Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > Fit Trix > Fit I.C.E.
Fit I.C.E. Threads discussing in-car electronics including audio, video, security, and navigation systems for the Honda Fit/Jazz
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #1 (permalink)
Old 09-10-2009, 09:21 PM
Stravos relies on Rep Points to liveStravos relies on Rep Points to liveStravos relies on Rep Points to liveStravos relies on Rep Points to liveStravos relies on Rep Points to liveStravos relies on Rep Points to liveStravos relies on Rep Points to liveStravos relies on Rep Points to liveStravos relies on Rep Points to liveStravos relies on Rep Points to liveStravos relies on Rep Points to live
Wiring bits?
Well I have my system all picked out and purchased, now I just need all the wiring bits. I have a good idea of what I need, just not sure where I should be looking to buy and what specs to look for.
I'm wiring up a HU, front components, rear coax and a 5-channel amp. HU should be taken care of, and I have a set of RCA cables that I can run for the mono channel.
Here's what I think I need:
4-channel RCA cables / 2x2-channel RCA cables
4 gauge power wire
remote wire for amp (gauge?)
a decent length of speaker wire
Am I forgetting anything here?
So here's where I need advice. How long do the RCAs need to be? I don't want to cut it too close, but I also don't want to have to run 5 feet of excess somewhere out of the way.
What size should for remote wire?
How much speaker wire should I get?
Obviously I can eyeball these easily enough, but if anyone has these numbers available it would be much appreciated.
And finally, are there any specific brands I should be looking at, or staying away from?
I appreciate any and all advice. You shall be rewarded with glorious Fit ICE pics once this is all set up
Thanks!
Sponsored Links
  #2 (permalink)
Old 09-11-2009, 09:32 AM
MetalHead88's Avatar
MetalHead88 relies on Rep Points to liveMetalHead88 relies on Rep Points to liveMetalHead88 relies on Rep Points to liveMetalHead88 relies on Rep Points to liveMetalHead88 relies on Rep Points to liveMetalHead88 relies on Rep Points to liveMetalHead88 relies on Rep Points to liveMetalHead88 relies on Rep Points to liveMetalHead88 relies on Rep Points to liveMetalHead88 relies on Rep Points to liveMetalHead88 relies on Rep Points to live
being that the fit isnt a very big car, i would imagine any rca wire they sell for wiring a car would reach the back seat no problem.
one thing i noticed you dont have in your list is ground wire for the amp. go with 4 gauge as well.
the remote wire holds very little power, it just tells the amp when to turn on and off, even the smallest gauge wire would be fine
its hard to tell with the speaker wire, honestly i would buy more then needed you never know when u could use some extra speaker wire.
lastly, you might be better off buying a full kit. i spent like 130 bucks on all my wiring (JL) JL is very overpriced, but its never a bad idea to buy the best.
in my last system, i used a 4 gauge boss kit that costed me like 70 bucks and had no problems in 3 and a half years.
alot of people use "street wire" kits i havent used them, but ive never heard anything bad either.
just dont go with those cheap wallmart wires. and buying too much is always better then buying too little.
  #3 (permalink)
Old 09-11-2009, 12:05 PM
Thanks MetalHead.
Right now I'm looking at StreeWires gear, because they seem to be the most readily available. I have an amp power kit and 40 feet of 14-guage speaker wire, which I'm sure is overkill.
Right now I'm trying to decide on RCA lengths. Standard sizes are 11.5' and 16.4', which is a huge difference. I had 16.4' running from the HU to the back of the trunk in my old Volvo, so I imagine 11.5' should be sufficient. If I install the amp under the back seats, 11.5' will be plenty, but I'm not so sure if I put it in the hatch.
  #4 (permalink)
Old 09-11-2009, 01:18 PM
mike2100's Avatar
mike2100 relies on Rep Points to livemike2100 relies on Rep Points to livemike2100 relies on Rep Points to livemike2100 relies on Rep Points to livemike2100 relies on Rep Points to livemike2100 relies on Rep Points to livemike2100 relies on Rep Points to livemike2100 relies on Rep Points to livemike2100 relies on Rep Points to livemike2100 relies on Rep Points to livemike2100 relies on Rep Points to live
use a string to measure how much wire you need, round up
__________________
09 TW Sport MT
08 SSM Sport AT
Reply
Tags
2009, amplifier, fit, honda, remote, wire
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Availability of wiring bits ElanS2 Honda Fit Dealer Representatives 1 08-12-2009 11:20 PM
Electrical bits needed ElanS2 Fit DIY: Repair & Maintenance 1 08-12-2009 11:17 PM
Wiring harness from etrailer for Honda Fit NCFit 1st Generation (GD 01-08) 5 07-28-2009 08:21 AM
Wiring change question.... vinnimac Fit Trix General Discussions 2 02-22-2009 04:10 AM
Wiring insanity RandomSkratch Fit I.C.E. 6 10-14-2008 08:01 PM
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
