Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > Fit Trix > Fit Interior & Exterior Illumination
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #1 (permalink)
Old 12-10-2005, 07:19 AM
kitty86 is on a distinguished road
brake light not working
hi im new to this, im from the uk so im guessing that the engine on the jazz over here be bit different to ur fits over where ur from. iv had the jazz for about a month now, and the brake lights has suddenly just gone of every thing else is working ok, its just the 3 brake lights dont work. i think it the fuse but im not sure? can some 1 tell me where the fuse is for the brake light? and if it not the fuse and other reason why it wont work.
p.s i know where the fuse box is just need to know which number the fuse is in.
thanks for ur help
andy
Sponsored Links
  #2 (permalink)
Old 12-10-2005, 10:08 AM
found out its not the fuses fault or the bulb. it the brake switch thats just above the brake pedal. need to replace it. any one in the uk know how much it cost and is it easy to fit?
  #3 (permalink)
Old 12-10-2005, 04:54 PM
vividjazz's Avatar
Someone that Posts too much
vividjazz relies on Rep Points to livevividjazz relies on Rep Points to livevividjazz relies on Rep Points to livevividjazz relies on Rep Points to livevividjazz relies on Rep Points to livevividjazz relies on Rep Points to livevividjazz relies on Rep Points to livevividjazz relies on Rep Points to livevividjazz relies on Rep Points to livevividjazz relies on Rep Points to livevividjazz relies on Rep Points to live
Should be a warranty claim so zero cost.
__________________
Australian Honda Fit Jazz Club - www.ausfit.com
  #4 (permalink)
Old 12-10-2005, 04:55 PM
Frequent FitFreak Poster
kentris is on a distinguished road
yeah just go back to honda dealer and tlak to them about it.
I'm from UK, what jazz you got? I got the 1.2L mdel.
  #5 (permalink)
Old 12-11-2005, 08:54 AM
iv got a 1.4 model. the car ran out of warrenty i bought it privately and its gone past it warrenty date. my friend said its should'nt be to much of a cost probably under 10 pounds to get the switch. just hope it is the switch cause iv checked every thing else (bulbs and fuses)
apart from that, the jazz is a great car
  #6 (permalink)
Old 12-11-2005, 12:00 PM
eyemdee is on a distinguished road
If you've checked the bulbs, and fuse number 16 under the bonnet - this powers the horn as well so if your horn doesn't work you know where to look - then you need to test the pedal switch itself. It is at the back of the brake pedal with a 4 way electrical connector attached. Disconnect the connector and check continuity across terminals 1 and 2 on the switch. There should be continuity with the pedal pressed and open circuit when released if the switch is working. You can also test the wiring to the switch by connecting together the two wires in the plug with the ignition on - this should light the brake lights if the switch is faulty. The switch looks easy enough to replace as it just appears to screw out. Hope this helps, Ian
  #7 (permalink)
Old 12-12-2005, 12:06 AM
Dojo relies on Rep Points to liveDojo relies on Rep Points to liveDojo relies on Rep Points to liveDojo relies on Rep Points to liveDojo relies on Rep Points to liveDojo relies on Rep Points to liveDojo relies on Rep Points to liveDojo relies on Rep Points to liveDojo relies on Rep Points to liveDojo relies on Rep Points to liveDojo relies on Rep Points to live
eyemdee,
Great advice and testing directions.
Kitty86, Here is a picture for reference. I think you may need part #5
D
  #8 (permalink)
Old 12-12-2005, 07:22 AM
thats some really good advice ian and dojo. thanks iv order the part from honda 2day its gonna cost £41.70 thats including VAT (very expensive) i will let u guys know how it goes.
thanks
andy
  #9 (permalink)
Old 12-12-2005, 05:06 PM
where abouts you from?
Reply
Tags
04, access, brake, break, cost, fit, fuse, fuses, honda, jazz, kitty86md, light, lights, switch, working
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Go
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
