Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > The Honda Fit and Jazz Forums > Fit Photos & Videos
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #1 (permalink)
Old 06-07-2009, 06:31 PM
mike410's Avatar
mike410 relies on Rep Points to livemike410 relies on Rep Points to livemike410 relies on Rep Points to livemike410 relies on Rep Points to livemike410 relies on Rep Points to livemike410 relies on Rep Points to livemike410 relies on Rep Points to livemike410 relies on Rep Points to livemike410 relies on Rep Points to livemike410 relies on Rep Points to livemike410 relies on Rep Points to live
My Headliner, Take 2
So this is my second headliner attempt (actually third, but tape as my second was temporary)
This was the first try:
I really like the material but it started to come down in some places after a short period of time. DON'T USE 3M SUPPER 77, unless you want it to come down.
Next I stripped the old material off the headliner and was left with the naked base
Then a headliner ghost appeard out of no where
Scary, huh? My friend and helper thought it would make a good haloween coustume.
Test fitting the material
Yes they are geckos
I then took some pictures of my roof deadening as I forgot to do so when I put it in
healiner glued on with contact cement
Finished pic along with the rest of the black interior
That is all. Hopefully it wont come down this time around. The contact cement is rated to 150+ degrees so it should be enough.
__________________
Sponsored Links
  #2 (permalink)
Old 06-07-2009, 06:33 PM
enjoito's Avatar
enjoito relies on Rep Points to liveenjoito relies on Rep Points to liveenjoito relies on Rep Points to liveenjoito relies on Rep Points to liveenjoito relies on Rep Points to liveenjoito relies on Rep Points to liveenjoito relies on Rep Points to liveenjoito relies on Rep Points to liveenjoito relies on Rep Points to liveenjoito relies on Rep Points to liveenjoito relies on Rep Points to live
Send a message via AIM to enjoito
oh mean the dope! haha geko's ftw
  #3 (permalink)
Old 06-07-2009, 06:36 PM
trancedsailor's Avatar
trancedsailor relies on Rep Points to livetrancedsailor relies on Rep Points to livetrancedsailor relies on Rep Points to livetrancedsailor relies on Rep Points to livetrancedsailor relies on Rep Points to livetrancedsailor relies on Rep Points to livetrancedsailor relies on Rep Points to livetrancedsailor relies on Rep Points to livetrancedsailor relies on Rep Points to livetrancedsailor relies on Rep Points to livetrancedsailor relies on Rep Points to live
Send a message via AIM to trancedsailor
That is totally awesome! Where did you find the design?
__________________
For Sale:: Progress swaybar, Weapon R trunk cage, right FX35 retrofit headlight. PM with offer if interested
1994 EG2 B16A3 acquired 9/3/09
  #4 (permalink)
Old 06-07-2009, 06:50 PM
mike410's Avatar
Quote:
I found it at one of the JoAnnes locally. It was in the giant clearance pile. It was $5 a yard which is a steal. On top of that I had a coupon for 10% off. If you are looking for something make sure that it is wide enough (forgot how wide it has to be but mine was 60in and I had plently left on the sides) and that it is not too thin. My material was a bit on the thin side. You need to be very careful with thin materials or the contact cement will go right through.
__________________
  #5 (permalink)
Old 06-07-2009, 09:04 PM
qbmurderer13's Avatar
Detailing Guru
qbmurderer13 relies on Rep Points to liveqbmurderer13 relies on Rep Points to liveqbmurderer13 relies on Rep Points to liveqbmurderer13 relies on Rep Points to liveqbmurderer13 relies on Rep Points to liveqbmurderer13 relies on Rep Points to liveqbmurderer13 relies on Rep Points to liveqbmurderer13 relies on Rep Points to liveqbmurderer13 relies on Rep Points to liveqbmurderer13 relies on Rep Points to liveqbmurderer13 relies on Rep Points to live
Ha those geckos are badass.
__________________
My Detail Threads
  #6 (permalink)
BoriJDMGD3's Avatar
Ihh IS Jaaaarome!
BoriJDMGD3 relies on Rep Points to liveBoriJDMGD3 relies on Rep Points to liveBoriJDMGD3 relies on Rep Points to liveBoriJDMGD3 relies on Rep Points to liveBoriJDMGD3 relies on Rep Points to liveBoriJDMGD3 relies on Rep Points to liveBoriJDMGD3 relies on Rep Points to liveBoriJDMGD3 relies on Rep Points to liveBoriJDMGD3 relies on Rep Points to liveBoriJDMGD3 relies on Rep Points to liveBoriJDMGD3 relies on Rep Points to live
looks good man...
