Fit FREAK.net
Go Back   Honda FIT Forums > Fit Trix > Fit Forced Induction Forum
Discuss all Forced induction modifications for the Fit
Forum Sponsor: KraftWerks
Reply
  #1 (permalink)
Old 08-28-2008, 08:56 PM
unclepowers is an unknown quantity at this point
L13A pistons in a L15A..
I am thinking about boosting..I want to know if the 1300 pistons will work in my L15A sport if needs be..
Sponsored Links
  #2 (permalink)
Old 08-28-2008, 11:46 PM
ghostfit will become famous soon enough
all l series engines have the same bore and cp. just different stroke. the l13 pistons won't lower compression. However if you do want to lower the cp. you could get a thicker head gasket Google cometic.
__________________
One day a group of soulmates figured out that you got to look behind the world of visible phenomenons to really find out things the others have not allready discovered.
  #3 (permalink)
Old 08-29-2008, 12:23 PM
underdog has a spectacular aura aboutunderdog has a spectacular aura about
I wouldn't reccomend running l13 pistons. they are from an 8v engine and the l15a is 16v so you may run into valve clearance issues.
__________________
2008 SSM Tanabe GF210 springs, Tanabe front strut bar, progress rear sway bar, Drag dr21's gunmetal, S2 short shifter & knob, Mishimoto intake, 8k hids, 4.3k fog's.
  #4 (permalink)
Old 08-29-2008, 05:11 PM
you would run into valve clearance issues if it was a domed piston. i believe the l series have flat top pistons.
__________________
  #5 (permalink)
Old 09-13-2008, 02:23 AM
L13 pistons in a L15
I wanted to know.I am planning to go boost.And i wanna get some "backup" pistons.I was getting some L13 pistons,just wanted to know if they could work.This is not like previous years when I boosted d15/16 then b16/18's.These parts (L-series) aren't exactly lying around where I am in Jamaica.
  #6 (permalink)
Old 10-05-2008, 05:32 AM
kylerwho's Avatar
kylerwho should get some awardskylerwho should get some awardskylerwho should get some awardskylerwho should get some awardskylerwho should get some awardskylerwho should get some awardskylerwho should get some awardskylerwho should get some awardskylerwho should get some awardskylerwho should get some awardskylerwho should get some awards
just put two head gaskets on to lower compression.
__________________
  #7 (permalink)
Old 10-05-2008, 12:57 PM
Quote:
NOOOoo! that increases the piston to head clearance which reduces quench which could lead to detonation alot easier than just leaving it alone and spend more money on a professional tuner. there are several people out there that run high compression + boost with great results. look at all the boosted type R guys. they make the same hp as gsr's with typically 3-5 less psi and have a fatter power band.
its not always about lowering static compression. its about lowering dynamic compression! ie. cam timing, ignition timing, reducing backpressure(too small exhaust, turbine, ect....)free'er flowing systems will need less ignition timing to make the same power, thus reducing the chance of detonation but usually comes at a price. a little less boost response. however there are ways around that as well....twin scroll!!!
I will give you that lower compression gives you a buffer for mistakes. but the only way to do it right is custom pistons, or find a piston that works from another boosted engine with 73mm pistons 4 valves per cyl with same valve arangement. good luck.
__________________
  #8 (permalink)
Old 10-05-2008, 01:39 PM
kylerwho's Avatar
you missed my winking face. that was a huge joke. Seems like a logical answer but it has some real bad effects.
__________________
Reply
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Pistons and turbo kit Starfox3 Fit JDM Tuning, Engine Modifications and Swaps 5 08-14-2008 07:32 PM
L13A Turbo? zfr846 Fit Forced Induction Forum 12 06-21-2008 04:06 PM
where to buy jdm L15a vtec ? vbo Fit JDM Tuning, Engine Modifications and Swaps 1 10-25-2007 04:53 AM
oversized pistons azkikersfit Fit JDM Tuning, Engine Modifications and Swaps 1 07-24-2007 08:00 PM
Anyone TurboCharge your L15A CVT yangjiesheng Fit Forced Induction Forum 32 04-25-2007 12:27 AM
Go
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
