Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > Fit Trix > Fit Shoes
Fit Shoes
Discuss Wheels & Tires for the Fit and Jazz
Forum Sponsor: Tire Rack
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #821 (permalink)
Old 12-01-2008, 09:05 PM
if the shoe FITs...'s Avatar
if the shoe FITs... relies on Rep Points to liveif the shoe FITs... relies on Rep Points to liveif the shoe FITs... relies on Rep Points to liveif the shoe FITs... relies on Rep Points to liveif the shoe FITs... relies on Rep Points to liveif the shoe FITs... relies on Rep Points to liveif the shoe FITs... relies on Rep Points to liveif the shoe FITs... relies on Rep Points to liveif the shoe FITs... relies on Rep Points to liveif the shoe FITs... relies on Rep Points to liveif the shoe FITs... relies on Rep Points to live
Quote:
Originally Posted by Fittuner08 View Post
Im looking at some Ce28N replicas that are 15/6.5 with a 40mm offset. what would be the best tire size to get without rubbing.
205/55/15 id say thats the best
__________________
RAMALAMADINGDONG
  #822 (permalink)
Old 12-02-2008, 12:16 AM
Fittuner08 is an unknown quantity at this point
tires
didn't you say thogh that you have that same size and that you are rubbing??
  #823 (permalink)
Old 12-02-2008, 12:24 AM
whoops my bad...205/50/15...yeah...not 55. 50's is what im getting they should be fine my 55 only rubs when i take a VERY hard turn...but there is no uneven wear on my tires still...an not to mention remember mines a 2 inch drop so u should still be fine with 55 anyways unless urs is 2in also...
__________________
RAMALAMADINGDONG
  #824 (permalink)
Old 12-02-2008, 09:23 AM
Premium Honda FIT Vendor
jim@tirerack is on a distinguished road
The best size tire would be either a 195/55R15 or 205/50R15. If I can help with the tires let me know.
__________________
Jim@tirerack.com
800-428-8355 ext 364
Performance Specialist
  #825 (permalink)
Old 01-14-2009, 08:44 PM
FiT4Kim's Avatar
FiT4Kim relies on Rep Points to liveFiT4Kim relies on Rep Points to liveFiT4Kim relies on Rep Points to liveFiT4Kim relies on Rep Points to liveFiT4Kim relies on Rep Points to liveFiT4Kim relies on Rep Points to liveFiT4Kim relies on Rep Points to liveFiT4Kim relies on Rep Points to liveFiT4Kim relies on Rep Points to liveFiT4Kim relies on Rep Points to liveFiT4Kim relies on Rep Points to live
I have a 09 sport with stock suspension and was wanting to get new rims 16x7 +43offset, what tire size would be best?
  #826 (permalink)
Old 01-14-2009, 08:47 PM
You can run either a 185/55R16 or 205/50R16 no problem. If I can help with the tires let me know.
__________________
Jim@tirerack.com
  #827 (permalink)
Old 01-14-2009, 09:57 PM
FiT4Kim's Avatar
sent you an email
  #828 (permalink)
Old 02-03-2009, 11:20 AM
Type 100's Avatar
Type 100 relies on Rep Points to liveType 100 relies on Rep Points to liveType 100 relies on Rep Points to liveType 100 relies on Rep Points to liveType 100 relies on Rep Points to liveType 100 relies on Rep Points to liveType 100 relies on Rep Points to liveType 100 relies on Rep Points to liveType 100 relies on Rep Points to liveType 100 relies on Rep Points to liveType 100 relies on Rep Points to live
Send a message via MSN to Type 100 Send a message via Yahoo to Type 100
Has anyone run "reinforced" tires? What pressures do you use?
I run Toyo Proxes 4s, 205/45ZR16 87W reinforced. As far as I can understand, the "reinforced" tires can take more weight (my old ones were load-/speed-rated 83V) but have to be inflated about 5 psi more than normal. So basing from the doorjamb reading 32 psi front/30 psi rear, and the +5 psi rule, I should be running 37 psi front/35 psi rear.
Anyone else on reinforced tires? Would like to see if we run similar pressures. Ride quality suffers a little due to the higher air pressure in my rubber.
__________________
Meet my Aibo: 2005 GD1 Honda Jazz 1.3S
Fit4Trav got it right: REAL FRIENDS > CAR CLUBS
  #829 (permalink)
Old 03-10-2009, 01:32 AM
runbikerun's Avatar
runbikerun relies on Rep Points to liverunbikerun relies on Rep Points to liverunbikerun relies on Rep Points to liverunbikerun relies on Rep Points to liverunbikerun relies on Rep Points to liverunbikerun relies on Rep Points to liverunbikerun relies on Rep Points to liverunbikerun relies on Rep Points to liverunbikerun relies on Rep Points to liverunbikerun relies on Rep Points to liverunbikerun relies on Rep Points to live
I can't decide. My goals are better mileage and a quieter ride than my stock dunlop 16s. Any recomendations?
