Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > Fit Trix > Fit Interior & Exterior Illumination
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #281 (permalink)
Old 05-11-2009, 02:59 PM
koolkevin1107's Avatar
koolkevin1107 relies on Rep Points to livekoolkevin1107 relies on Rep Points to livekoolkevin1107 relies on Rep Points to livekoolkevin1107 relies on Rep Points to livekoolkevin1107 relies on Rep Points to livekoolkevin1107 relies on Rep Points to livekoolkevin1107 relies on Rep Points to livekoolkevin1107 relies on Rep Points to livekoolkevin1107 relies on Rep Points to livekoolkevin1107 relies on Rep Points to livekoolkevin1107 relies on Rep Points to live
Send a message via AIM to koolkevin1107
Quote:
Originally Posted by trancedsailor View Post
I heard Lamin-x film doesn't burn. I am using Nokya 80w yellows right now, the highest-watt bulb on the market. I'm sure it would burn lol
Actually, lamin-x DOES burn. I used to use lamin-x until i started burning through them every 4-5 months on OEM bulbs, so i decided to switch over to xpel. I havn't burned the xpel film in over 1.5+ years and still running strong! That's why i carry the xpel brand only.
Quote:
Originally Posted by MetalHead88 View Post
so i got the drivers side out, after 2 hours messing around with the bulb and the clip. i gave up for the day. (and put the drivers side back on, watch i wont get it off again.) is there some sort of trick to this. i took the fender lining off and the splash gaurd underneather. i have plenty of room to work with, the bulb just wont twist out. and the clip is nearly impossible to remove. thats how i got the other 1 off, i poped a screwdriver in and it unclipped. this side wont do that....is there some kind of trick to this? i can pop a motor in.... but i cant take foglights off.... very fustrating...
Yeah the clip is REALLY hard to get off. U just gotta push the button and pull hard. It's easier 2 unclip the harness from the bulb rather then removing the bulb from the housing. Keep trying.
__________________
AIM: koolkev1107
  #282 (permalink)
Old 06-14-2009, 04:16 PM
jadr09fit relies on Rep Points to livejadr09fit relies on Rep Points to livejadr09fit relies on Rep Points to livejadr09fit relies on Rep Points to livejadr09fit relies on Rep Points to livejadr09fit relies on Rep Points to livejadr09fit relies on Rep Points to livejadr09fit relies on Rep Points to livejadr09fit relies on Rep Points to livejadr09fit relies on Rep Points to livejadr09fit relies on Rep Points to live
Put the films on yesterday. Glad we did the wet method, as we had more time to get the placement right.
For the 09's, there's 1 10mm screw in the upper corner of the housing. Take that out, then swing the foglight out. The side closest to the grille swings toward the fenders a couple inches, then you're able to pull the foglight out. Take off the clip for the bulb, and the foglight is free. To get to the light, take out the three screws holding the housing to the light.
Installation is the same as removal. After re-assembling the light and housing, re-connect the bulb sockets. Then, angle the foglight just like you took it out, then slide it back in a couple inches. Push the inside corner in. This should make the outside clips catch, and get the single inside clip to catch. You'll know it's clipped in when the foglight can be gently wiggled without moving much. Don't forget to put back the 10mm screws to finger tight.
This is posted as a guide for foglight removal on the 09's, we take no responsibility for any damages incurred following this guide.
__________________
J: 2009 Honda Fit 1.5 5AT
D: 1999 Buick LeSabre 3.8 4AT
  #283 (permalink)
Old 06-21-2009, 01:31 AM
justintime's Avatar
justintime relies on Rep Points to livejustintime relies on Rep Points to livejustintime relies on Rep Points to livejustintime relies on Rep Points to livejustintime relies on Rep Points to livejustintime relies on Rep Points to livejustintime relies on Rep Points to livejustintime relies on Rep Points to livejustintime relies on Rep Points to livejustintime relies on Rep Points to livejustintime relies on Rep Points to live
Thanks a lot, installed the clear films today on an 09 GE8 Fit. Took me less than 20 mins for both sides. The film looks VERY resistant.... awesome.
