Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > Fit Trix > Fit Forced Induction Forum
Discuss all Forced induction modifications for the Fit
Forum Sponsor: KraftWerks
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #21 (permalink)
Old 06-01-2009, 07:14 PM
Spooling relies on Rep Points to liveSpooling relies on Rep Points to liveSpooling relies on Rep Points to liveSpooling relies on Rep Points to liveSpooling relies on Rep Points to liveSpooling relies on Rep Points to liveSpooling relies on Rep Points to liveSpooling relies on Rep Points to liveSpooling relies on Rep Points to liveSpooling relies on Rep Points to liveSpooling relies on Rep Points to live
Quote:
Originally Posted by 1990hondahf View Post
Does the F-CON IS cause the same closed loop problem as the e-mange?
all piggybacks alike can certainly influence the close loop AFR to a certain degree but not overcome it
  #22 (permalink)
Old 06-02-2009, 02:00 AM
explosivpotato's Avatar
explosivpotato relies on Rep Points to liveexplosivpotato relies on Rep Points to liveexplosivpotato relies on Rep Points to liveexplosivpotato relies on Rep Points to liveexplosivpotato relies on Rep Points to liveexplosivpotato relies on Rep Points to liveexplosivpotato relies on Rep Points to liveexplosivpotato relies on Rep Points to liveexplosivpotato relies on Rep Points to liveexplosivpotato relies on Rep Points to liveexplosivpotato relies on Rep Points to live
That's not true. The Greddy Emanage Ultimate can NOT in ANY WAY change the AFR your ECU shoots for in closed loop. The AEM F/IC has COMPLETE control over the target AFR in closed loop.
I do not know about the F-Con, as the tuning software and details are only available to authorized dealer$.
__________________
'07 MR Fit Sport MT
T1R Turbo kit, 6psi
AEM F/IC tuned by yours truly!
155hp, 157.1 Ft-Lb
,___,
[O.o]
/)__)
-"--"- ORLY??
Need tuning or troubleshooting assistance?
PM ME!
  #23 (permalink)
Old 06-02-2009, 03:00 AM
"Target AFR" does not = complete control.
The F-CON iS's AFR is 12-14 in boost then jumps back to 14.7 to 15.2 or higher in idle.
  #24 (permalink)
Old 06-02-2009, 03:05 AM
1990hondahf's Avatar
1990hondahf relies on Rep Points to live1990hondahf relies on Rep Points to live1990hondahf relies on Rep Points to live1990hondahf relies on Rep Points to live1990hondahf relies on Rep Points to live1990hondahf relies on Rep Points to live1990hondahf relies on Rep Points to live1990hondahf relies on Rep Points to live1990hondahf relies on Rep Points to live1990hondahf relies on Rep Points to live1990hondahf relies on Rep Points to live
What about the AEM allows it to overcome closed loop? Is it the way it is wired in? Something else?
  #25 (permalink)
Old 06-02-2009, 10:34 AM
The AEM F/IC taps into the Nernst Cell line on the stock LAF (lean air-fuel) sensor. Since the stock sensor is current based, the AEM is able to alter its feedback to the ECU by injecting / shunting current from the circuit.
When I said complete control, I meant that you can adjust the target Air:Fuel ratio to whatever you want at any load / RPM breakpoint. The Emanage Ultimate cannot do this as far as I know, and the HKS may or may not be able to do this. The AFRs seen on stock HKS kits at WOT have nothing to do with wether or not they can control closed loop. The way to know that is to see what the AFR does while rolling onto the gas at LESS than full throttle while entering boost. If the AFR drops below 15.0:1 consistently and smoothly, it can control closed loop. If it stays up in the stoich range, then it can't / they haven't implemented it in the stock tune.
__________________
'07 MR Fit Sport MT
T1R Turbo kit, 6psi
155hp, 157.1 Ft-Lb
,___,
[O.o]
/)__)
-"--"- ORLY??
PM ME!
Reply
Tags
10, 2008, 2009, complete, extreme, fic, fit, hks, honda, kit, kits, lbs, r18, supercharger, turbo
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GREDDY TURBO KIT GD3 First Released Kit sdPANNfit For Sale / Want To Buy / Classified Ads for USED Fit Items 18 06-26-2009 11:27 AM
greddy posted 07-08 fit turbo kit on their site with a price!! F'it_ImFromTx Fit Forced Induction Forum 10 05-08-2009 08:21 PM
NIGHTHAWKSI's custom turbo build progress thread NIGHTHAWKSI Fit Forced Induction Forum 274 05-04-2009 11:17 AM
FS: Complete T1R Turbo Kit with option stage upgrades!!! YeeFit For Sale - Local Pickup Only 1 04-02-2009 02:47 AM
does anyone know if greddy makes a turbo timer wiring harness kelsodeez Fit Forced Induction Forum 4 05-18-2008 10:40 PM
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
