Fit FREAK.net
Go Back   Honda FIT Forums > Fit Trix > Fit Forced Induction Forum
Discuss all Forced induction modifications for the Fit
Forum Sponsor: KraftWerks
Closed Thread
  #21 (permalink)
Old 04-20-2008, 01:39 AM
leonine's Avatar
leonine has a spectacular aura aboutleonine has a spectacular aura about
Quote:
Originally Posted by KraftWerks View Post
KraftWerks Fit Supercharger Kits
General KraftWerks Kit Information:
-Automatic Fits will be able to get the Base kit.
care to elaborate on this? are you saying that a/t fit's can not handle the upgraded injector package? please shed some light on this Oscar because there are alot of a/t owners that already have headers/test pipes and that would mean they would have to remove them in order to get the carb kit. 3 thousand dollars is an awful lot of money to spend for 25 - 30 hp with no hope for additional power.
what brought you to this conclusion if this is true. again specifics please as it seems like this was slipped in here without any supporting info.
  #22 (permalink)
Old 04-20-2008, 11:28 AM
Stevens24's Avatar
Stevens24 will become famous soon enough
Considering this in the section describing both base and High boost. It may just mean that AT cannot run the 10lb kit once it is available. I say that becuase it comes a couple lines after he says a base and High boost kit are available, AT can run the base kit.
  #23 (permalink)
Old 04-20-2008, 11:31 AM
Stevens24's Avatar
Oscar how much HP loss is expected at altitude compared to normal loss? Obviously it is relative I am just wondering if you lose a higher percentage with the kit than just with a stock motor?
  #24 (permalink)
Old 04-20-2008, 01:06 PM
JDMchris.com's Avatar
Administrator
JDMchris.com relies on Rep Points to liveJDMchris.com relies on Rep Points to liveJDMchris.com relies on Rep Points to liveJDMchris.com relies on Rep Points to liveJDMchris.com relies on Rep Points to liveJDMchris.com relies on Rep Points to liveJDMchris.com relies on Rep Points to liveJDMchris.com relies on Rep Points to liveJDMchris.com relies on Rep Points to liveJDMchris.com relies on Rep Points to liveJDMchris.com relies on Rep Points to live
Quote:
Originally Posted by SD_MR_FIT View Post
im looking into the 10psi kit now. i had the money to order the 5psi kit, but in the end i will be looking for more power, so i decided to wait for the 10psi kit.
can you give us a dyno on your 10psi kit? itll give us more of a reality check, and gives us basically on an idea on what our fit is capable of.
i really just want to shoot for 180whp. thats my goal for the stock motor, i know its possible....but with stock internals i do not know.
If he had the 10psi dyno it would be posted already. That information is going to be released soon tho.
__________________
KillerFit #8)
AIM: JDMCHRISDOTCOM
07 TW KWSC'd
08 SSM Daily
Yes I have 2 Fits!
KRAFTWERKS Kit Owner #1
Can't wear skinny jeans cuz my nuts don't fit
EPIC BUILD
No hassle 09 Fits at a Discount- PM me
  #25 (permalink)
Old 04-20-2008, 02:52 PM
jscooter is an unknown quantity at this point
Quote:
we are just as excited/impatient as the last crew that wanted to know about the 5psi kit but this one is more for the ones that wanna get EVERYTHING we can out of that lil motor...lol
but i got a quesiton for you (nooB one)
do you have BOV that you can hear when you shift? if not would have ing one make the car breath better and give you more hp?
  #26 (permalink)
Old 04-20-2008, 03:16 PM
Administrator
as stated before, The kit comes with a Bypass valve, so you will have the pshhh sound
__________________
KillerFit #8)
AIM: JDMCHRISDOTCOM
07 TW KWSC'd
08 SSM Daily
Yes I have 2 Fits!
EPIC BUILD
  #27 (permalink)
Old 04-20-2008, 03:48 PM
ldweng is an unknown quantity at this point
Premium is 93 Octane around here. I tend to use Top Tier gasoline, but there is a lot of cheaper gas around with 10% ethanol. Is there any problem burning it occasionally with 5# of boost?
__________________
2007 Silver Base MT
HFP 16x6.5 wheels 205/45-16 P Zero Nero
HFP Axle Back
Progress Rear Sway Bar
aFe Drop In Air Filter
HFit Short Shift Kit
T1R Header
T1R Mid Pipe
Soon - Fit - Forced induction technology
  #28 (permalink)
Old 04-20-2008, 07:32 PM
Illusive's Avatar
Administrator
Illusive is a splendid one to beholdIllusive is a splendid one to beholdIllusive is a splendid one to beholdIllusive is a splendid one to beholdIllusive is a splendid one to beholdIllusive is a splendid one to beholdIllusive is a splendid one to behold
Now that the pre-sale has ended, when can we expect these kits to begin shipping? I need to know if this will arrive in time for me to install before our only show of the year on May 24th!
