Fit Interior & Exterior IlluminationThreads discussing interior and exterior lighting modifications for the Fit/Jazz
Welcome to Fit Freak!
Welcome to Fit Freak,
I changed mine to some crappy LEDs I had in my garage, will leave them until I order up some more omni directional ones. Was super simple to get to the bulbs as has been stated, push that cover the the right and it pops right out. Not sure why you guys are breaking them, didnt seem fragile to me at all. Maybe if you do it when its really cold that will have something to do with it.
__________________
08 Sport AT BOM...tint/alarm/remote start/16x7 5Zigen FN01R-C/Yokohama AVID H4S
I should have taken pics of the lens when I bought them, does anyone have any available to help out? They were easy to put in but I broke them them trying to get them out.
__________________ My Flickr page!
Mods:
HID's
Led reverse, brake, and parking bulbs
Took off stock exhaust
k me and my friend did it figured out lifting the trunk hatch half way and doing it made it easier to pop out the housing. sorry no pics was trying to take time not to break clips. but use like med pressure to the left and like push up small kind should pop out. dont force it will break. and then you put it back in have to go left side in the right should pop in. i really wish i took pics sorry.
broke my shit barely touchin it, those things are so fragile. How much are those covers, gotta get a new one any time you touch it. The left one was perfect, right side exploded instantly. And after testing my LED's they are pretty dim. You guys using high flux or smt or what as for LED's, or you doin the 5 radial mount ones or what?
__________________
Aww, they love each other, but are jealous of who gets my attention
the bulb size is 194. I do NOT RECOMMEND getting glass bulbs that are painted because i had some lying around from my old car and installed them on my fit. A week later one was out and when i check the housings, the glass broke and the housings were melted!!! i had 2 order TWO new license plate housings and covers ($10 each side) so now i switched them to LED'S. Here is where i get all my led's:
Scroll down until u see where it says: 194 Signal/Marker Bulbs. (Inverted Lenses Emit Light out the sides of the bulb)
U need an inverted bulb (that shoots light from the side rather then a traditional LED that focuses light out the tip of the nose) because the led doesn't face directly down at the license plate to illuminate it enough. The side emmiting led's work the best and are very bright.
Thanks alot for everyone's input. Following the advice I was able to change out my bulbs in less than 5 mins. I did notice 1 thing that would help those who are still having trouble (doubt it since the last post was in jan) is to push to the right and try to start lifting the left side of the housing. the clip that keeps it in place is only on the right side. so when pushed in it creates the gap needed to pull it out.
__________________ San Antonio, TX
2008 Tidewater Blue Fit Sport
SSR Intake
PIAA Xtreme White Plus H4
Under dash cathodes
LEDs (dome,truck,license plate)
35% front tint, 5% all other
i was able to replace the bulbs with a led wedge style, it has 9 leds in each bulb.it looks great. i got them off of ebay. ill get back with the item #. i also broke one side of the cover, but honda replaced it under warranty
I did mine last evening. Trick is to keep your right thumb down low on the lens while pushing to the right. At same time use fingernail of left hand to pry under the left edge. They only move to the right maybe 1/4 inch.
Oh do try them before putting them back in. I did not and had to take them out again and fiddle with the bulb bases to make contact.
__________________
''Life's tough......it's even tougher if you're stupid.''
