Dyno Numbers, Dyno Numbers, Dyno Numbers
Thought there should be a thread for dyno results for the Fit with different products or configurations. Anyone got muffler delete numbers?
Example Start From Ben at AJ Racing TR1 Header Results :
Dyno 1 - Bone stock
Dyno 12 - T1R Intake + T1R Crank pulley +T1R 50S Cat-back exhaust
Dyno 19 - T1R Intake + T1R Crank pulley +T1R 50S Cat-back exhaust + T1R HEADER !!!!
Here the gains from DYNO 19 vs DYNO 12 :
3000rpm+1whp / +1 lbs
3500rpm+2whp / +2.5 lbs
4000rpm+4whp / +4.6 lbs
4500rpm+3.8whp / +3.8 lbs
5000rpm+2.6whp / +2.2 lbs
5500rpm+2.8whp / +3 lbs
6000rpm+1.07whp / +1.2 lbs
6500rpm+ 0whp / + 0 lbs
Here's DYNO 1 vs DYNO 19 :
3000rpm+3.5whp / +4.2 lbs
3500rpm +6.8whp / +8.2 lbs
4000rpm +8.3whp / +8.7 lbs
4500rpm+8.8whp / +8.5 lbs
5000rpm+10.1whp / +10 lbs
5500rpm +12.9whp / +8 lbs
6000rpm+13.9whp / +11.8 lbs
6500rpm+ 14.6whp / + 11.3 lbs
The 38mm piping on the header did biger difference. When we dynoed the 32mm header, the result was same as stock and we only gained a little bit of torque. After we installed the 38mm, we noticed a difference on the dyno right away.
Thanks
Ben
__________________
_________________________________________________