__________________
Mugen - T1R - J's Racing - Spoon
Fitfreak.net Admin! Fear the PINK WRATH! =)
Got a question? I might have an answer, drop me a PM if you need help!
- KillerFit #10 -
KRAFTWERKS Kit Owner #5
  #29 (permalink)
Old 04-21-2008, 02:39 AM
03DSM-RSX's Avatar
Frequent FitFreak Poster
03DSM-RSX has a spectacular aura about03DSM-RSX has a spectacular aura about
I understand the use of the Powercard/Supercard for CARB purposes, but i still do not believe its the best method for the non-CARB applications. As its similar, from what i'm reading so far about it, to Comptech's Black box, JR's Powercard, Cybernation's Guardian E.I., TRD's black box, etc. All did not give the optimum performance, and yet promised all the same stuff like the Supercard is promising.
Are there tunable solutions for the setups? ie. Greddy Emanage Ultimate? Or perhaps attach the EMU in conjunction with the Supercard? Was there an attempt at getting Hondata to help with just reflashing the ECU with the tune instead of just piggybacking a box? Sure, the Supercard will work, esp on your test cars, but just wondering if there are other methods out there.
Also, 10psi on stock MAP. I'm assuming the Fit uses the same MAP as most other Honda's. 10-11psi is usually the limit where the sensors stop reading accurately. its borderlining for comfort personally, as if there is a slight chance to run higher boost than actually is read, ECM wouldn't know. I'm sure u already know that, but just also wondering if you should look into using the RDX's stock MAP sensor as a replacement or even Hondata's 4-bar sensor. Its more about getting the proper MAP reading and having a good margin in case you go over the specified boost level unintensionally.
Please enlighten me more of the engine management aspect of the L15 . A supercharger i tuned on was supposed to only run 11.5psi, but somehow came out to 13.5. luckily, we were using the Greddy Pressure sensor that reads up to 3 bars.
Can't wait to see these setups in action, i'm also watching your S2k setups as well. A friend of mine is really interested in doing it soon.
__________________
"Neg-rep'd by Claymore" Crew
03 DSM RSX Base Automatic-287whp/240wtq.....new build this summer
05 RS 1.0 TRD S/C tC - 283whp/200wtq 12psi + 35 dry shot
06 WDP TL A-Spec
07 VBP Fit Sport Auto-Totaled
07 WDP RDX w/ Technology Pkg
08 Vapor Metallic Saleen Mustang S281 3-Valve #25
08 Ford Expedition EL XLT
  #30 (permalink)
Old 04-21-2008, 11:54 AM
Mr_ET's Avatar
Honda Fit Forums Moderator
Mr_ET has much to be proud ofMr_ET has much to be proud ofMr_ET has much to be proud ofMr_ET has much to be proud ofMr_ET has much to be proud ofMr_ET has much to be proud ofMr_ET has much to be proud ofMr_ET has much to be proud ofMr_ET has much to be proud of
A stock Honda map sensor will stop reading at 12 psi so 10 psi should not cause any trouble at all.
It is my understanding that the supercard/powercard is only designed to modify fuel curves like an fmu would do. Is there any timing retard done?
If your timing is too far off you can detonate and blow the engine, if you go over 12 psi on a stock map your ecu will just put you in limp mode. I would be more worried about timing.
__________________
2008 VBP Fit LX M/T
3m clearbra
Keyless entry
Sport Spoiler
Zeta dead pedal
JDM centre console w/ armrest
  #31 (permalink)
Old 04-21-2008, 01:19 PM
StormSilverGD3's Avatar
StormSilverGD3 has a spectacular aura aboutStormSilverGD3 has a spectacular aura about
Quote:
Are we talking 12psi of additional pressure or 12psi period? atmospheric pressure is already approx. 14.7psi.
If your timing is too far off you can detonate and blow the engine.
Timing would be a concern of mine as well. However, on the flip side of that coin the Comptech kits just use their ESM box and an FMU and don't alter the ignition timing either.
__________________
The Fit is GO!
