aftermarket seats and seat rail questions
  #221
Old 02-03-2009, 09:48 PM
saiko's Avatar
Avid FitFreak Poster
Originally Posted by 08fithappy
This is one of the mods i want to do to the fit. I just want the driver side though. I don't know how that would look one bucket seat and one stock. I want bride but recos are nice to.
IMO I thought it looked kind of weird, so i just went with both. I just have OCD like that. haha
  #222
Old 02-03-2009, 09:58 PM
kylerwho's Avatar
spoon fed
i plan on getting a buddy club bucket. what seat rail would you guys recommend?
  #223
Old 02-04-2009, 01:30 AM
Type 100's Avatar
Originally Posted by saiko
Nice site. Idk if recaros will fit on bride rails. Why not juust go bride on bride or recaro on recaro?
I'm sure they'll work. I checked the sites---I can read a little Japanese. Recaro's SR-series and L-series seats will definitely work on the R-series Bride seat rails (RO-type, RB-type, RK-type, RX-type).
products
Besides I think some other poster (MK GD3?) tried them already with good results
Why not all-Bride or all-Recaro? Here's my story...
I got an offer for a second-hand black Recaro SR3 in good condition (one month used) for PhP17,000 (US$1 = PhP47 or so), but brand-new Recaro "baseframes"/seat rails are pretty expensive---almost as expensive as the seat! Bride's rails are half their price over here in the Philippines.
Funny thing, really. Over here, in terms of seats, Bride's are about 30% pricier than Recaros, but Recaro's baseframes are twice the price of Bride's seat rails.
  #224
Old 02-04-2009, 02:07 AM
ahchuen's Avatar
does anyone has have the spoon carbon kevlar seats???
which rails did you use???
  #225
Old 03-10-2009, 05:36 AM
ctan108's Avatar
Has anyone here tried putting EP3 Type R REcaros onto their Jazz??...Just wondering if the ep3 rails will fit straight onto the jazz
  #226
Old 06-11-2009, 08:34 PM
Kurse's Avatar
So, anyone have find a good solution for the airbag light? (No tape please!)
  #227
Old 06-11-2009, 10:18 PM
kylerwho's Avatar
spoon fed
get a 4.3ohm resistor from radio shack and touch the two ends into your now open seat airbag plug and that will shut off the light.
  #228
Old 06-11-2009, 10:20 PM
Kurse's Avatar
thanks a lot!
  #229
Old 06-12-2009, 04:57 PM
add a 1A or 2A fuse in series with the resistor so it doesn't come an ignitor in case the SRS sends a signal. you can either just solder it or use some small female spade connectors and e-tape over it.
i thought i used 3.33 ohms in the past but that was on a gen5 prelude.
  #230
Old 06-15-2009, 09:11 PM
Kurse's Avatar
do you have a picture of it? thanks
  #231
Old 06-17-2009, 08:19 AM
dacollier1's Avatar
I used a 2.2ohm resistor from the local electronics store because radio shack near me did not stock it (not 2.2K, which RS did have). After you shove the resistor in, you will have to reset the light if it's on now, which you can do with a small diameter paper clip as described elsewhere on the forum or following the sequence in the the helms manual (though they say not to do it with a clip, it works.).
Note that the seat belt wire and the seat position sensor must also be plugged in to keep the air bag light off. Tested each one by itself and it trips the air bag light 6 seconds after disconnection. However, as soon as they are plugged back in again, the light will go off after removing the key once and restarting the car, unlike the air bag connector which does need the full reset. The seat postition sensor does not have to be grounded and can be tucked anywhere as long as it's plugged in.
  #232
Old 10-26-2010, 05:07 PM
lungfish23's Avatar
Maybe someone can help....
Will USDM ITR front seats work? Or how much work will be needed to make the base fit?
thanks!
  #233
Old 10-26-2010, 09:43 PM
spoonek4's Avatar
thanks!
Too much of a hassle & money for too little of an advantage is all I can say. The USDM ITR seats still ain't that cheap so I would at the very least get the JDM ITR Recaro.
  #234
Old 03-14-2011, 02:33 PM
lox83's Avatar
Hey im new to the forum, im in the uk and i am in the process of shopping for 02/04 plate Jazz/fit. just trying to gather some info on seat rails to fit a uk spec, any help is most appeciated
  #235
Old 05-17-2011, 10:31 PM
apeng's Avatar
as you wish...
http://www.cardomain.com/ride/3076295/2005-honda-jazz
bracket not same...just lite modd to fit in gd3
  #236
Old 08-23-2011, 07:57 AM
chaddahc's Avatar
i think you can get the railings of ur stock seat then fit it in ur racing seat just few modification of hole
  #237
Old 08-23-2011, 09:06 AM
Garyman's Avatar
if you want off the shelf product- I believe you will need Bride RO seat rails H201 and H202 for the GD Jazz. Probs talking about +£250 shipped from Japan.
I got some recaros in my GE
  #238
Old 08-24-2011, 12:50 AM
RetroAttack's Avatar
hey guys i just have a few questions,
so by putting in aftermarket seats, i will have to bypass the airbag system.
this can be done with just resistors?
after the resistors no more lights and all other airbags will still work?
and what is this paper clip method for resetting?
i am just a little confused and dont want to put in the seats if none of the airbags will work as the car is a daily driver.
i also want to get the lights of the dash.
  #239
Old 11-30-2011, 01:24 AM
kodok3ribu's Avatar
has anyone put on ek9 seats on the fit? wondering how much work on the railings need to be done..
  #240
Old 10-06-2012, 03:35 PM
T-Fit's Avatar
For all you people who did a seat swap on your USDM GD3's, how did you mount your passenger side seatbelt? I'm trying to figure out how I'm gonna do this. I'm using DC2 Recaro's and Bride RO rails.
Quick Reply: aftermarket seats and seat rail questions
