Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > Fit Trix > Fit I.C.E.
Fit I.C.E. Threads discussing in-car electronics including audio, video, security, and navigation systems for the Honda Fit/Jazz
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #1 (permalink)
Old 09-12-2009, 02:32 PM
BayAreaKid relies on Rep Points to liveBayAreaKid relies on Rep Points to liveBayAreaKid relies on Rep Points to liveBayAreaKid relies on Rep Points to liveBayAreaKid relies on Rep Points to liveBayAreaKid relies on Rep Points to liveBayAreaKid relies on Rep Points to liveBayAreaKid relies on Rep Points to liveBayAreaKid relies on Rep Points to liveBayAreaKid relies on Rep Points to liveBayAreaKid relies on Rep Points to live
Question Camera Security System??
Anyone install a security camera system in their car? My car was hit while I it was parked and I want cameras to catch this if it happens again. Luckily they left a note, but next time they may not. I was looking for a front and rear camera setup maybe side as well.
__________________
Alex
In my Garage: Fit/3 Series/BoxsterS/NSX/Prius
Sponsored Links
  #2 (permalink)
Old 09-14-2009, 06:57 AM
CuTeBoi's Avatar
CuTeBoi relies on Rep Points to liveCuTeBoi relies on Rep Points to liveCuTeBoi relies on Rep Points to liveCuTeBoi relies on Rep Points to liveCuTeBoi relies on Rep Points to liveCuTeBoi relies on Rep Points to liveCuTeBoi relies on Rep Points to liveCuTeBoi relies on Rep Points to liveCuTeBoi relies on Rep Points to liveCuTeBoi relies on Rep Points to liveCuTeBoi relies on Rep Points to live
apartment or house?
Put the cameras around the car, if your car gets hit, it will most likely be from the side, the view angles of cameras mounted on a car would be too limited. and with the power supply requirements from systems that have HD quality to "catch" the culprit, your battery would die rather quickly.
__________________
Got Speed?
  #3 (permalink)
Old 09-18-2009, 08:46 PM
interestingstuff relies on Rep Points to liveinterestingstuff relies on Rep Points to liveinterestingstuff relies on Rep Points to liveinterestingstuff relies on Rep Points to liveinterestingstuff relies on Rep Points to liveinterestingstuff relies on Rep Points to liveinterestingstuff relies on Rep Points to liveinterestingstuff relies on Rep Points to liveinterestingstuff relies on Rep Points to liveinterestingstuff relies on Rep Points to liveinterestingstuff relies on Rep Points to live
NetworkCameraReviews.com - IP Camera Forum is probably one of the best forums out there for security camera info. I would go there and ask for suggestions. I have seen plenty of tiny cameras. Most run on DC. Many run on batteries. It should be easy enough to set up good unit(s) once you figure out what is out there.
Please report back with what you find out.
__________________
IS
CBP (Black) 09 Base Fit C4C deal (thanks Gub'mint!)
Alpena Innisbrook Interior Makeover Kit (Seatcovers)
$23 keyless entry keyfob (why they don't just give you one when the system is in there is beyond me.)
Reply
Tags
camera, car, fit, forum, honda, rear, security
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
2009 Infiniti FX50 Sid 6.7 Other Car Related Discussions 6 05-28-2008 10:12 PM
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
