Bluetooth wiring help
Hey guys I really need some help with a new radio I bought to replace my stock headunit. I bought this one: http://www.amazon.com/gp/offer-listi...&condition=new
Its a kenwood DDX372BT and im going to install it into my 2011 Honda Fit Sport. If any of you have experience in installing the whole blue tooth wiring I could really use some tips! Like, where did you find was the best place to run it through so the wiring is less visible.
And more importantly, where in the dash did you find was the easiest to run it through? Is it easier to run the wire by the passengers side? If so, which panels should i take out to make it go behind the glove box and are they easy to snap off? Any incite is appreciated guys! Ill try to post pics ASAP
ajynks@gmail.com
08-14-2016 09:03 PM
BStecke
02-07-2011 06:07 AM
