Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > Fit Trix > Fit Shoes
Fit Shoes
Discuss Wheels & Tires for the Fit and Jazz
Forum Sponsor: Tire Rack
Welcome to Fit Freak!
Welcome to Fit Freak,
View Poll Results: Which Wheels would you buy
Voxx MG 27 39.71%
MB Drifter 41 60.29%
Voters: 68. You may not vote on this poll
Reply
  #21 (permalink)
Old 07-06-2005, 01:36 AM
Dojo is on a distinguished road
SR20jet,
The offset for the stock 6J/15" wheels is +53mm.
I was looking at this Ings Honda Fit. It looks like it has '04-05 S2000 rims.
Looks nice!
  #22 (permalink)
Old 07-06-2005, 01:51 AM
sr20jet's Avatar
sr20jet is on a distinguished road
Whoa....the offset on these FIT's are high, this is no Suby. With this in mind, the FIT can run 7" width wheels with an offset of 45mm-48mm or a 6.5" width with a 50mm offset.
Are the offset the same for the 14's factory wheels too?
__________________
JET-OUT
A Hopeful Future US F.I.T. Owner
My Daily Driver (Pic Update 10/31/05)
  #23 (permalink)
Old 07-06-2005, 02:30 AM
sr20jet's Avatar
Also there are not many aftermarket wheel support with very high offsets. Most popular aftermarket wheel applications today are around the 40mm and lower offset.
__________________
JET-OUT
  #24 (permalink)
Old 07-06-2005, 09:36 AM
sr20Jet,
I agree that there aren't too many wheels in the offset range required for the Fit. In Japan some guys run 5 mm spacers to bring the offset up so they can run popular rims. I'll post some of the Rims that fit the Fit later today.
D
  #25 (permalink)
Old 07-06-2005, 04:51 PM
sr20jet's Avatar
Guess the only thing would be ideal is to use 5mm or 10mm spacers to get that high offset.
__________________
JET-OUT
  #26 (permalink)
Old 07-06-2005, 05:04 PM
ken1279 is on a distinguished road
Ah... so the 15s have a 53mm offset. That's why I having problems.
  #27 (permalink)
Old 07-06-2005, 05:20 PM
sr20jet's Avatar
Ken, what width and offset are you using on your car?
__________________
JET-OUT
  #28 (permalink)
Old 07-06-2005, 05:47 PM
Quote:
The width is 6.5 and offset is 40.
  #29 (permalink)
Old 07-06-2005, 05:57 PM
sr20jet's Avatar
Try running 8mm or 10mm spacers to see if that solves your rubbing problem.
__________________
JET-OUT
  #30 (permalink)
Old 07-06-2005, 07:11 PM
Hmm... Question? This would make the wheels go out right? So if I put 10mm spacers, my new offset would be 30?
  #31 (permalink)
Old 07-06-2005, 07:28 PM
sr20jet's Avatar
Quote:
No, it will push the offset to more positive, so it will be 50mm. Your wheel will be more flush with the fenders.
__________________
JET-OUT
  #32 (permalink)
Old 07-06-2005, 07:35 PM
You're right.
But the rubbing problem that I am encountering is not inside the wheel but with a screw inside the rear fender that holds the bumper. This is the same problem with Myx. I was thinking of getting 185/55/R15 tires instead of 195/55/R15 to solve this.
  #33 (permalink)
Old 07-06-2005, 07:41 PM
sr20jet's Avatar
Ken, since you are running 195/55/15's, you have a slight taller overall wheel diameter from stock. I'm assuming you had the 14" wheel option?
Rule of thumb when widening your tire width is to go down on the aspect ratio and you stayed within the ratio of 55. Try running either 195/50's or 195/45's.
__________________
JET-OUT
  #34 (permalink)
Old 07-06-2005, 08:12 PM
sr20jet's Avatar
Ken, you are actually right. Using a spacer will bring down the offset to 30mm, not raise the offset.
__________________
JET-OUT
  #35 (permalink)
Old 07-06-2005, 10:01 PM
Ken,
The stock size 14" wheel is 5.5J/14 with +45 offset.
Yeah, your right about the offsets and that explains why you have some rubbing in the rear of your fit.
Some guys in Japan get wider rear tires to fit by bending and triming the sheetmetal where the rear bumper attaches.
Maybe this picture will help show the problem.
But this screw is the real problem that has to be dealt with if you want to have tires that fill out the wheel well or large sizes like 18"s.
D
  #36 (permalink)
Old 07-07-2005, 02:41 AM
sr20jet's Avatar
That's a heck of a difference in offset between the 2 factory FIT/Jazz alloys. I'm assuming Ken's car was equipped with the 14" alloys, then he's good with the setup he has right now. Only the tires overall diameter is giving him problems. Go with what I suggested above, try same width tire but lower sidewall ratio, 50 or 45.
__________________
JET-OUT
  #37 (permalink)
Old 07-07-2005, 01:51 PM
I don't think it's the diameter that causing the problem. I think it's the width of tires. I'm still within 3% of the original diameter of the stock 14" alloys. I'll just use up my tires then I'll switch to 185/55/R15 and see if this helps.
  #38 (permalink)
Old 07-07-2005, 01:57 PM
Quote:
Originally Posted by Dojo
Ken,
D
Wow! Where did you find this info? I was thinking of doing this but I don't want to touch the sheet metal. Thanks for all the suggestions guys!
  #39 (permalink)
Old 07-07-2005, 03:18 PM
sr20jet's Avatar
Ken, even if you go to a 195/50-15(22.68 inches tire/wheel dia.), the overall diameter is 3/4 less from the over diameter of 195/55-15(23.44 tire/wheel dia.).
__________________
JET-OUT
  #40 (permalink)
Old 07-07-2005, 06:26 PM
Ken,
I got the pics from a Japanese Fit site, EuroFit-R . I used to live in Japan and can read and speak a bit of Japanese, I'm sorry to say better than Tagalog. My relatives in the PI wonder about me.
But on another note, all the sheetmetal you would want to trim is not visible unless the wheel is off and you look inside the fender. Just remember to prime and seal any metal after you grind places down. On one website a guy tried putting on 195/50/15 tires on 6.5J/15 +38 rims and had the same rubbing problems. He ended up with 185/55/15 tires and had no problems and didn't have to modify the inner fender area. But he ended up changing to 195/45/16 tires on 7.5J/16 +38 rims
Comparison of stock 175/65/14 next to 195/45/15 tires. If you are going to stay with 15" wheels I would get the 185/55/15 tires.
D
Reply
Tags
1954017, 40, fit, hfp, hieght, honda, hpo, low, mg, offset, rims, ss7, stock, voxx, weigh, wheel, xtatik
« Help!! | Question.. »
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Window Louvers, visors, photos, questions, installation, answers j_gusani80@hotmail.com Fit Exterior Modifications & JDM Styling 201 11-18-2009 07:57 AM
How to clean the interior? With questions, answers and suggestions sLiVeRwOrM Fit Care 98 09-07-2009 11:19 PM
Floor Mats, questions, answers, recomendations stacey14 Fit Interior Modifications 213 10-28-2008 03:52 PM
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