__________________
The $8 Grill Mesh Solution for the Fit, protect your A/C condenser etc.
Check my GE8 A/C insulation mod temp tests
  #284 (permalink)
Old 06-22-2009, 05:22 AM
hondafitblue relies on Rep Points to livehondafitblue relies on Rep Points to livehondafitblue relies on Rep Points to livehondafitblue relies on Rep Points to livehondafitblue relies on Rep Points to livehondafitblue relies on Rep Points to livehondafitblue relies on Rep Points to livehondafitblue relies on Rep Points to livehondafitblue relies on Rep Points to livehondafitblue relies on Rep Points to livehondafitblue relies on Rep Points to live
Quote:
Originally Posted by MarTT View Post
I ordered a kit from X-Pel - (H0227) - specifically pre-cut for the Fit fog lights. Extremely easy install, I like the look! (And feel better now that I know I'm protected from those rocks that may damage them.)
More photos with instructions here.
sup how much does the kit cost? i want like a set of 5 pre cut for the fog lights
  #285 (permalink)
Old 07-15-2009, 02:43 AM
qbmurderer13's Avatar
Detailing Guru
qbmurderer13 relies on Rep Points to liveqbmurderer13 relies on Rep Points to liveqbmurderer13 relies on Rep Points to liveqbmurderer13 relies on Rep Points to liveqbmurderer13 relies on Rep Points to liveqbmurderer13 relies on Rep Points to liveqbmurderer13 relies on Rep Points to liveqbmurderer13 relies on Rep Points to liveqbmurderer13 relies on Rep Points to liveqbmurderer13 relies on Rep Points to liveqbmurderer13 relies on Rep Points to live
Man I want the film AND the yellow output at night. Guess its not happening huh...
__________________
My Detail Threads
  #286 (permalink)
Old 07-15-2009, 09:24 AM
MetalHead88's Avatar
MetalHead88 relies on Rep Points to liveMetalHead88 relies on Rep Points to liveMetalHead88 relies on Rep Points to liveMetalHead88 relies on Rep Points to liveMetalHead88 relies on Rep Points to liveMetalHead88 relies on Rep Points to liveMetalHead88 relies on Rep Points to liveMetalHead88 relies on Rep Points to liveMetalHead88 relies on Rep Points to liveMetalHead88 relies on Rep Points to liveMetalHead88 relies on Rep Points to live
Quote:
go with both film and bulbs. thats what i did, the lights are protected, the look hot when off, and on.
  #287 (permalink)
Old 07-15-2009, 01:58 PM
Detailing Guru
Well people are saying the film will burn with aftermarket bulbs. I'm just wondering how long does the film last with some PIAA bulbs. I don't mind changing the film every other month but if it lasts a week then no thanks.
__________________
My Detail Threads
  #288 (permalink)
Old 07-16-2009, 01:31 AM
azncarbos's Avatar
azncarbos relies on Rep Points to liveazncarbos relies on Rep Points to liveazncarbos relies on Rep Points to liveazncarbos relies on Rep Points to liveazncarbos relies on Rep Points to liveazncarbos relies on Rep Points to liveazncarbos relies on Rep Points to liveazncarbos relies on Rep Points to liveazncarbos relies on Rep Points to liveazncarbos relies on Rep Points to liveazncarbos relies on Rep Points to live
Send a message via AIM to azncarbos
If the PIAA are 55watt they will last for about year or more it depend on the how thick the vinyl are....for me it has been over 2 years now with the film and stock bulb....