__________________
09 Crystal Black SPORT
  #830 (permalink)
Old 03-10-2009, 12:55 PM
I am not sure that I can get you better ride quality. I can get you better handling and longer tread life. I would look at going with a 205/50R16 in the size. It is going to be a little wider and the same height.
If I can help let me know.
__________________
Jim@tirerack.com
  #831 (permalink)
Old 03-15-2009, 07:55 PM
qbmurderer13's Avatar
Detailing Guru
qbmurderer13 relies on Rep Points to liveqbmurderer13 relies on Rep Points to liveqbmurderer13 relies on Rep Points to liveqbmurderer13 relies on Rep Points to liveqbmurderer13 relies on Rep Points to liveqbmurderer13 relies on Rep Points to liveqbmurderer13 relies on Rep Points to liveqbmurderer13 relies on Rep Points to liveqbmurderer13 relies on Rep Points to liveqbmurderer13 relies on Rep Points to liveqbmurderer13 relies on Rep Points to live
What tire can you recommend for me in 205/50R16? Looking for the perfect balance of price, performance and treadwear. Comfort isnt a deal breaker for me. Price will be though. Sorry I know its a pretty vague question.
__________________
My Detail Threads
  #832 (permalink)
Old 03-16-2009, 02:48 AM
MINI-Fit's Avatar
Frequent FitFreak Poster
MINI-Fit relies on Rep Points to liveMINI-Fit relies on Rep Points to liveMINI-Fit relies on Rep Points to liveMINI-Fit relies on Rep Points to liveMINI-Fit relies on Rep Points to liveMINI-Fit relies on Rep Points to liveMINI-Fit relies on Rep Points to liveMINI-Fit relies on Rep Points to liveMINI-Fit relies on Rep Points to liveMINI-Fit relies on Rep Points to liveMINI-Fit relies on Rep Points to live
Quote:
Normally we look at 204/45-16 as the size for the FIT.
However 205/50-16 will be a little tall at 24.1" tire diameter but still work with the stock suspension. 50 series sidewall will allow for a little more comfort.
For good price, decent performance, and longer treadwear-
General Exclaim UHP $78 each, 380 treadwear
Fusion ZRi $82 each, 320 treadwear
Kumho Ecsta SPT $80 each, 320 treadwear
Yokohama S.Drive $91 each, 300 treadwear
  #833 (permalink)
Old 03-16-2009, 03:05 AM
Detailing Guru
Well considering the stock tire diameter is 24.0" I think 24.1" will be better than the 23.3" diameter of the 205/45...
__________________
My Detail Threads
  #834 (permalink)
Old 03-16-2009, 04:49 AM
MINI-Fit's Avatar
I think we have different year Fits-
I was referring to stock tire size on 2007-2008 Fit Sport
see
Fit Sport tire fitment question...
Post #9
Stock tire diameter 23.4". 195/55-15
For 2009 Fit Sport
16" wheels and 185/55-16 tires 24.2" tire diameter
  #835 (permalink)
Old 03-16-2009, 04:55 AM
Detailing Guru
Yeah I have an 09, stock tire size is 185/55R16.
__________________
My Detail Threads
  #836 (permalink)
Old 03-16-2009, 11:04 AM
In the 205/50R16 if you are looking for longer tread life I would go with an all season tire. You will loose some performance to gain the tread life. I would take a look at the Goodyear GT at 89.00 each. If you stay with a longer wearing performance tire I would look at the General Exclaim UHP at 78.00 each.
__________________
Jim@tirerack.com
  #837 (permalink)
Old 03-16-2009, 12:08 PM
Detailing Guru
Those generals look like the winner, thanks!
__________________
My Detail Threads
  #838 (permalink)
Old 03-16-2009, 01:24 PM
If you order online just enter my name as a previous contact and I will get them on the way.
Thank you ,
__________________
Jim@tirerack.com
  #839 (permalink)
Old 03-16-2009, 01:40 PM
Detailing Guru
Quote:
Thank you ,
Ill be ordering them in about 2 weeks but ill put your name down, thanks.
__________________
My Detail Threads
  #840 (permalink)
Old 03-18-2009, 01:33 PM
runbikerun's Avatar
This is probably a really dumb question for all of you that know this stuff. Would there be an reason or advantage for me to go to a 15" wheel instead of my stock 16's? This is my daily commuter car. I will never hit a track. Is there a reason that one size 15, 16 or even 17 is better than another?
__________________
Reply
Tags
15, 185, 205, 55, exalto, fitting, lancer, mileage, pe2, questions, resistance, rolling, size, tire, tires, width
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
