Fit FREAK.net
Go Back   Honda FIT Forums > Fit Trix > Fit Shoes
Fit Shoes
Discuss Wheels & Tires for the Fit and Jazz
Forum Sponsor: Tire Rack
View Poll Results: Which Wheels would you buy
Voxx MG 23 39.66%
MB Drifter 35 60.34%
Voters: 58. You may not vote on this poll
Reply
  #1261 (permalink)
Old 02-11-2008, 11:42 AM
Platinum Honda FIT Vendor
jim@tirerack is on a distinguished road
mnapuran,
There is room in the wheel well to fit bigger wheels and tires than stock. With the wider wheel the offset is lower to move the wheels away from the brakes. Everything we list on our web site for wheels has been tested and we know will fit.
If I can help let me know.
__________________
Jim@tirerack.com
800-428-8355 ext 364
Performance Specialist
  #1262 (permalink)
Old 02-11-2008, 12:30 PM
mnapuran's Avatar
Senior Member
mnapuran will become famous soon enough
Quote:
Originally Posted by jim@tirerack View Post
mnapuran,
I understand.. but that really doesn't answer the question of why Honda uses a larger offset, and those using them haven't had rubbing problems.
The real issue seems to be that most companies aren't making wheels with a similar offset, and the closest most DO make are 40mm or so. This doesn't make it fit right... it just makes it fit as close as it can given the wheel manufacturers limited options.
__________________
Mike N - My Blog
FXOL / MobileImage - Live Fit Chat
Custom decals, Full color printing, and more!
'08 Fit Sport | '98 Grand Prix GTP | '07 CBR 600 RR | '01 Suz DRZ-400 SM
  #1263 (permalink)
Old 02-19-2008, 11:10 PM
davela72 has a spectacular aura aboutdavela72 has a spectacular aura about
Jim, whats your thoughts on running a 195/45/16? This would be with a 16x7 wheel.
thanks!
__________________
'08 SSM Sport 5MT
  #1264 (permalink)
Old 02-21-2008, 02:05 AM
dank24's Avatar
dank24 is a jewel in the roughdank24 is a jewel in the roughdank24 is a jewel in the roughdank24 is a jewel in the rough
I know this is a tire/wheel thread. But I got questions on both + springs. I have 16x7 w/ a 38mm offset. What springs and tires would work best without rubbing at all?
__________________
I sell HIDs, Plug and Play. Great prices shipped. PM me for more info.
  #1265 (permalink)
Old 02-21-2008, 12:11 PM
The best tire size would be 205/45R16. You should be fine with that wheel and tire combination. I would say the Eibach Pro Kit would be a nice set up. You would have about 1.5" front and 1.3" rear drop but you can still align the car and use the OE shocks.
__________________
Jim@tirerack.com
  #1266 (permalink)
Old 02-21-2008, 04:00 PM
Tofuman's Avatar
Tofuman has a brilliant futureTofuman has a brilliant futureTofuman has a brilliant futureTofuman has a brilliant futureTofuman has a brilliant futureTofuman has a brilliant futureTofuman has a brilliant futureTofuman has a brilliant futureTofuman has a brilliant futureTofuman has a brilliant futureTofuman has a brilliant future
hi jim,
i'm looking for super light weight rims and tires. i'm looking at 14"-15" wheels. i saw the kosei k1 ts in 14". what other rims do you recommend. and what is the widest tire i could run on these wheels? i will be dropping the car about 1.5 F, 1.3 R
Thanks!!
__________________
  #1267 (permalink)
Old 02-21-2008, 06:42 PM
The K1-TS is 14X6 and 9.3 lbs. You can run a 185/60R14 or 195/60R14 on that car. You should not have any problems even with the car lowered.
The Enkei RPF1 is the lightest 15" I have at 15X7 and 9.5 lbs. The tire size would be 195/55R15 or 205/50R15.
If I can help just let me know.
__________________
Jim@tirerack.com
  #1268 (permalink)
Old 02-22-2008, 12:36 PM
diedwater has a spectacular aura aboutdiedwater has a spectacular aura about
I have read thro this thread, but it seems that there are a couple mixed opinion on what rubs....
