06-13-2008, 02:23 PM
I've had the JDM front end on since last year. So for all of you who have the JDM front end and put on the KWSC you will notice that the hood wont close. It doesn't close because the KWSC discharge pipe that runs above the intake manifold from the pulley side of the engine to the flywheel side has to large of a diameter (pipe with the KW logo on it). What I did to fix the problem is used an aluminum 1.75" diameter mandrel bent pipe to replace a section of the above pipe. Now everything works perfect. When I first put the KWSC on I was so pissed that the hood didn't close. I changed my oem hood to my cf hood and smashed it closed (in hope that the cf hood would bend). This really did bend the ___ out to the cf hood. The good thing is that it left marks on the discharge pipe so I knew exactly what the problem was.
I used a 1.75" pipe because the SC outlet is around 1.75" and the discharge pipes that lead from the SC to the mentioned above KW logo pipe is also 1.75" od. The KW logo pipe is around 2.5" od because the throttle body is around 2.5" od. By adding a couple of hose clamps, silicone hose for 1.75 od pipe, and the above 1.75 replacement pipe you'll be golden with the JDM front end.
Hope this helps.
Chris this hasn't been said by any one before but I wanted to say thank you for putting your car up as a mule. The KWSC is really the BEST FI kit on the market. I know that the introduction of this kit really depended upon your car. Thank you for giving up your car so that we all could benefit.
06-13-2008, 02:26 PM
Frequent FitFreak Poster
Quote:
Originally Posted by KraftWerks
You will never get a dyno to start at zero. That would mean the engine was not running.
Typical dyno centers start their runs at 15-20mph. It is how the tool is used.
-OJR
lololol nonono, not the data, just the whp axis label!
__________________
for sale soon: stock 15" sport rims - already sold: t1r header, 5 psi a/t kit, ur alt pulley
06-13-2008, 03:21 PM
Administrator
Hope this helps.
GOod deal Lance... I simply gutted my OEM hood to clear!
__________________
KillerFit #8)
AIM: JDMCHRISDOTCOM
07 TW KWSC'd
08 SSM Daily
Yes I have 2 Fits!
KRAFTWERKS Kit Owner #1
EPIC BUILD
SBIFG!
06-13-2008, 04:35 PM
Master FitFreaker
Quote:
Originally Posted by xorbe
I also notice that the AFR at the bottom of the chart is rising rapidly. I wonder what i/h/e + 195cc would do.
That AF is ok. Better to go with engine management for anything more than that IMO, the larger injectors are not needed.
__________________
100% Naturally Aspirated,Pure Performance
06-13-2008, 04:53 PM
thanks for the dynos! glad to see that the supercharger is still putting out signficantly more hp tq even over this. (compared it to the base map that's on kraftwerks site.)
__________________
i actually return rep!
You'll hunt me. You'll condemn me, you'll set the dogs on me. But that's what has to happen.
06-13-2008, 05:20 PM
It's really my pleasure to provide that type of information. I dynoed my car with J's header, J's test pipe, J's b pipe, J's muffler, and Last Station's power box. My header and test pipe are coated with Swian Techs "White Lightning." My dyno charts are very similar to Ben's dynos I posted (actually a couple higher). But because of the variance between dynos, humidity, blah, blah, blah. I just say they are similar to Ben's.
Before I purchased the KWSC I compared my charts to Kraftwerks. As eldaino mentioned, these charts really show the benefits of the the KWSC.
For those of you who have purchased full exhaust like me your one step closer to maxing out the sc when the options become available.
06-13-2008, 05:41 PM
so are you currently running this exhaust and header set-up with your kit? have you done any dyno runs with everything already on?
__________________
06-13-2008, 05:52 PM
No I'm not running the Header or test pipe. Even though I'm waiting anxiously for Tom's dynos (Mugen header, ? cat delete) I will most likely wait untill the Hondata comes out before re-installing them.
Sorry no dynos yet. I've only been up and running for two weeks and don't work as fast as Tom. In addition, I trust what KW dynos read. I will be interested in dynos in the future though.
06-13-2008, 06:03 PM
look forward to seeing them man, if all goes well, you should be feeling a significant improvement once you get it all on!
__________________
06-13-2008, 07:19 PM
Senior Member
Sorry about the delay on my updated dyno. Was helping Umiekun with swapping springs. Will defnitiely have updated dynos w/ A/F ratio by tomorrow.
Tom
06-15-2008, 07:12 PM
Did i just screw up?
im thinking about going FI with the kraftwerks supercharger maybe around christmas ...Did i just screw myself by buying the 50mm skunk2 catback instead of the 60mm??????
__________________
06-16-2008, 06:22 AM
Quote:
No you didnt.
06-16-2008, 01:34 PM
Can someone who has just the base kit w/out injector upgrade installed on a M/T Fit do a quick test and see what kinda 0-60 times you are getting?
Just trying to compare what im getting with my fit w/the base S/C kit installed.
Thanks.
06-16-2008, 02:27 PM
Quote:
There are so many variables... what temperature and humidity, what altitude, and how good is the driver, and with 1 foot of roll-out? I figured out this weekend that 63F (night) -> 99F (sunny afternoon) makes ~1.1s difference for my stock a/t! I was sort of disheartened that I may have a hard time quantifying my own mods to a reasonable degree.
__________________
06-16-2008, 03:43 PM
Quote:
Originally Posted by SickFit
No you didnt.
thanks....Am i looking at loosing overall gains due t0 smaller mm piping?, or is it a small small difference?
__________________
06-16-2008, 03:49 PM