  #32 (permalink)
Old 04-21-2008, 01:24 PM
OJRKraftWerks's Avatar
Platinum Honda FIT Vendor
OJRKraftWerks has a spectacular aura aboutOJRKraftWerks has a spectacular aura aboutOJRKraftWerks has a spectacular aura about
Quote:
We will be working with Hondata on the High-Boost. We have not said we would be using the SuperCard on the High-Boost. The SuperCard is designed for low-boost applications, where a timing adjustment is not needed. The SuperCard does its job very well. Our software is proprietary to us, so I do not know how other companies have built their software. I recommend checking out the first post of this thread, and read up on the SuperCard.
Of course we understand the limitation of the Honda MAP sensor, and we build in a buffer. According to all of our continuous data logging, the MAP sensor is working with ease. We run 10 PSI with our Hondata Reflash on the S2000, and it runs VERY well.
If you run an inefficient supercharger too high, you will get erratic boost numbers. This is caused by the excess "boost" actually being hot air. The hotter the air gets, the more it expands. Roots superchargers do this, once you reach 9-10PSI.
-OJR
__________________
Oscar Jackson Jr.
KraftWerks Supercharger Systems
Forced Induction Forum Sponsor
Stay Boosted, My Friends
  #33 (permalink)
Old 04-21-2008, 01:39 PM
REXXXXXXXXX's Avatar
REXXXXXXXXX has a spectacular aura aboutREXXXXXXXXX has a spectacular aura about
Considering this is a 'Forced Induction' Forum, it's safe to say that we're talking about boost, not atmospheric pressure.
__________________
KRAFTWERKS Kit Owner #6
http://www.myspace.com/lickmydragonballz
私は粘土をもっと憎む
  #34 (permalink)
Old 04-21-2008, 02:30 PM
Kuturagi's Avatar
Kuturagi will become famous soon enough
If there is any chance of testing this kit with an Intake Mannifold, I know people have talked about it in Thread 2.0 but any ideas as to the results? And as far as loss of power like the 50hp lost from some exhaust parts on your S2K kit, do we need to steer away from anything on the fit that you know of yet? Thanks
__________________
Brand New: ASpec B-Pipe and 38/38/70 tint
  #35 (permalink)
xorbe's Avatar
xorbe is a jewel in the roughxorbe is a jewel in the roughxorbe is a jewel in the roughxorbe is a jewel in the rough
Quote:
I believe he is testing in California, and pretty much all we get is that ethanol watered-down gas, iirc.
  #36 (permalink)
Old 04-21-2008, 02:43 PM
Mr_ET's Avatar
The kit recommends 91 octane so anything more won't change anything.
Higher octane always helps reduce detonation but at 5psi and 121 whp 91 octane is fine.
The 12psi is above atmospheric pressure.
OJR great to hear that the high boost kit will have proper timing maps as well
__________________
2008 VBP Fit LX M/T
3m clearbra
Keyless entry
Sport Spoiler
Zeta dead pedal
  #37 (permalink)
Old 04-21-2008, 02:46 PM
bschook5 is an unknown quantity at this point
Getting close to the end of April
Still hoping it is going to ship in April!
  #38 (permalink)
Old 04-21-2008, 04:00 PM
-OJR
hell yeah!!!! *in arnold voice* more POWAH!!! (hopefully...lol)
  #39 (permalink)
Old 04-22-2008, 02:09 AM
03DSM-RSX's Avatar
-OJR
Thanks for the explanation!
Everyone should go the high boost setup F- low boost.
__________________
06 WDP TL A-Spec
  #40 (permalink)
Old 04-22-2008, 02:57 AM
Kamui's Avatar
Kamui will become famous soon enough
Will the Hi-boost upgrade allow the top speed limiter to be removed?
__________________
04/01/2008 Date I bought my baby
Mods:
6/25/08 /// Mugen Power Titanium Exhaust (Thanks Hocker)
More to come!!!
Closed Thread
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
KraftWerks Supercharger Kit Thread 2.0! OscarJr@JacksonRacing Fit Forced Induction Forum 414 04-18-2008 09:37 PM
KraftWerks Supercharger Pre-Order Ends 4/18! OJRKraftWerks FIT-Vendor Sponsored Group Buys and Sales 0 04-18-2008 06:12 PM
Doug Thorley Supercharger & Kraftwerks Supercharger Comparison Thread JDMchris.com Fit Forced Induction Forum 95 04-15-2008 01:56 PM
KraftWerks Supercharger Kits OscarJr@JacksonRacing Fit Forced Induction Forum 539 03-07-2008 01:55 PM
Mugen Fit Spec D SuperCharger release Info Dojo General Fit Talk 4 01-09-2006 11:30 PM
Go