I m looking at a set of
16 x 7 / 40 rims, so with 205/45/16 I shouldn't be rubbing right? what about after lowering, say with skunk2 springs?
what if I go down to 15 x 6.5 / 40 with 195/50/15? is that a pretty safe bet, or still might be rubbing?
  #1269 (permalink)
Old 02-22-2008, 01:59 PM
mnapuran's Avatar
Senior Member
died.. those wheels w/ a 40 offset WILL rub
__________________
Mike N - My Blog
  #1270 (permalink)
Old 02-22-2008, 02:18 PM
alexfree05's Avatar
Frequent FitFreak Poster
alexfree05 relies on Rep Points to livealexfree05 relies on Rep Points to livealexfree05 relies on Rep Points to livealexfree05 relies on Rep Points to livealexfree05 relies on Rep Points to livealexfree05 relies on Rep Points to livealexfree05 relies on Rep Points to livealexfree05 relies on Rep Points to livealexfree05 relies on Rep Points to livealexfree05 relies on Rep Points to livealexfree05 relies on Rep Points to live
I have a set of rims in size 16x7 42 offset, with lowered 1.8F 1.3R
what size of tire i could run on these wheels?
thanks!!
  #1271 (permalink)
Old 02-22-2008, 04:33 PM
Quote:
what about 15 x 6.5 / 38 offset and 195/50/15 ?
16 x 7 / 38 offset 205/50/16 ?
if not what offset should I be looking at? and what tire?
Thank you for the help!
  #1272 (permalink)
Old 02-23-2008, 04:38 PM
The offset would be better in the low 40's for the most clearance. Try a tire size 205/45R16 for the most clearance. If you have a little rubbing you can always roll the fender lips or run a little more negative camber.
If I can help with the wheels and or tires let me know.
__________________
Jim@tirerack.com
  #1273 (permalink)
Old 02-23-2008, 09:21 PM
alexfree05's Avatar
hi jim
thanks!!
  #1274 (permalink)
Old 02-23-2008, 09:29 PM
MINI-Fit's Avatar
MINI-Fit will become famous soon enough
Quote:
Originally Posted by alexfree05 View Post
hi jim
thanks!!
For you, 205/45-16 it's very close to stock height.
205/40-16 is also possible, fits rims 7-8" wide best. It's smaller than stock tire diameter for more clearance. Stiffer ride and more potential risk of rim damage from hitting potholes.
For 15 x 6.5 / 38 offset and 195/50/-15, that's fine. Even 15x7 +38 offset will work with 195/50-15
  #1275 (permalink)
Old 02-24-2008, 01:05 AM
alexfree05's Avatar
ok thanks a lot
so i will choose 205/45-16
  #1276 (permalink)
Old 02-25-2008, 08:59 AM
They are correct. The right size would be 205/45R16. They should fit with no problems. If I can help with the tires let me know.
__________________
Jim@tirerack.com
  #1277 (permalink)
Old 02-25-2008, 01:03 PM
alexfree05's Avatar
my friend told me to choose Toyo,
is that good?
  #1278 (permalink)
Old 02-25-2008, 01:33 PM
smatts's Avatar
Honda Fit Forums Moderator
smatts has a spectacular aura aboutsmatts has a spectacular aura about
HFP 16x6.5 inch wheels +55 offset. 205/45/16 tires. Lowered on T1R V2 S-Coil springs. No rubbing, with 5 people in the car.
__________________
Blaze Orange Julep
Montreal, QC
  #1279 (permalink)
Old 02-25-2008, 02:21 PM
I would ask your friend why he recommended that tire? How many tires as he tested on the car. What he looks for out of a tire. I don't carry the Toyo so I could not say one way or the other. I do have a number of options in the 16" for the car.
__________________
Jim@tirerack.com
  #1280 (permalink)
Old 02-25-2008, 07:10 PM
alexfree05's Avatar
it is because he is using Toyo on his xB, and he said it is from Japan...
IMO, I would choose Falken.
Reply
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Window Louvers, visors, photos, questions, installation, answers j_gusani80@hotmail.com Fit Bodywork & JDM Styling 186 11-02-2008 08:43 PM
Floor Mats, questions, answers, recomendations stacey14 Fit Inside 213 10-28-2008 03:52 PM
How to clean the interior? With questions, answers and suggestions sLiVeRwOrM Fit Care 97 10-15-2008 01:15 PM
Go
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
