Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > Fit Trix > Fit Forced Induction Forum
Discuss all Forced induction modifications for the Fit
Forum Sponsor: KraftWerks
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #21 (permalink)
Old 04-08-2009, 01:14 AM
explosivpotato's Avatar
explosivpotato relies on Rep Points to liveexplosivpotato relies on Rep Points to liveexplosivpotato relies on Rep Points to liveexplosivpotato relies on Rep Points to liveexplosivpotato relies on Rep Points to liveexplosivpotato relies on Rep Points to liveexplosivpotato relies on Rep Points to liveexplosivpotato relies on Rep Points to liveexplosivpotato relies on Rep Points to liveexplosivpotato relies on Rep Points to liveexplosivpotato relies on Rep Points to live
While I'm sorry to see a fitfreaker leave the FI community, I'm just as glad to see a new member! Leonine's link is very good, and the AEM Power forums are very useful for info on the F/IC. I also have a guide on this forum that I wrote up with the help of some other forum members. It's a thread in this forum, titled something like "how to tune the Greddy Emanage". It's more Emanage-specific, but the principles and math are all the same. My advice would be to lurk some more, download the FIC software (FREE!) and play around with it.
If you have any questions, feel free to pm me, or make a post about it. We're all here to learn as much as we can.
__________________
'07 MR Fit Sport MT
T1R Turbo kit, 6psi
AEM F/IC tuned by yours truly!
155hp, 157.1 Ft-Lb
,___,
[O.o]
/)__)
-"--"- ORLY??
Need tuning or troubleshooting assistance?
PM ME!
  #22 (permalink)
Old 04-08-2009, 05:27 PM
CamFit relies on Rep Points to liveCamFit relies on Rep Points to liveCamFit relies on Rep Points to liveCamFit relies on Rep Points to liveCamFit relies on Rep Points to liveCamFit relies on Rep Points to liveCamFit relies on Rep Points to liveCamFit relies on Rep Points to liveCamFit relies on Rep Points to liveCamFit relies on Rep Points to liveCamFit relies on Rep Points to live
Thanks a bunch for pointing me in the right direction, just got home from work and it seems I have much reading to do.
thanks for your time
  #23 (permalink)
Old 04-08-2009, 06:01 PM
friend called, wants a hand installing AEM water meth kit.
ie..... large triple triple and reading instructions... sounds intersting.. It can hook up to the ecu retard timing/ boost when water/meth runs low...
might be yet another thing to look into.. mabe i will post my findings in the water meth thread.. more reaserch and more coffie... yum
  #24 (permalink)
Old 04-09-2009, 09:01 PM
Spooling relies on Rep Points to liveSpooling relies on Rep Points to liveSpooling relies on Rep Points to liveSpooling relies on Rep Points to liveSpooling relies on Rep Points to liveSpooling relies on Rep Points to liveSpooling relies on Rep Points to liveSpooling relies on Rep Points to liveSpooling relies on Rep Points to liveSpooling relies on Rep Points to liveSpooling relies on Rep Points to live
why does this F/IC thing comes with vacuum hose? so you can feed vacuum directly to F/IC? to read boost??
im thinking of getting the AEM F/IC package. sounds like its a workable platform.
__________________
  #25 (permalink)
Old 04-09-2009, 10:27 PM
leonine's Avatar
leonine relies on Rep Points to liveleonine relies on Rep Points to liveleonine relies on Rep Points to liveleonine relies on Rep Points to liveleonine relies on Rep Points to liveleonine relies on Rep Points to liveleonine relies on Rep Points to liveleonine relies on Rep Points to liveleonine relies on Rep Points to liveleonine relies on Rep Points to liveleonine relies on Rep Points to live
correct. it reads pressure up to 35 psia i believe.
  #26 (permalink)
Old 04-10-2009, 01:07 AM
quangalang's Avatar
quangalang relies on Rep Points to livequangalang relies on Rep Points to livequangalang relies on Rep Points to livequangalang relies on Rep Points to livequangalang relies on Rep Points to livequangalang relies on Rep Points to livequangalang relies on Rep Points to livequangalang relies on Rep Points to livequangalang relies on Rep Points to livequangalang relies on Rep Points to livequangalang relies on Rep Points to live
no just to read boost but it is a built in map sensor and that's how you build your fuel/ignition maps
__________________
I DO NOT rep unless you deserve it.
OBAMA- so far 2 months of failure...
I VOTED:
McCain/ Palin
YES on 8!
  #27 (permalink)
Old 04-10-2009, 02:35 AM
Quote:
how come the emanage doesn't have to use an external map sensor?
__________________
  #28 (permalink)
Old 04-10-2009, 03:48 AM
quangalang's Avatar
Correct me if im wrong, but i think the emanage uses the stock map sensor, i think that's why people got the CEL's for it.
