Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > Fit Trix > Fit Interior & Exterior Illumination
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #1 (permalink)
Old 11-03-2009, 10:34 PM
Jumarcil is an unknown quantity at this point
Question HID Light Problem ;-(
Hi;
I just had an HID kit installed on my Fit 2008 and the right bulb fails once in a while. At first they installed it with ballast but without a relay so when I started the car I didn't have any light at all until I started the light. But when I opened the light I had an on and off problem with the right bulb sometimes failing. They told me that by installing a relay it should fix my problem. They did install the relay but still the same on and off problem. They set it up so that when I start the car I am on the high beam and when I turn the light on, they fall back to lo beam. After they work normally but still with the rigt beam sometimes not working.
Any help greatly appreciated since I am sending back the car to the garage in 2 days and the mechanic is out of idea I guess.
thanks
Jules
Sponsored Links
  #2 (permalink)
Old 11-04-2009, 01:15 PM
qbmurderer13's Avatar
Detailing Guru
qbmurderer13 relies on Rep Points to liveqbmurderer13 relies on Rep Points to liveqbmurderer13 relies on Rep Points to liveqbmurderer13 relies on Rep Points to liveqbmurderer13 relies on Rep Points to liveqbmurderer13 relies on Rep Points to liveqbmurderer13 relies on Rep Points to liveqbmurderer13 relies on Rep Points to liveqbmurderer13 relies on Rep Points to liveqbmurderer13 relies on Rep Points to liveqbmurderer13 relies on Rep Points to live
Sell it and go back to stock, or get REAL HID system. This shows the quality of these plug and play kits.
__________________
My Detail Threads
  #3 (permalink)
Old 11-04-2009, 02:39 PM
FITMugen relies on Rep Points to liveFITMugen relies on Rep Points to liveFITMugen relies on Rep Points to liveFITMugen relies on Rep Points to liveFITMugen relies on Rep Points to liveFITMugen relies on Rep Points to liveFITMugen relies on Rep Points to liveFITMugen relies on Rep Points to liveFITMugen relies on Rep Points to liveFITMugen relies on Rep Points to liveFITMugen relies on Rep Points to live
I don't know what type of HID conversion kit you got? I bought mine from eBay.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=390032291858&viewitem= &sspagename=STRK%3AMEWNX%3AIT
If you follow the link you will see a diagram. You have to have a relay. Otherwise, it might void your car warranty if you had electrical issue.
The relay will get a signal from one of headlights socket. The power feeds directly from a battery. Hi and lo are controlled by Bi-Xenon Controller.
I don't have any problem with my HID yet. It has been 3 months on the FIT. However, I have HID on my 2007 Civic Si for almost 3 years now with no problem.
Please let me know if you need further assistant.
__________________
FITMugen
2009 Honda FIT Sport AT/VSA/NAV
-Ambient Lights - OEM
-Remote Engine Starter - OEM
-HID
-Heated Windshield Washer
-TINT
  #4 (permalink)
Old 11-04-2009, 10:22 PM
Thanks for your help.
Jules
Reply
Tags
08, beam, car, conversion, fit, hid, honda, kit, light, lights, low, oem, peoblems, problems, start, turn
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
New Products! Many LED light for Our Fit! theljnet theljnet.com 0 06-05-2008 01:05 AM
Replace Alternator to fix SRS light problem? Did I get took by the dealer?? MegaC Other Car Related Discussions 1 08-29-2005 03:30 PM
Replace Alternator to fix SRS light problem? Did I get took by the dealer?? MegaC Other Car Related Discussions 0 08-29-2005 12:30 PM
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
