KraftWerks Supercharger Kit Info v2.1
Old 05-13-2008, 02:02 PM
REXXXXXXXXX's Avatar
Frequent FitFreak Poster
yes!!!
Originally Posted by FitSport2007_5spd
Does the Honda reflash kit come with injectors? I'm so confused now!!
LOOK AT THE SITE. you can get either the injector upgrade NOW, or the hondata upgrade in JUNE. Not both. The Hondata upgrade comes with the injector upgrade included. LOOK-
Included Items:
• Hondata/KraftWerks ECU Reflash
o Adjust Fuel
o Adjust Timing
o Revised VTEC
o Raised Rev Limit
o Removed Speed Governor
o Injector Compensation
o Closed Loop Fuel (Increase Fuel Efficiency)
• Flowed High-Output Injectors
• KraftWerks Plug and Play Connectors
• New Fuel Rail Studs and Spacers
  #242
Old 05-13-2008, 02:04 PM
are you by any chance OVER 10# or somewhere in between?
  #243
Old 05-13-2008, 02:05 PM
aliencowboy's Avatar
The Hondata kit comes with the upgrades injectors so you would not have to buy the injector kit separately, per the website. A savings of $400.
Who-Ho
  #244
Old 05-13-2008, 02:09 PM
JDMchris.com's Avatar
I run THIS
Who-Ho
Not only that but the Injectors are also bigger than the upgrade package.
  #245
Old 05-13-2008, 02:15 PM
SickFit's Avatar
Originally Posted by GAFIT
Some simple math tells me the high boost kit could be pretty expensive. $3500 base kit + $400 injectors + $1000 Hondata = $4900.
No dude, if you saw, the Hondata package brings the injector upgrade package in it if you noticed. So its 3500 + 1000.
  #246
Old 05-13-2008, 02:16 PM
SickFit's Avatar
OMG! Its a beautiful thing.
Chris, you know the CC on the injectors on that package?
  #247
Old 05-13-2008, 02:17 PM
OJRKraftWerks's Avatar
Former Vendor
The Hondata Reflash Package comes with different injectors. So take the 400 out on injectors
The Injector Upgrade Package and Hondata Reflash Package are not compatible with each other. We have both packages, so we can offer a choice for consumers on solutions.
-OJR
  #248
Old 05-13-2008, 02:18 PM
Included Items:
o Adjust Fuel
o Adjust Timing
o Revised VTEC
o Raised Rev Limit
Just got the answer above to my question. So, OSCAR, when in June is the Hondata going to be available. I just literally put my TIR header in this morning, so bad timing on my part!
  #249
Old 05-13-2008, 02:19 PM
xorbe's Avatar
looks like us californians get the supercard to stay carb happy, sigh...
  #250
Old 05-13-2008, 02:21 PM
I run THIS
So are we to assume that the only difference between the $399 injectors and the $999 kit is the Hondata ECU Reflash?
The reason I ask is that I just literally finished this morning installing my T1R header in anticipation for the base kit and injectors within the coming week. So, the next logical question is can I buy in June just the Hondata ECU Reflash if I buy the injectors this week?
Was stated that the injector upgrade for $399 and the $999 Hondata upgrade have DIFFERENT injectors. The ones with the Hondata kit have Bigger injectors. So no. you cant buy the Injectors then just buy the Hondata.
  #251
Old 05-13-2008, 02:23 PM
GAFIT's Avatar
That makes me feel a lot better...should have read more carefully. Keeping fingers crossed for a pre-order discount on the high boost kit
  #252
Old 05-13-2008, 02:26 PM
eldaino's Avatar
no. according to the site, the injectors that come with the hondata upgrade are DIFFERENT than the injector upgrade made for the supercard.
i just was just wondering if the hondata injectors are going to be the same ones used on the highboost kit, as that is supposed to be tuned with hondata instead of the supercard...chris any thoughts?
at any rate, for us base guys, we have 3 options now:
1.buy the base kit, stay carb legal
or add headers and exhaust and then chose from:
2. buying the base injector upgrade
or
3. buying the hondata upgrade that comes with even bigger injectors.
  #253
Old 05-13-2008, 02:30 PM
eldaino's Avatar
ha ha/\/\/\/\ could his question have been answered more times? lol.
  #254
Old 05-13-2008, 02:41 PM
I run THIS
OK so I was doing a MPG test on my car... I was doing extraordinarily well, then my GF drove it and killed it lol. I think I could've definitely hit close to 40. However I am glad to announce I was able to still achieve 30MPG! Now I am not at 5psi.... so just imagine.
  #255
Old 05-13-2008, 06:14 PM
Kuturagi's Avatar
I hope this kit helps with the low end a lot too, I know I see the torque gains over other options, but I want some more low end!!!
  #256
Old 05-13-2008, 06:41 PM
SickFit's Avatar
The Hondata will help out the low end.
  #257
Old 05-14-2008, 01:41 PM
bschook5's Avatar
Instructions are on the site now...
http://www.kraftwerksusa.com/product...structions.pdf
  #258
Old 05-14-2008, 01:47 PM
bschook5's Avatar
Looks like the Hondata reflash comes with 310cc Injectors according to the instructions, quite a bit bigger then the 205cc in the Injector package!!!
  #259
Old 05-14-2008, 02:07 PM
xorbe's Avatar
19 pages and 75 step and photos, I bet someone pulled an all-nighter or two getting that together... good job!
  #260
Old 05-14-2008, 02:42 PM
gotfitted's Avatar
i can't help but associate bigger injectors with a bigger bill at the gas pump
Quick Reply: KraftWerks Supercharger Kit Info v2.1
