Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > Fit Trix > Fit Interior & Exterior Illumination
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #221 (permalink)
Old 03-17-2008, 04:26 PM
SickFit's Avatar
Frequent FitFreak Poster
SickFit has much to be proud ofSickFit has much to be proud ofSickFit has much to be proud ofSickFit has much to be proud ofSickFit has much to be proud ofSickFit has much to be proud ofSickFit has much to be proud ofSickFit has much to be proud ofSickFit has much to be proud ofSickFit has much to be proud of
Quote:
Originally Posted by jdjohnson9 View Post
I just poured lots of water on the lamin-x and peeled it off. There is alot of residue on the glass still that you need to scrub off tho. I dont know of a way to make it any easier. It does stick very well which is great for installing but sucks for removing, kinda like window tint.
Just water . Must be something else too right?
That $hit is stuck like chuck.
Seriously I tried lifting the vinyl with a phillips flat head and it didnt even budge. I will try water when I get home.
Has anyone tried reheating it? This way the adhesive can melt agian.
__________________
  #222 (permalink)
Old 03-17-2008, 04:37 PM
jdjohnson9's Avatar
Avid FitFreak Poster
jdjohnson9 relies on Rep Points to livejdjohnson9 relies on Rep Points to livejdjohnson9 relies on Rep Points to livejdjohnson9 relies on Rep Points to livejdjohnson9 relies on Rep Points to livejdjohnson9 relies on Rep Points to livejdjohnson9 relies on Rep Points to livejdjohnson9 relies on Rep Points to livejdjohnson9 relies on Rep Points to livejdjohnson9 relies on Rep Points to livejdjohnson9 relies on Rep Points to live
You can try it. I know it sounds silly but i filled my sink up with water and dunked just the glass in the water and let it sit for a few minutes and then used a razor blade with more water to pretty much cut and pull it off. My first lamin-x was only installed for a month or so and didnt really get a chance to bake on. Maybe that had something to do with it. I had to clean the hell out of the glass tho cause it was covered in adhesive. That was a big pain. I would be carefull using a screwdriver cause you could scratch the glass itself. I used a lot of caution with the razor so i didnt scratch it. Hope that helps.
__________________
Joshua
Gone but not forgoten:
2007 MR Sport M/T (Ruby)
2008 NHBP Sport Auto (ex wifey's)
New in town:
2008 Nimbus Grey Metallic, Ridgeline RTL
  #223 (permalink)
Old 03-29-2008, 07:46 PM
goodyonsen's Avatar
goodyonsen relies on Rep Points to livegoodyonsen relies on Rep Points to livegoodyonsen relies on Rep Points to livegoodyonsen relies on Rep Points to livegoodyonsen relies on Rep Points to livegoodyonsen relies on Rep Points to livegoodyonsen relies on Rep Points to livegoodyonsen relies on Rep Points to livegoodyonsen relies on Rep Points to livegoodyonsen relies on Rep Points to livegoodyonsen relies on Rep Points to live
Send a message via AIM to goodyonsen
How long does it usually take to ship?
__________________
RIP always&forever <3
FS: STOCK PARTS + SKUNK2 SPRINGS
  #224 (permalink)
Old 03-30-2008, 02:18 AM
SD_MR_FIT's Avatar
SD_MR_FIT relies on Rep Points to liveSD_MR_FIT relies on Rep Points to liveSD_MR_FIT relies on Rep Points to liveSD_MR_FIT relies on Rep Points to liveSD_MR_FIT relies on Rep Points to liveSD_MR_FIT relies on Rep Points to liveSD_MR_FIT relies on Rep Points to liveSD_MR_FIT relies on Rep Points to liveSD_MR_FIT relies on Rep Points to liveSD_MR_FIT relies on Rep Points to liveSD_MR_FIT relies on Rep Points to live
Send a message via AIM to SD_MR_FIT
i just removed my lamin-x super easy.
i just pulled it right off. took a little effort but so simple.
THEN to get all that residue off, you take a razor blade and you just etch it off. super simple, then use a scrub pad and some soapy water to get it nice and clean.
i just transfered over to the blue batmobile tint because my lamin-x burnt(had a black and brown spot in the middle of it)
i like this stuff better, the tint... its WAY cheaper and it has a darker look to it.
unfortunately it doesn't protect my fogs as well as the lamin-x does.
__________________
James- Phase 3 of make over in progress
  #225 (permalink)
Old 04-01-2008, 04:41 PM
YeeFit's Avatar
YeeFit relies on Rep Points to liveYeeFit relies on Rep Points to liveYeeFit relies on Rep Points to liveYeeFit relies on Rep Points to liveYeeFit relies on Rep Points to liveYeeFit relies on Rep Points to liveYeeFit relies on Rep Points to liveYeeFit relies on Rep Points to liveYeeFit relies on Rep Points to liveYeeFit relies on Rep Points to liveYeeFit relies on Rep Points to live
WOW! how retarded... I went to the X-Pel site to order a bulk sheet of yellow 30mil film, a 10" x 10" sheet was $13.. not bad.. then while I was completing the checkout.. the shipping was $45!?!?! wtf?
$58 dollars for a 10"x10" sheet worth $13?
  #226 (permalink)
Old 04-01-2008, 08:27 PM
Kelmar's Avatar
Kelmar has a spectacular aura aboutKelmar has a spectacular aura about
Seriously dude, order from Andy at Bluebatmobile. It's $12 SHIPPED and they are precut!!!
