Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > Fit Trix > Fit Interior & Exterior Illumination
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #1 (permalink)
Old 06-09-2009, 07:34 PM
fitdeaf is an unknown quantity at this point
JDM/EDM headlight adjustable switch/unit - USDM GD Fit
FitFreakers-
Since I have all, if not, most of the necessary parts and wiring diagram for headlight adjustable unit (it would be located next to the power-folding mirror switch inside my car – same location for JDM coin tray, in case you may be wondering) as seen in JDM/EDM model, a set of adjustable headlights is required to complete the installation.
My question is - could USDM headlights be fitted with adjustable unit? If not, is it possible for the imported (JDM/EDM) adjustable headlights to fit (no puns intended) with USDM front end, perhaps, with the use of spacer (for lack of a better term) or related fitment?
Your advice/input would be greatly appreciated.
Damien
Sponsored Links
  #2 (permalink)
Old 06-10-2009, 04:54 PM
gimme's Avatar
gimme relies on Rep Points to livegimme relies on Rep Points to livegimme relies on Rep Points to livegimme relies on Rep Points to livegimme relies on Rep Points to livegimme relies on Rep Points to livegimme relies on Rep Points to livegimme relies on Rep Points to livegimme relies on Rep Points to livegimme relies on Rep Points to livegimme relies on Rep Points to live
Send a message via AIM to gimme
I dont think the headlights would work with our front end. the over all length is different as well as the angles of them. You could possibly space them out, but the angles would look bad I would think.
__________________
I offer various installs on our car and have done most that can be done. PM for pricing and appts. Not only am I a fan of the Fit, I actually own one
http://www.fitfreak.net/forums/gener...tml#post697447
  #3 (permalink)
Old 06-10-2009, 07:26 PM
gd3vbp relies on Rep Points to livegd3vbp relies on Rep Points to livegd3vbp relies on Rep Points to livegd3vbp relies on Rep Points to livegd3vbp relies on Rep Points to livegd3vbp relies on Rep Points to livegd3vbp relies on Rep Points to livegd3vbp relies on Rep Points to livegd3vbp relies on Rep Points to livegd3vbp relies on Rep Points to livegd3vbp relies on Rep Points to live
If you have the time to do it, and the money for a set of edm headlights you could swap over all the moving components then wire it up to make it work.
  #4 (permalink)
Old 06-11-2009, 07:40 PM
gimme-
I do completely understand that fitment may be out of question, even though the larger USDM headlights may have similar appearance as the smaller EDM headlights – unlike the JDM counterparts. I thought the larger bulb component (one with high-beam/low-beam, not amber, if I am making sense) could be easily swapped with the adjustable unit, no?
Damien
Reply
Tags
09, 2008, adjustable, angles, coin, edm, fit, front, gd, headlight, headlights, honda, jdm, usdm
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Projectors, Many question and answers astronaut Fit Interior & Exterior Illumination 88 10-28-2009 04:04 AM
RED headlight USDM FELIXY69 For Sale - Local Pickup Only 1 01-22-2009 11:43 PM
Dash lights adjustable independent of headlight status secondspassed Fit Interior & Exterior Illumination 2 01-20-2009 11:41 PM
fs: OEM RED USDM headlight 10000kms FELIXY69 For Sale - Local Pickup Only 0 10-15-2008 07:25 AM
fs: OEM RED USDM headlight 10000kms FELIXY69 For Sale / Want To Buy / Classified Ads for USED Fit Items 1 10-14-2008 08:36 PM
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
