New member
Old 02-28-2016, 01:25 PM
BeaverMeat's Avatar
New member
Hi
In the process of purchasing a 2008 Fit Sport 5-speed with only 90,000k (56,000 miles). So I'm looking for a forum to help with my planned modifications.
Nothing too crazy. Just a LSD (for winter driving) and while I'm doing that a flywheel and possibly a clutch with lighter rotational mass. Also a rear disc brake conversation is of interest. Rims (obvoisly). As for power... Just some bolt-on parts to help it breath and fart
Old 03-01-2016, 01:49 AM
gallent92's Avatar
There are lots of good ideas and inspiration on looks around, you are on the right place. Welcome
Old 03-01-2016, 01:57 AM
Hootie's Avatar
Hello and welcome to the forum!
The rear disc conversion is actually a pretty good modification. It opens the door wide open for various pad friction materials and rotor selection.
I personally recently did the EP3 Si rear disc conversion and its actually a fairly easy swap if you are comfortable with turning a wrench.
Old 03-02-2016, 01:56 PM
lunch box's Avatar
At risk of thread-jacking, is the EP3 rear-disc swap specific to the GD8? Or will many of the parts work for my GE8?
Beaver, from one newb to another, welcome. Your mod wish list looks like mine, plus a different shifter.
Old 03-02-2016, 02:09 PM
Hootie's Avatar
Originally Posted by lunch box
At risk of thread-jacking, is the EP3 rear-disc swap specific to the GD8? Or will many of the parts work for my GE8.
You MIGHT be able... but don't hold me to it.
The reason being is that you will need to remove the drum assembly, install a Scarebird conversion bracket, and reassemble accordingly off of that. You WILL have to be careful of damaging the spindle because it is NOT replaceable like the GD3 (you will have to get a new rear axle if threads cannot be repaired).
In addition to that, I've heard that the GE8 is longer than the GD3 so you may need a different parking brake cable... Even if the cables were the same length, the EP3 cables are not plug and play so they will need to persuasion and have brackets bent/relocated.
Old 03-02-2016, 02:25 PM
lunch box's Avatar
Thank you. That's really helpful.
dasdavid
04-04-2017 01:47 PM
onebigbagostupid
03-26-2012 01:43 PM
Brian Rubin
06-29-2010 06:10 PM
Solscud007
09-20-2007 12:14 AM
Fit sport
04-25-2007 10:15 PM
Quick Reply: New member