  #227 (permalink)
Old 04-02-2008, 03:24 PM
kptrulee's Avatar
kptrulee relies on Rep Points to livekptrulee relies on Rep Points to livekptrulee relies on Rep Points to livekptrulee relies on Rep Points to livekptrulee relies on Rep Points to livekptrulee relies on Rep Points to livekptrulee relies on Rep Points to livekptrulee relies on Rep Points to livekptrulee relies on Rep Points to livekptrulee relies on Rep Points to livekptrulee relies on Rep Points to live
Send a message via AIM to kptrulee Send a message via MSN to kptrulee
Quote:
how to get in contact in with him?
  #228 (permalink)
Old 04-05-2008, 02:45 PM
Kelmar's Avatar
Email him at bluebatmobile@san.rr.com
  #229 (permalink)
Old 04-05-2008, 03:15 PM
KoolMikeSki's Avatar
KoolMikeSki relies on Rep Points to liveKoolMikeSki relies on Rep Points to liveKoolMikeSki relies on Rep Points to liveKoolMikeSki relies on Rep Points to liveKoolMikeSki relies on Rep Points to liveKoolMikeSki relies on Rep Points to liveKoolMikeSki relies on Rep Points to liveKoolMikeSki relies on Rep Points to liveKoolMikeSki relies on Rep Points to liveKoolMikeSki relies on Rep Points to liveKoolMikeSki relies on Rep Points to live
hmmm I just got xpel for mine and it was $11.46 shipped for two 4x6" sheets?
__________________
2007 NHBP Fit (Stock)
2002 Chrysler Sebring LX
  #230 (permalink)
Old 04-05-2008, 03:17 PM
Kelmar's Avatar
Yeah, you can always get just the sheets from Bluebatmobile. Personally, I felt I'd pay a little more and not have to cut them myself.
  #231 (permalink)
Old 04-05-2008, 03:21 PM
True........
__________________
  #232 (permalink)
Old 04-05-2008, 03:30 PM
kptrulee's Avatar
thanks kelmar, will be sending him an email
  #233 (permalink)
Old 04-06-2008, 10:14 AM
Tiffany has a reputation beyond reputeTiffany has a reputation beyond reputeTiffany has a reputation beyond reputeTiffany has a reputation beyond reputeTiffany has a reputation beyond reputeTiffany has a reputation beyond reputeTiffany has a reputation beyond reputeTiffany has a reputation beyond reputeTiffany has a reputation beyond reputeTiffany has a reputation beyond reputeTiffany has a reputation beyond repute
Quote:
Originally Posted by Rad View Post
i just ended up painting mine with stain glass paint
it worked great!!!
i left the outside edge unpainted just to be on the safe side to let heat escape.
but it was MUCH better than lamin-x or any of that
pic related
How long have you had the stain glass paint on. I have used that before for house windows. Requires a primer too. any cracking. I think that would happen with all the heat.
  #234 (permalink)
Old 04-06-2008, 03:19 PM
SD_MR_FIT's Avatar
i would have paid more to have andy give me a bigger sheet for the fogs. i like to wrap it all. instead of having some spots. even though the foglight covers cover it....but i know its not completely covered and it bugs me.
the only reason why i would say go with lamin-x over bluebatmobiles is because it will ACTUALLY protect your foglights.
andys is just for looks, but they havnt burnt on me yet.
but my lamin-x film took about 8 months to burn so i dont know.
both products put out the yellow look. but lamin-x is thicker so it i will prevent your fogs from cracking if a small rock hits it.
__________________
  #235 (permalink)
Old 04-06-2008, 03:25 PM
Kelmar's Avatar
I was under the impression that if it was completely wrapped that it WOULD burn?
  #236 (permalink)
Old 04-09-2008, 05:57 PM
aliencowboy's Avatar
aliencowboy relies on Rep Points to livealiencowboy relies on Rep Points to livealiencowboy relies on Rep Points to livealiencowboy relies on Rep Points to livealiencowboy relies on Rep Points to livealiencowboy relies on Rep Points to livealiencowboy relies on Rep Points to livealiencowboy relies on Rep Points to livealiencowboy relies on Rep Points to livealiencowboy relies on Rep Points to livealiencowboy relies on Rep Points to live
Here a few shots of mine from Bluebatmobile.
  #237 (permalink)
Old 04-09-2008, 09:10 PM
Kelmar's Avatar
Looks good!
  #238 (permalink)
Old 04-09-2008, 09:36 PM
dickiez's Avatar
dickiez has a spectacular aura aboutdickiez has a spectacular aura about
Send a message via AIM to dickiez
Quote:
wow niceness i still need to do that independent thing
__________________
GD3 Squad Member #72
  #239 (permalink)
Old 04-30-2008, 06:51 PM
TiMo is an unknown quantity at this point
Yellow fog light looks good.
  #240 (permalink)
Old 05-23-2008, 01:46 PM
TOOL's Avatar
Administrator
TOOL has disabled reputation
Send a message via AIM to TOOL
Im going to be doing this later today.
Its says to apply with a water/alchohol mix to make the film adhear better, did you guys do this?
Tyler
__________________
- KillerFit #12 -
Honda Fit Forums Administrator
http://www.flickr.com/photos/shitwagovan/
Reply
Tags
answer, brown, ca, car, civic, crescenta, diy, film, fog, install, la, light, lights, protege, tail, turning, vinyl, yellow
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
JDM style 3rd brake light DIY! koolkevin1107 Fit Interior & Exterior Illumination 61 01-19-2009 12:31 PM
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
