Can I move the oem front speakers to the rear? After upgrading the fronts
Old 09-06-2012, 10:23 PM
mxl180's Avatar
I want to upgrade the front speakers. Since they're better than the rear, can I move these to the rear? Would it fit?
Old 09-06-2012, 10:39 PM
Dwalbert320's Avatar
In my 2012 they are the same Front and Back. Yours should be as well. Unless they are blown in the back I see no reason to switch them out.
Old 09-07-2012, 08:13 AM
x4x5x1x's Avatar
Yup just like Dwalbert320, all your speakers are the same so feel free to move them however you want.
Old 09-10-2012, 08:35 PM
yitznewton's Avatar
Yep, I have 07 Sport and same rubbish front and back. I swapped in some simple Polk 6.5" coaxials front & back, and oh what a difference!
Old 09-10-2012, 08:36 PM
yitznewton's Avatar
Old 12-26-2012, 04:16 AM
Bogdan's Avatar
in terms of doorpanels, do any of the clips break off when you take the doorpanels off to change the speakers?
Old 01-03-2013, 08:43 PM
Spitfire's Avatar
I did mine last week (2013 Fit Sport MT) and the door panels were an absolute bastard to remove. I followed the instructions to the letter, but you really need to pull hard on the panel to get the clips to let go. I applied A LOT of force, and when they did finally let go I ended up flat on my back ... I'm not exaggerating. However, to answer your question, none of the clips broke, although a couple were left in the door rather than in the door panel -- these were easily removed from the door using vice grips and they were then re-inserted into the door panel.
I'll be honest with you; I thought it was going to be an easy job but I really had to apply a lot of force to the door panel and I thought I was going to break something. It was unbelievable really.
Old 01-10-2013, 06:35 PM
Bogdan's Avatar
has anyone posted instructions on how to take the door panels off? haven't taken those off on my fit yet. its an 08 base fit
Old 01-10-2013, 06:54 PM
Wafulz's Avatar
Old 01-10-2013, 06:55 PM
Wafulz's Avatar
Old 03-28-2015, 08:36 AM
Bogdan's Avatar
Bengo
12-01-2022 07:16 PM
soasin
08-02-2012 06:00 PM
Fitpizzaz
03-19-2009 09:13 PM
pvanberk
10-17-2006 10:27 PM
pvanberk
08-14-2006 08:15 PM
Quick Reply: Can I move the oem front speakers to the rear? After upgrading the fronts
