Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > Fit Trix > Fit Shoes
Fit Shoes
Discuss Wheels & Tires for the Fit and Jazz
Forum Sponsor: Tire Rack
Welcome to Fit Freak!
Welcome to Fit Freak,
View Poll Results: Which Wheels would you buy
Voxx MG 27 39.71%
MB Drifter 41 60.29%
Voters: 68. You may not vote on this poll
Reply
  #1361 (permalink)
Old 08-24-2008, 11:09 PM
crosshockey12 is an unknown quantity at this point
seems like there is alot of knowledge in here SO PLEASE HELP.
I've decided I want to go with a 16x7 wheel. i have seen a 40 and 43 offset in some wheels I like. I also plan on putting the eibach pro kit on it which is i believe 1.5 in the front and 1" drop in the rear. and I would be running 205/45/16. can anyone tell me if im going to be rubbing or..?
thanks so much in advance for the help.
also a larger positive offset (ie +43 over +38) would mean the wheel sticks further out from the fenderwell, am I correct?
  #1362 (permalink)
Old 08-24-2008, 11:28 PM
MNfit's Avatar
MNfit relies on Rep Points to liveMNfit relies on Rep Points to liveMNfit relies on Rep Points to liveMNfit relies on Rep Points to liveMNfit relies on Rep Points to liveMNfit relies on Rep Points to liveMNfit relies on Rep Points to liveMNfit relies on Rep Points to liveMNfit relies on Rep Points to liveMNfit relies on Rep Points to liveMNfit relies on Rep Points to live
I think you will be alright with that set up im running the same tire size with a +42 and dont rub. For offset the lower the number, the farther it will stick out from the Fender.
__________________
KRAFTWERKS Kit Owner #13
  #1363 (permalink)
Old 08-26-2008, 01:04 PM
Premium Honda FIT Vendor
jim@tirerack is on a distinguished road
The 16X7 wheels would be fine with the 205/45R16. If you are lowering the car you may need to run a little more negative camber. If I can help let me know.
__________________
Jim@tirerack.com
800-428-8355 ext 364
Performance Specialist
  #1364 (permalink)
Old 08-26-2008, 10:17 PM
cdezspykez's Avatar
cdezspykez is an unknown quantity at this point
Send a message via AIM to cdezspykez
how far would 6.5 and 35 offset stick out?
__________________
  #1365 (permalink)
Old 08-27-2008, 10:35 AM
docjim2's Avatar
docjim2 is on a distinguished road
Well Done!!
__________________
2000 Accord Coupe v6
Eibach Sport springs; Eibach camber kits; custom cat back; Honda 17in wheels w 225 45 X 17 Toyo P4's; AEM short ram ; Pass 8500 X50 radar
2007 Fit Base Vivid Blue Pearl AT
17 ASA painted black w machine lip; 205-40X17 Fusion tires; iWay GPS 350c; Zeta sills; Mugen viser ; Cobra radar; blue accent shift knob ; tonneau cover, Zeta"dead pedal"; Megan racing cat back; Tanabe tower bar braces; pillar brace. K&N OEM filter
Please turn your head when you cough...
  #1366 (permalink)
Old 08-27-2008, 11:16 AM
thomasgrant is on a distinguished road
Here are some really resourceful links to use in educating yourself on wheel upgrades.
Good:
Wheel Offset Calculator
Even better:
http://www.rims-n-tires.com/rt_specs.jsp
  #1367 (permalink)
Old 08-27-2008, 06:21 PM
Quote:
what do you mean? like a 38 offset?
  #1368 (permalink)
Old 09-11-2008, 08:19 PM
evamph21 is an unknown quantity at this point
hey guys im looking into a set of BBS RS wheels. id really like to get some 17s, but im only finding them in 17x8. would a 17x8 with the right offset work? if so what offset would you guys recommend?
fender rolling wouldnt be a problem to correct any rubbing. id also be lowering the car at some point as well.
  #1369 (permalink)
Old 09-11-2008, 09:07 PM
SD_MR_FIT's Avatar
SD_MR_FIT relies on Rep Points to liveSD_MR_FIT relies on Rep Points to liveSD_MR_FIT relies on Rep Points to liveSD_MR_FIT relies on Rep Points to liveSD_MR_FIT relies on Rep Points to liveSD_MR_FIT relies on Rep Points to liveSD_MR_FIT relies on Rep Points to liveSD_MR_FIT relies on Rep Points to liveSD_MR_FIT relies on Rep Points to liveSD_MR_FIT relies on Rep Points to liveSD_MR_FIT relies on Rep Points to live
Send a message via AIM to SD_MR_FIT
you will definitely need to roll the rear fender. yo will get super close with the front fender, as long as you do the fender trick you should be fine.
but the rear....yeah either cut it off or roll it.
good luck. well the lower you get, the more the wheel cambers...and remember you have to BE SLAMMED to make 17's look good.
