary sensors, the Manifold Absolute Pressure sensor (MAP) and an Intake Air Temperature sensor (IAT). These two sensors work in conjunction with the ECU to precisely and accurately "predict" the amount of air passing through the engine.
Notice I said "predict", not measure. That is because the speed density system doesn't actually measure the amount of air passing through the engine. It calculates this value using the amount of manifold pressure and air temperature, and then based on a set of values already entered into the ECU that represent the Volumetric Efficiency (VE) of the engine, it "infers" or extrapolates how much air should be entering the engine.
The formula is expressed thusly: (Engine Mass Airflow Rate) ≈ RPM × MAP / (absolute temperature)
This is based on the presumption that the fuel tables that are set in stone in the ECU concerning VE (volumetric efficiency), stay the same.
When you increase the size of the intake/exhaust tract, you are changing the VE of the engine, without changing the preset values in the ECU.
The MAP and IAT are still reading the same values. What the ECU doesn't know is that even though pressure and temp have stayed the same, the amount of air has increased, sometimes dramatically.
Most of the time, but not all of the time, most of the time, since factory engine ECUs tend to run on the rich side, leaning the mixture down some will increase horsepower. But at a certain point, it begins to lose power. Especially in the higher RPM range.
The only way to compensate, is to increase fuel delivery. And that can be done by increasing base fuel pressure, or changing the ECU fuel map parameters to reflect the new VE value.
Ref:
MAP sensor - Wikipedia, the free encyclopedia
Speed Density to Mass Air Flow Conversion
Old Apr 16, 2009 | 09:24 PM
  #59
shazaam's Avatar
and a high five to sid regardless what'ss 100% true. makes me wanna go on n learn to tune
MissFit10
Feb 27, 2012 10:39 PM
dewthedew
20
Jan 20, 2009 06:49 PM
ikrash
17
Oct 27, 2008 03:14 AM
AnlDyxp_GD3
20
Oct 26, 2008 03:17 AM
sy11580
18
Oct 9, 2008 12:59 AM