__________________
DIY on Installing HID
http://www.fitfreak.net/forums/fit-y...-hid-kits.html
  #289 (permalink)
Old 07-16-2009, 12:41 PM
i have 55 watt yellow bulbs with yellow lamin-x film. its been 7 months since ive had them in, and no signs of any burns. they do get hot, but all is going well. i have never actually felt the stock bulbs, so i cant tell you exactly how much hotter they get. just when you put the film on make sure you do it right and dont cover the entire lens
  #290 (permalink)
Old 07-16-2009, 12:49 PM
Detailing Guru
Awesome looks like ill be getting both. Does anyone make pre-cut film for 09 fogs? Xpel offers it but it comes in their headlight kit which is like 70 bucks.
__________________
My Detail Threads
  #291 (permalink)
Old 07-16-2009, 06:34 PM
Piaa's, if they are stock wattage that means they take in 55 watts and put out 55 watts, then u'll be fine. However, if they are 55 watts and put out 100 watts, i DO NOT RECOMMEND getting it. The higher watts will burn something out, whether it be the film or ur wiring. Just stick to oem wattage bulbs and get some films.
OH btw i have both the yellow and clear precut films for the 09. let me know if u want a set. For the precut pieces, it's $10 shipped. cheaper then ANYBODY.
He is right, he bought the films from me and i have them precut to leave a 2cm gap along the edge to allow the heat to escape. With my technique, it doesn't burn. I've had mine with stock bulbs (as well as yellow bulbs but i put em back to stock) for 2 years now, no burning.
__________________
AIM: koolkev1107
  #292 (permalink)
Old 07-17-2009, 03:39 PM
i didnt buy them from kev, but 10 bucks precut is a great price. i got mine on ebay. for 7 bucks for 2 sheets (which is enough for 2 sets) . i cut them myself by making a template out of paper and tracing it onto the film.
buy em from kev. for the price, and the gaurenteed perfect fit, you cant beat it.
  #293 (permalink)
Old 09-26-2009, 04:53 PM
FitDEEZ's Avatar
FitDEEZ relies on Rep Points to liveFitDEEZ relies on Rep Points to liveFitDEEZ relies on Rep Points to liveFitDEEZ relies on Rep Points to liveFitDEEZ relies on Rep Points to liveFitDEEZ relies on Rep Points to liveFitDEEZ relies on Rep Points to liveFitDEEZ relies on Rep Points to liveFitDEEZ relies on Rep Points to liveFitDEEZ relies on Rep Points to liveFitDEEZ relies on Rep Points to live
Very healpful instructions I jst did this to my GE8
__________________
'10 Storm Silver AT Sport /navi/vsa
Mods: 09 Accord horn,window visors,PIAA yellowfoglight bulbs,yellow foglight film,JDM Type R emblems,35% tint
Domo Security system lol O_O
-CRX SiR *under construction*
  #294 (permalink)
Old 10-25-2009, 06:04 AM
chrisvaccaro is an unknown quantity at this point
80watt fogs and xpel film do not mix!!!! just went through my second set of yellow film. I am gonna go for the piaa bulbs and order some more film, I just hate wasting money like this. You live and you learn.
  #295 (permalink)
Old 10-29-2009, 07:41 PM
Palm Beach is an unknown quantity at this point
Send a message via AIM to Palm Beach
kev still got any smoke 09 sets?
  #296 (permalink)
Old 10-30-2009, 07:09 PM
The Xpel films already protected the foglights on J's Fit. Debris flew out of a truck and smashed into the foglight. The lens cracked, and there are pieces of lens inside the housing. The film is holding everything together, and doing just fine! It's even been through the carwash a bunch of times and is water-tight. We're not worrying about the foglight, needless to say.
Get the films, they work!
__________________
Reply
Tags
answer, brown, ca, car, civic, crescenta, diy, film, fog, install, la, light, lights, protege, tail, turning, vinyl, yellow
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
JDM style 3rd brake light DIY! koolkevin1107 Fit Interior & Exterior Illumination 61 01-19-2009 12:31 PM
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
