There are a few different Foot Light Kits out there. The most popular being accessory 08E10-SLN-30. This thread is to discuss the other Foot Light kit 08E10-SAA-A01. I am interested in comparing the differences between two lighting kits and looking for kit's 08E10-SAA-A01 install instructions. I have shot detail photos of the parts so we all can get a good look at what is in this kit.
So here is my story. I purchased the Honda JDM Foot Light kit (08E10-SAA-A01) from A&J Racing. These blue LED lights once installed will light up the driver and passenger foot well area. I was told they would turn on when I turn on my headlights. They might even come on when the doors are open. We will have to wait until I get them installed for me to know if that is a true answer.
The kit is from Honda Japanese and did not come with any install instructions. The instructions are only available to dealerships. Dickson at A&J Racing said they don't have any access to the install instructions, but someone he knows has the Foot Lights installed on their car. He will try to take some photos to show the install.
We have all seen those install PDF that are for other Honda Accessories. It would be great if someone could get a hold of one of those instructions for this kit. Even if it is only in Japanese I could get my wife to translate it.
I am sure I could install the Foot Lights without the instructions, but I am interested in doing it the correct Honda dealership install way. The wires ran and plug in correctly, the modules and metal brackets attached to the correct spots, etc.
I took lots of photos of the wiring kit and I will post them here for all of us to review. My comments go with the linked photos. Click on the links to view the photos if they don't appear.
A= Where the lights attach. One for the driver's side and one for the passenger"s side.
B= Plugs into the Black Box Module. What do you think this box does. It it not found on the other lighting kit.
C= I think this plugs into the fuse box. But I could be wrong on that.
CC= A pass-through. So you can plug in another accessory and share the same plug source.
D= Light Green plug. I don't know where it plugs into. It could go near or in the Fuse Box.
E= Blue Plug with foam protection. I am looking to see here this attaches, maybe the mirrow switch.
F= A in-line Fuse.
I can tell which end of the bracket attaches to the light. I do not know which side should be up when it is attached. I don't know how the metal brackets attach to the car. I could just guess, but I wonder what the real install says.
There are only two screws and 2 lock-nuts in the package.
One sticker reads Foot Light and the other reads Pocket Light in English and Japanese. By the way, My wife explained what Pocket Light was. Pocket lights are small lights appearing in the "middle" of the dash. She said Pocket Light means, small light or small convenient light or not too big light, ha, ha. They come in either blue or amber lights. If you order the blue kit, your middle lights will be blue except for the glove box, that remains amber. Sells for about $70. dollars in Japan.
This paper template is used to aligning something. Drilling holes, metal brackets, etc.
Same paper template translated from Japanese. You can almost understand it. CAR LINE means the car goes this way. The Direction the car travels.
Lights being attached.
Lights snap on tightly to the metal bracket. I don't know which side is up or down on the brackets.
Most likely the metal bracket is attached to the car first, then the black box is slide on to it. I don't know which side is up or down on the bracket. Sort of like the "black box" that you slide on that when you install the Keyless Entry Remote wire harness on a Base Fit Model.
Where does it attach to the fuse box? I could be totally wrong. I am checking into it.
Where does this plug into. It looks like it plugs in near the fuse box. I will check it out.
Where does this plug into. I'll check into it.? Could plug in to the Mirror Switch
Look Ma, An In-Line Fuse. If you screw up and it stops working, check this fuse.
One last thing, I can figure out how to install this kit based on other install kits out there. I am just curious to see the real install instructions. I like to know what Factory/Dealership install are supposed to look like to on this kit.
Replies welcome.
