Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > Fit Trix > Fit Forced Induction Forum
Discuss all Forced induction modifications for the Fit
Forum Sponsor: KraftWerks
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #1 (permalink)
Old 10-18-2009, 05:21 AM
1990hondahf's Avatar
1990hondahf relies on Rep Points to live1990hondahf relies on Rep Points to live1990hondahf relies on Rep Points to live1990hondahf relies on Rep Points to live1990hondahf relies on Rep Points to live1990hondahf relies on Rep Points to live1990hondahf relies on Rep Points to live1990hondahf relies on Rep Points to live1990hondahf relies on Rep Points to live1990hondahf relies on Rep Points to live1990hondahf relies on Rep Points to live
Lets talk abour A/F ratio
What are you guys running for you A/F ratios at:
  1. idle
  2. light boost
  3. full boost
4 something in the morning and just got everything installed...too late to take her out....I have my laptop and a FIC ready in the morning....just need some help from you guys so I don't blow up my ride!
__________________
2008 SSM Fit Sport
2008 Accord (5 speed)
1990 CRX/GSR Turbo
FS: $4500...
http://s148.photobucket.com/albums/s4/1990hondahf/
Sponsored Links
  #2 (permalink)
Old 10-18-2009, 09:00 AM
dewthedew's Avatar
Fit Moderator
dewthedew relies on Rep Points to livedewthedew relies on Rep Points to livedewthedew relies on Rep Points to livedewthedew relies on Rep Points to livedewthedew relies on Rep Points to livedewthedew relies on Rep Points to livedewthedew relies on Rep Points to livedewthedew relies on Rep Points to livedewthedew relies on Rep Points to livedewthedew relies on Rep Points to livedewthedew relies on Rep Points to live
Send a message via AIM to dewthedew
13-15.x idle
10-17partial throttle
13 light boost
12.9 wot and now 11/10 in 3rd between 5-6500
I need a tune!I'll post after tune numbers lol
  #3 (permalink)
Old 10-19-2009, 12:58 PM
explosivpotato's Avatar
explosivpotato relies on Rep Points to liveexplosivpotato relies on Rep Points to liveexplosivpotato relies on Rep Points to liveexplosivpotato relies on Rep Points to liveexplosivpotato relies on Rep Points to liveexplosivpotato relies on Rep Points to liveexplosivpotato relies on Rep Points to liveexplosivpotato relies on Rep Points to liveexplosivpotato relies on Rep Points to liveexplosivpotato relies on Rep Points to liveexplosivpotato relies on Rep Points to live
Your AF ratio should depend on manifold pressure more than anything else. The fit uses a wideband, and the FIC can control it very well, so your AF ratios should be dead nuts as follows:
Idle / cruising (anything below 5-7" of vacuum) - 14.7-15.0 (I have mine running 15.0 for a hair better gas mileage)
Transition to boost (anything between 5" and 0) - AFR should smoothly ramp down to ~13 - 13.5 at 0 vacuum
In boost (anything above 1psi) - you should be running in the low to mid 12's.
Ignition is another story, I'm running a .68 degree/lb of boost step retard, with additional timing pulled in low RPM boost as this area tends to be a tricky one.
__________________
'07 MR Fit Sport MT
T1R Turbo kit, 6psi
AEM F/IC tuned by yours truly!
155hp, 157.1 Ft-Lb
,___,
[O.o]
/)__)
-"--"- ORLY??
Need tuning or troubleshooting assistance?
PM ME!
Reply
Tags
af, forced, induction
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oil life indicator: Interesting bit from Car Talk adouglas Fit DIY: Repair & Maintenance 3 12-08-2007 01:49 PM
Honda Fit in Car Talk Cat General Fit Talk 1 11-06-2007 09:32 AM
Rolling Start -- Fit on Car Talk FondaFit Other Car Related Discussions 19 05-13-2007 06:05 AM
Does anyone know the gear ratio of 7 speed mode? Kostas General Fit Talk 7 05-13-2006 02:39 PM
N.A. Fit Speed:RPM's ratio? CarDemon General Fit Talk 1 02-19-2006 05:20 PM
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