F/IC can cap the maximum voltage that the stock ecu will receive thus the stock ecu will never read positive boost.
__________________
I VOTED:
McCain/ Palin
YES on 8!
  #29 (permalink)
Old 04-11-2009, 09:22 PM
equiptcustoms is an unknown quantity at this point
I also bought the aem fic 6 30910. id like to know how you connected the map sensor, because the installation guide states that it has maf connection or both maf and map connection.. can i use the maf connection to the map or connect the analog a/b to the map..??? thank you hope someone can help me wire the aem.
turbo fit l15a
thank you
  #30 (permalink)
Old 04-11-2009, 09:32 PM
leonine's Avatar
Quote:
turbo fit l15a
thank you
if you are not going to get the boomslang harness (dont see why you would want to wire it up yourself but thats just me) then you would intercept the red/green wire on connector A pin 30 with the 2 MAF wires.
Then run the vacuum line through the firewall. 1 side connects to the AEM the other tee into the vacuum line for the pcv.
On the setup screen for MAF input select MAP and enter 2.9 volts to clamp (exactly 14.8). The you can tune your fuel and ignition maps based on the AEM's map sensor/rpm while clamping the stock one so the ecu never sees boost.
  #31 (permalink)
Old 04-11-2009, 09:47 PM
thank you very much for the guide sir.
  #32 (permalink)
Old 04-11-2009, 10:07 PM
leonine's Avatar
no problem. make sure you are using the latest version of the software (3.04) and that you calibrate the rpms/tps before you begin.
EDIT: just saw you were in China. Not sure if the ecu pinouts differ for the JDM/EDM versions so double-check.
  #33 (permalink)
Old 04-13-2009, 05:13 PM
quangalang's Avatar
Which wire is the O2 wire that i need to tap into?
can someone check for me?
__________________
I VOTED:
McCain/ Palin
YES on 8!
  #34 (permalink)
Old 04-13-2009, 05:45 PM
leonine's Avatar
A31 i believe but i will double check when i get home in a couple of hours. My service manual has more detailed pinout explanations.
  #35 (permalink)
Old 04-13-2009, 07:27 PM
quangalang's Avatar
Quote:
yeah im pretty sure it's A31 also, can you please confirm when you have time please?
thanks
__________________
I VOTED:
McCain/ Palin
YES on 8!
  #36 (permalink)
Old 04-13-2009, 08:00 PM
A31 sounds plausible, AFS+ seems like it would be Air/Fuel signal Pos.
If leonine can't find it in his shop manual I'll go pull my boomslang harness out from under my glovebox and have a look-see.
__________________
'07 MR Fit Sport MT
T1R Turbo kit, 6psi
155hp, 157.1 Ft-Lb
,___,
[O.o]
/)__)
-"--"- ORLY??
PM ME!
  #37 (permalink)
Old 04-13-2009, 08:05 PM
leonine's Avatar
A31 is correct.
Hey potato you still using that same map you sent me or have you made changes?
  #38 (permalink)
Old 04-13-2009, 08:10 PM
I've made a bunch of changes, mostly to the O2 map, and a little to the fuel map.
I also richened up my idle a hair (to 14.3) to smooth out the idle. I need to adjust my valves, I think. I'm gonna do that this weekend.
Do you wanna see my new map? I'd be glad to email it to you.
__________________
'07 MR Fit Sport MT
T1R Turbo kit, 6psi
155hp, 157.1 Ft-Lb
,___,
[O.o]
/)__)
-"--"- ORLY??
PM ME!
  #39 (permalink)
Old 04-13-2009, 08:46 PM
leonine's Avatar
yes please i would appreciate it. Have you gotten any MIL's with the new map or is it pretty stable. I adjusted my valves this past weekend. Made a big difference at idle and low rpms. They were way off.
  #40 (permalink)
Old 04-13-2009, 10:16 PM
quangalang's Avatar
cool! rep to leonine!
and potato, you got PM.
__________________
I VOTED:
McCain/ Palin
YES on 8!
Reply
Tags
02, 304, aem, boomslang, connection, emanage, fic, find, harness, racingimporter, review, reviews, sensor, skew, uego, version
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Buffer Splatter Prevent this Messy Time Waster phil@detailersdomain Fit Care 0 03-18-2009 07:45 PM
Fit review on CNET - they get fooled by trip computer! DZeckhausen 2nd Generation (GE 08-present) 1 10-26-2008 12:22 PM
dealer-installed remote starter: dealer issues?! Funchy General Fit Talk 14 08-29-2008 11:15 PM
FIT Yahoo Autos Reviews alclssus2020 General Fit Talk 43 07-12-2007 04:07 AM
Product Review - Duplicolor Caliper/ Drum paint avosfit Fit Shoes 9 08-01-2006 12:31 AM
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