__________________
KillerFit #6
I CLICK THROUGH GEARS !!!!
  #7 (permalink)
Old 06-07-2009, 09:11 PM
mike410's Avatar
Well since I wished there was a write up of when I did this the first time and from a PM I got, I decided to kind of put one together.
Headliner removal guide:
In this guide you will be taking many plastic panels off of your car. Myself nor FitFreak.net are not responsible if you break any clips or anything else during the process.
Tools needed:
phillips head screwdriver
very small eyeglass size flathead
torx screwdriver (I used a t20)
clip puller
metric sockets
a helper for a second set of hands is nice
Step 1: Remove the cover by the rear view mirror. Just slide it out forward toward the windshield.
Step 2: Remove the three phillips screws holding the rear view on, then remove the mirror
Step 3: Remove the two torx screws holding the sun visor on (you can also use a flathead instead)
Step 4: Remove the mount things for the sun visor by twisting them 90 degress in whichever direction is easier, then pulling down.
Step 5: Next is removing the A pillar. There isnt an easy way to do this. The top clip is damn near impossible to get out (someone know an easier way?). Removing the weatherstriping around the outside of the door frame in that area can help. Red dots are about where the clips are. The A pillar is two separate pieces if the bottom piece stays in just pull it out. It is held in by some small tabs. Repeat for the other side.
Step 6: Remove the "Oh-Shit" handles. remove the covers on both sides with the small flathead. then remove the phillips screw on each side. Repeat for the other three.
Step 7: Remove the top part of the panel below the B pillar. Pull outwards on the area that the seat belt comes out of. Then pull the bottom of the B pillar outwards to remove the clip. Then you can just slide them down a bit so they are out of the way. This red dot is the only clip location on the B pillar. Repeat for the other side.
Step 8: Remove the dome light by first removing the inner clear plastic piece with a small flathead. Then remove the two phillips screws shown by the red dots. Then disconnect the wiring connector from the assembly.
Step 9: Remove the plastic covering for the middle seat belt. I think there is only one clip in the area that I marked red. Either way it is easy to get out. Then remove the plastic frame if it does not come off with the first piece.
Step 10: Remove the other plastic covering shown. The red dot shows where the clip is (it could be on another corner but I think its right)
Step 11: Remove the rear seat belts. First remove the plastic piece that covers where the bolt is near the C pillar. Then remove the bolt with a 15mm socket. Repeat for the other side
Step 12: Remove the C pillar. First remove the two phillips screws shown by the yellow dots. Then pull the lower panel outwards. pop the clips out of place, shown as red dots, and then the panel should be able to come out downward. Repeat for the other side.
Step 13: Remove the headliner. The front is too wide to come out of the hatch. It takes a little convincing to squeeze it out.
I hope that was all the steps that are necessary to remove the headliner. If anyone feels that I should add a step somewhere feel free to let me know and I will change it. Also if more or better (not at dusk) pictures are needed feel free to ask and I will take them.
__________________
  #8 (permalink)
Old 06-07-2009, 11:10 PM
Cat's Avatar
Cat Cat is offline
Cat relies on Rep Points to liveCat relies on Rep Points to liveCat relies on Rep Points to liveCat relies on Rep Points to liveCat relies on Rep Points to liveCat relies on Rep Points to liveCat relies on Rep Points to liveCat relies on Rep Points to liveCat relies on Rep Points to liveCat relies on Rep Points to liveCat relies on Rep Points to live
Wow pretty cool looking and what a great choice of patterns.
Cat :x
__________________
Got me feelin' so Fly!
  #9 (permalink)
Old 06-08-2009, 02:12 AM
nxtfit_08's Avatar
nxtfit_08 relies on Rep Points to livenxtfit_08 relies on Rep Points to livenxtfit_08 relies on Rep Points to livenxtfit_08 relies on Rep Points to livenxtfit_08 relies on Rep Points to livenxtfit_08 relies on Rep Points to livenxtfit_08 relies on Rep Points to livenxtfit_08 relies on Rep Points to livenxtfit_08 relies on Rep Points to livenxtfit_08 relies on Rep Points to livenxtfit_08 relies on Rep Points to live
looks good and good diy i cant wait to be able to do mine soon!
__________________
  #10 (permalink)
Old 06-08-2009, 02:23 AM
denice25 relies on Rep Points to livedenice25 relies on Rep Points to livedenice25 relies on Rep Points to livedenice25 relies on Rep Points to livedenice25 relies on Rep Points to livedenice25 relies on Rep Points to livedenice25 relies on Rep Points to livedenice25 relies on Rep Points to livedenice25 relies on Rep Points to livedenice25 relies on Rep Points to livedenice25 relies on Rep Points to live
that's was cool man.... nice..
