Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > Fit Trix > Fit I.C.E.
Fit I.C.E. Threads discussing in-car electronics including audio, video, security, and navigation systems for the Honda Fit/Jazz
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #21 (permalink)
Old 07-02-2007, 04:23 PM
tgreaves is an unknown quantity at this point
Quote:
Originally Posted by kurtneis View Post
anybody have sirius sportster radio hooked up in their fit? I have the sportster from sirius and wonder if there is a bracket or anything that will mount the unit down by the aux jack and power?!!!
I mounted mine on to the left front window, the little "vent" window in the corner of the dash.. I need to run the wires but im going to run then down along side the dash so that they can hardly be seen..
  #22 (permalink)
Old 07-03-2007, 10:36 AM
I finished hooking up the sirius unit lastnight and I tried plugging my ipod cable into the sirius unit and the other end into the AUX port...WOW, what a difference.. It sounds better than even the antenna wire relay does..
  #23 (permalink)
Old 08-03-2007, 11:21 PM
5thstreet's Avatar
5thstreet is an unknown quantity at this point
Quote:
Me three. I have a sportster reply and mounted it in that spot with the suction cup mount. I have the antenna on the dash up by the windsheild. Very easy. The reception would have to be pretty poor in order for me to go through the work ro put it on the roof. I'm lazy.
  #24 (permalink)
Old 08-09-2007, 12:36 PM
Charmy is just really niceCharmy is just really niceCharmy is just really niceCharmy is just really niceCharmy is just really nice
Send a message via AIM to Charmy
sirius
I bought a plastic contraption that can stick on the dash with adhesive or clip onto the A/c vents. It can hold an ipod, a cell phone, or pretty much whatever you want it to hold. So, I'm planning on buying the Sirius Stiletto 10 and just using the Aux to play it through the cars speakers.
  #25 (permalink)
Old 08-29-2007, 03:44 PM
5thstreet's Avatar
Weird problem
Anybody else have weird interaction b/w Sirius reception strength and fan blower speed?
If I turn the blower up to "4" I lose signal strength?
My antenna is mounted on the center of the dash.
__________________
2007 Milano Red Sport AT
All season floor mats
Cargo tray
Sirius Stiletto 100
Khumo Ecsta LX Platinum tires/Snow tires in winter
K&N drop in air filter
Thule roof rack
Draw-Tite hitch
Quicksilver 6.0 ultra-light camper
  #26 (permalink)
Old 11-20-2007, 11:12 PM
jman245's Avatar
jman245 is an unknown quantity at this point
i am getting the stiletto 10 as well,do i only need to plug it in the aux port to make it play out the car speakers? do i need the car kit as well? please lmk
  #27 (permalink)
Old 12-04-2007, 01:16 AM
"G" "G" is offline
"G" is an unknown quantity at this point
Is their a such thing as an adapter that plugs in to the cd changer input on the sport ? I know they are made for other cars.
  #28 (permalink)
Old 01-20-2008, 04:23 PM
"G" "G" is offline
Found one! PA11HON2Y Honda auxiliary input and iPod adapter;
  #29 (permalink)
Old 01-20-2008, 10:51 PM
Lyshk0's Avatar
Lyshk0 is on a distinguished road
Send a message via AIM to Lyshk0
Quote:
Originally Posted by radareclipse View Post
This mounts on the left side A-pillar in seconds. Then screw the Sirius mount to it and route your wires.
ProClip Mounting System *-*Choose Your Country
this wasn't out when i got sirius, so i had to install it in the pop-out panel for the fuse panel (lower right). i'll get pix up tmw prolly.
__________________
  #30 (permalink)
Old 05-22-2008, 10:36 PM
Patrick@SCP is an unknown quantity at this point
Sirius
I have my Stiletto 100 mounted using a Pro-Fit bracket called the "Ultimount" that uses an adhesive pad that sticks to the chassis and a rotating head that locks into your desired position. I'll post a pic as soon as I remember to take one. The windshield is so huge on the Fit that I just used some double-sided tape to the dashboard and ran the wire along the front of the dash where the windshield meets the board and underneath the dash and am using the Aux-in. I have absolutely no problems with reception and sound quality between FM-mod and Aux-in are night and day. While it's not the most stealthy of installs it does keep the antenna off the body so it's not as unsightly and there's no risk of damaging the paint (I had the antenna on the trunk of my Saab for 2 years and I managed to scuff the area where it was stuck pretty badly).
Pro Fit UltiMount - Universal Mounts
  #31 (permalink)
Old 06-03-2008, 11:09 PM
rocksnap is an unknown quantity at this point
sirius antenna
Holy cowabunga! I was just looking at the above antenna routing that the guy put in thru by removing the side panel and spare tire area! I just routed mine up the center mirror into the headliner, across to the drivers side, then all the way down the left side. Tucks nicely, and quickly, into the headliner, including the rear hatch trim. I do have a very small bit of antenna wire exposed at the hatch but that is only seen when the hatch is opened. Most people would not even notice! I give the guy credit for going thru all that time and trouble but...
I have three wired coming off my Sirius head unit. Power, antenna and line out to my aux input. All those get routed up the center mirror. They are even held in by the rubber (mirror to windshield) support, against the mirror arm. All out of sight.
If you want to spend all that time taking the interior apart that is your call. I will be off starting my third beer while you are still putting your car apart!
Reply
Tags
2006, accord, adapter, antenna, dealer, direct, factory, fit, fm, honda, install, mounted, radio, roof, sirius, stiletto
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
2003 Accord Radio Display Problem Mike Other Car Related Discussions 42 12-23-2008 04:30 PM
Fit Factory Radio Wiring Harness BamaBR549 Fit I.C.E. 4 11-12-2007 11:56 PM
A RADIO trick for the Fit... integradriv3r Fit I.C.E. 13 02-16-2007 03:14 PM
Re: Radio Code?? radarguy1@earthlink.net Other Car Related Discussions 0 05-04-2005 05:44 PM
'91 Accord Radio Power Question Phil Other Car Related Discussions 4 05-04-2005 12:16 PM
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
