Fit FREAK.net
Go Back   Honda FIT Forums > Fit Trix > Fit Forced Induction Forum
Discuss all Forced induction modifications for the Fit
Forum Sponsor: KraftWerks
Reply
  #41 (permalink)
Old 12-28-2007, 01:01 PM
NvM NvM is offline
NvM will become famous soon enough
i'm currently running a custom setup with a TD04 subaru forester turbo, had it on my car for almost 2 yrs, & 35,000 kms, regular servicing & hasnt ever missed a beat, stock engine internals. Engine is the L15A & car has been tracked quite regularly Turbo Lag is not to bad, starts spooling @ 2200rpm & full around 3k. & If you do go custom i would highly recommend a aftermarket ECU, money well spent. Also i'm currently using delphi 380cc injectors which i found did the job very nicely.
If I were going to go for a off the shelf kit i would consider Top Fuel as well as HKS, but i'm unsure of the fitment for the USDM Fit's.
  #42 (permalink)
Old 03-28-2008, 07:18 AM
jscooter is an unknown quantity at this point
what numbers are you gettin and what is your exact set-up?
  #43 (permalink)
Old 03-28-2008, 12:01 PM
NvM NvM is offline
get 152 hp @TW, have a dyno sheet will post it & it was on 6 psi tune which i achieved this.
Engine
L15A
Custom Turbo kit running a TD04
HKS BoV
Custom FMIC
Microtec Ecu (soon to be upgraded to Autronic SM4 Standalone)
Direct Fire CDI (on hold)
Profec B Spec II
Apexi Turbo Timer (pending installment)
HKS forged pistons (coming soon)
HKS Camshaft (coming soon)
HKS Gasket (coming soon)
Delphi 380cc injectors
Custom Fuel Rail
Custom Return Line
Sard Fuel Pressue Reg
ETD torque damper (pending installment)
Spoon Radiator cap
Spoon oil cap
Mugen Resvoir Socks
Mugen Thermo Stat (pending installment)
Mugen Thermo Switch
Summit light weight engine pulley
K&N pod filter
K&N oil breather
K&N oil filter
Odessey Deep Cell Battery - now a DEKA light weight battery
With rear battery relocation
High Flow Cat
Custom B-pipe
Spoon Street Type Exhaust
just copied & pasted my engine list from another board...
  #44 (permalink)
Old 04-02-2008, 10:07 AM
Puertorican Jazz is an unknown quantity at this point
Yo!
Hey guys, um..I just turbocharged mine with a t03 Hybrid and I have no clue how much cc are the factory injectors, it's on 4psi and I'd like to know if I should change them (I'm planning on staying on 4) and if I should, which ones would work perfect on it?
__________________
T03 Powered Fit
  #45 (permalink)
Old 04-03-2008, 05:23 AM
03DSM-RSX's Avatar
Frequent FitFreak Poster
03DSM-RSX has a spectacular aura about03DSM-RSX has a spectacular aura about
wow....i've been totally out of the loop. So much has developed for the Fit!
Last time i was here, Kraftwerks barely came out as a name!
Nice setup NVM!
__________________
"Neg-rep'd by Claymore" Crew
03 DSM RSX Base Automatic-287whp/240wtq.....new build this summer
05 RS 1.0 TRD S/C tC - 283whp/200wtq 12psi + 35 dry shot
06 WDP TL A-Spec
07 VBP Fit Sport Auto-Totaled
07 WDP RDX w/ Technology Pkg
08 Vapor Metallic Saleen Mustang S281 3-Valve #25
08 Ford Expedition EL XLT
  #46 (permalink)
Old 04-20-2008, 07:17 AM
Quote:
Engine
L15A
HKS BoV
Custom FMIC
Profec B Spec II
Custom Fuel Rail
Custom Return Line
Spoon Radiator cap
Spoon oil cap
Mugen Resvoir Socks
Mugen Thermo Switch
K&N pod filter
K&N oil breather
K&N oil filter
High Flow Cat
Custom B-pipe
how soon are you getting these? if you have em what is whp now?
  #47 (permalink)
Old 04-20-2008, 11:44 AM
RDS RDS is offline
Senior Member
RDS will become famous soon enough
Integrated exhaust manifold on 09s + fabricated adapter = turbo manifold Mmmm...boost. Yum.
  #48 (permalink)
Old 05-13-2008, 11:45 PM
cmm cmm is offline
cmm is an unknown quantity at this point
Honda VF Turbo
I was thinking of something completely different, its a bit tricky thou, i have bought a RDX ecu to try to figure it out, i wanna frakin a VF turbo from a Honda RDX onto the fit. run like 6 psi all the time-no lag, or little due to the VF option the only thing that is trubbling me is the VF portion and how i get the little flutter valve to switch. Electronic switching is a possibility- tying it to a outside source, like for instance a relay to the vtec solenoid but, id like ti to be instinctive and simple, no new fangled wire/ cirit bords. ill have to do more resurch and get back to ya..
  #49 (permalink)
Old 05-13-2008, 11:47 PM
Zangoose GD3 Blue's Avatar
Zangoose GD3 Blue has much to be proud ofZangoose GD3 Blue has much to be proud ofZangoose GD3 Blue has much to be proud ofZangoose GD3 Blue has much to be proud ofZangoose GD3 Blue has much to be proud ofZangoose GD3 Blue has much to be proud ofZangoose GD3 Blue has much to be proud ofZangoose GD3 Blue has much to be proud ofZangoose GD3 Blue has much to be proud of
is this true...
are you serious bro...
__________________
07 Honda Fit sport 5Speed M/T aka New York JAZZ
Fit Motivation 101
Mods Installed--> soon to be HKS turbo powered
the fits are so underestimated...they r beasts in sheeps clothing~ anonymous
  #50 (permalink)
Old 06-16-2008, 03:15 PM
jamaicanfit's Avatar
jamaicanfit is an unknown quantity at this point
im running the HKS set up on my JDM Fit with e-manage blue on 5.8 psi and got 133whp, i mean its not a whole lot fast low down but on the highway it runs 190 km in no time
Reply
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
FIT/JAZZ Supercharging Open Discussion claymore Fit Forced Induction Forum 74 07-15-2008 01:44 AM
HKS Japan Turbo for 1st Gen Fit/Jazz 200psGD3 Fit Forced Induction Forum 19 02-17-2008 01:07 PM
T1R Turbo (Dyno'ed on pg.12) May 1st 2007 AJ PwR Jr. AJ-Racing.com 319 12-16-2007 08:45 AM
turbo question... kancerr Fit Forced Induction Forum 17 09-28-2007 04:54 AM
Civic Door door won't open linuxgeek1 Other Car Related Discussions 0 07-08-2005 12:34 AM
Go
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