__________________
"thanE"
  #11 (permalink)
Old 06-08-2009, 05:18 AM
LiL Wee FIT will become famous soon enough
Nice headliner! Did the roof deadening make much of a difference?
__________________
www.torontofits.com
  #12 (permalink)
Old 06-08-2009, 09:51 AM
MarkyMark's Avatar
MarkyMark relies on Rep Points to liveMarkyMark relies on Rep Points to liveMarkyMark relies on Rep Points to liveMarkyMark relies on Rep Points to liveMarkyMark relies on Rep Points to liveMarkyMark relies on Rep Points to liveMarkyMark relies on Rep Points to liveMarkyMark relies on Rep Points to liveMarkyMark relies on Rep Points to liveMarkyMark relies on Rep Points to liveMarkyMark relies on Rep Points to live
Looks good bro. Yeah don't use 3M Super 77. If you have to use a 3M spray adhesive, use the super 90. I would recommend contact cement to people wanting to do this.
__________________
Like Cube said, "If I hit the switch, I can make the ass drop...."
  #13 (permalink)
Old 06-08-2009, 10:52 AM
score04w relies on Rep Points to livescore04w relies on Rep Points to livescore04w relies on Rep Points to livescore04w relies on Rep Points to livescore04w relies on Rep Points to livescore04w relies on Rep Points to livescore04w relies on Rep Points to livescore04w relies on Rep Points to livescore04w relies on Rep Points to livescore04w relies on Rep Points to livescore04w relies on Rep Points to live
this may sound like a stupid question, but all you guys are talking about being careful with the gluing part, how do you exactly glue the new fabric up without messing it up
__________________
  #14 (permalink)
Old 06-08-2009, 11:18 AM
dewthedew's Avatar
Fit Moderator
dewthedew relies on Rep Points to livedewthedew relies on Rep Points to livedewthedew relies on Rep Points to livedewthedew relies on Rep Points to livedewthedew relies on Rep Points to livedewthedew relies on Rep Points to livedewthedew relies on Rep Points to livedewthedew relies on Rep Points to livedewthedew relies on Rep Points to livedewthedew relies on Rep Points to livedewthedew relies on Rep Points to live
Send a message via AIM to dewthedew
did you paint the interior panels black?
  #15 (permalink)
Old 06-08-2009, 12:28 PM
mike410's Avatar
Thanks for all comments everyone
The roof deadening helps a good amount in my opinion. The roof is very solid now. It still has some movement to it with my system turned up, but way less that it had before.
If you have access to an air compressor and a spray gun, spraying the contact cement on both surfaces would be the easiest and give the lowest chance of it seeping through the material. I brushed mine on since I do not have an air compressor at school. I just took my time and worked on reasonable sized sections at a time.
Yes I painted my interior panels black. It changes the whole feel of the inside along with the dark headliner.
__________________
  #16 (permalink)
Old 06-08-2009, 12:39 PM
can you buy spray can contact cement?
__________________
  #17 (permalink)
Old 06-08-2009, 12:49 PM
mike410's Avatar
not that I am aware of. 3M Supper 90 would probably be the closest thing that is readily available. I havent used it, but I will never use a adhesive out of a aerosol can again.
__________________
  #18 (permalink)
Old 06-08-2009, 01:09 PM
hahaha enough said, just anxious to do this now
__________________
  #19 (permalink)
Old 06-08-2009, 01:37 PM
MarkyMark's Avatar
Brush on contact cement in 12" square sections at a time, put it on both the material and the headliner.
__________________
  #20 (permalink)
Old 06-08-2009, 01:39 PM
thanks for the help
__________________
Reply
Tags
2007, 3m, apillar, car, cement, contact, coral, fit, florida, headliner, honda, removal, remove, repair, springs, sun, visor
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Antenna base replacement and headliner removal Iridium 2nd Generation (GE 08-present) 1 12-07-2008 01:00 AM
Damn kids, someone help me with my headliner removal jrzy2nr Fit Exterior Modifications & JDM Styling 1 08-10-2008 10:55 PM
2008 Headliner Removal runbikerun Fit DIY: Repair & Maintenance 8 01-11-2008 06:19 PM
Headliner leak? whiz General Fit Talk 2 02-17-2007 08:25 PM
removal of headliner 07 Fit? tj_boof General Fit Talk 11 05-25-2006 02:55 PM
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
