Fit Interior & Exterior IlluminationThreads discussing interior and exterior lighting modifications for the Fit/Jazz
Welcome to Fit Freak!
Welcome to Fit Freak,
with most setups all you do is train the homelink as usual (click the clicker while doing the weirdy dance on your head singing honda is great, etc etc), then you go to your garage door opener and have it accept your homelink as a trigger. break out your manual and look up how to add new remotes.
this, effectively, sets your opener to respond to one static code. homelink devices don't have the ability to mimic a rolling code so this is the workaround. with non-rolling-code setups you wouldn't have to program your opener, it would just respond thinking your homelink IS your old remote.
that's not true
the first programming step is to get the frequency
the second programming step is to setup rolling code.. as confirm by a phone call to homelink
Anybody have time to drive to Ohio and install mine for me? I was so excited to get the thing but can't find a half an hour of unitterrupted time to get it installed. Got a template for the cut out and everything.
__________________
2007 Storm Silver 5sp M/T Sport
Just getting started on mods:
1 - interior light mod
2 - a/c defrost disabled
3 - maplight with HomeLink
4 - Icom IC-2720H Radio Install
My wife's CR-V has the maplight with the sunglass holder and I was wondering the same thing. I had hers half way out to see if it would fit and got busted and had to put it back. Hers doesn't have the homelink though so I'd have to find one with the homelink.
__________________
moth passed with no replys, and i wanted to ask the same question - will the unit with the sunglass holder fit depthwise?
for those who did the original mod (just the light and link) and cut the liner - do you think it might have enough depth or was it pretty tight as it is?
thanks
__________________
'07 Sport. White. unfortunatley AT
it won't fit without some modification, such as moving it back towards the back, since the roof gets in the way :-P
-joe
hmmm. somehow it looks like it is getting even shalower as you move back but from what you said it is the other way around. why? is there anything protruding from the roof in the "hump" area (the bulge closer to mirror mount)?
__________________
Joe, I think I found what you were talking about here. I blanched at the price though...$311.22 USD before shipping,
Update: my mistake, according to mr-cappy the bulb and bracket are included in the #11 kit...so more like $199.26
Here are the parts roll call for future reference.
I went out to the salvage yards today but didnt find the maplink but did find one with the maplight missing so I cut off the connector so at least I got the connector NOTE: during my research the Acura CL only offered the maplight with homelink WITHOUGHT sunglass holder in 98 and 99 there was no Acura CL in 2000 and the 2001 model has the sunglass holder
I understand the positive to light and negative to ground but to help clarify
Wyy183 mentioned the red wire with white strip which is the center wire in the tree-pin connector does this serve your memory also?
Spider2k mentioned one is constant 12v, one is ground and negative is switched from the door circuit
eGadgetGeek mentioned I tested my light this evening with a battery to make sure everything worked. The switched lights come on with the two outside pins powered. When you take the center pin to ground it lights the lights as long as they aren't already turned on. So, this would mean they are negative switched from the door circuit. Haven't pulled the dome light yet to see how it is wired
So to help clarify everything as shown in the pic
The top pin goes to ground?
The bottom pin goes to the dome light red/white stripe wire?
The middle pin goes to the dome light green/brown stripe wire (to turn on lights when door is open)?
Must find on eBay or salvage yard.
...OK, that's better. Still a stretch to far for me though. Thanks for the update.
Another guy was saying he had to get the bracket and bulb separately, must have been a salvage purchase then. My bad.
Quote:
Originally Posted by mr-cappy
#11 comes with 12, 14 and 15
Reason: More appropriate reaction.