__________________
James- Phase 3 of make over in progress
  #1370 (permalink)
Old 09-11-2008, 09:44 PM
Honda-Tech.com: Honda Fit: 17x8 +40 Work Wheels
after some searching i found one guy that had 17x8s. wish the pics still worked.
offsets were et40 front, and et35 rear. does thats sound right?
  #1371 (permalink)
Old 09-11-2008, 11:23 PM
Benggolf's Avatar
Benggolf relies on Rep Points to liveBenggolf relies on Rep Points to liveBenggolf relies on Rep Points to liveBenggolf relies on Rep Points to liveBenggolf relies on Rep Points to liveBenggolf relies on Rep Points to liveBenggolf relies on Rep Points to liveBenggolf relies on Rep Points to liveBenggolf relies on Rep Points to liveBenggolf relies on Rep Points to liveBenggolf relies on Rep Points to live
I had 17 x 7 +35 Work Wheels all around with 205/40 x 17 tires and I did have rubbing issues in the back.
It also depends on how wide a tire you will be mounting. I suggest no less than +45 offset and you should be safe.
__________________
Benggolf
2009 SSM FiT Sports Aut.
For more details on mods done: http://www.yarisworld.com/forums/fun...o=view&id=1015
  #1372 (permalink)
Old 09-12-2008, 01:34 PM
awesome. thanks for your help.
  #1373 (permalink)
Old 09-13-2008, 04:43 PM
jdmallstar2000 is on a distinguished road
any chance of fitting a 16X7 +25 wheel with a 5mm spacer making it +20 fit with out rubbing? would i have to roll fenders?? im thinking of having pretty it low with lots of neg camber.. with a 195/50/16 tire any info would be great
  #1374 (permalink)
Old 09-15-2008, 10:54 AM
Evampj21,
Without doing fender modification I don't think you are going to make that wheel fit. I also don't ever remember them making a 4-100 bolt pattern in that wheel. They have been discontinued for a long time.
__________________
Jim@tirerack.com
  #1375 (permalink)
Old 09-15-2008, 10:57 AM
jdmallstar2000,
I would say that without pulling the fenders out the offset you are looking at will not work.
__________________
Jim@tirerack.com
  #1376 (permalink)
Old 09-21-2008, 06:50 PM
JaySmith's Avatar
JaySmith relies on Rep Points to liveJaySmith relies on Rep Points to liveJaySmith relies on Rep Points to liveJaySmith relies on Rep Points to liveJaySmith relies on Rep Points to liveJaySmith relies on Rep Points to liveJaySmith relies on Rep Points to liveJaySmith relies on Rep Points to liveJaySmith relies on Rep Points to liveJaySmith relies on Rep Points to liveJaySmith relies on Rep Points to live
Send a message via AIM to JaySmith Send a message via MSN to JaySmith Send a message via Yahoo to JaySmith
I currently own 17x7 +38 O.Z. F1 Cups, and was wondering if a 205/45/17 tire would rub without fender modification?
__________________
  #1377 (permalink)
Old 09-21-2008, 08:50 PM
mahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to live
No. The less the offset the further out from the hub the wheel will be. The greater offset moves the wheel inwards. The 16x7 wheel with 43 mm offset is good stock height with 205/45x16 tires but if you lower an 08 you will likely get rubbing.
If you are dropping an 08 then the 16x7/45 wheels and 25/45x16 tires are your choice.
  #1378 (permalink)
Old 09-22-2008, 09:14 AM
Hello Jay,
I hope you got my email. If I can help let me know.
__________________
Jim@tirerack.com
  #1379 (permalink)
Old 09-22-2008, 03:33 PM
JaySmith's Avatar
Hello Jay,
I did, thank you so very much. Your knowledgeable help was definitely appriciated.
__________________
  #1380 (permalink)
Old 09-23-2008, 06:27 PM
kancerr relies on Rep Points to livekancerr relies on Rep Points to livekancerr relies on Rep Points to livekancerr relies on Rep Points to livekancerr relies on Rep Points to livekancerr relies on Rep Points to livekancerr relies on Rep Points to livekancerr relies on Rep Points to livekancerr relies on Rep Points to livekancerr relies on Rep Points to livekancerr relies on Rep Points to live
i have 15x7.5/40 offset konig networks on the stock 07 sport tires. i am lowering the car on eibach sportline, 2.0" drop in the front and 1.8" drop in the rear.
i have been told i will rub. how will i need to go about fixing this once it is dropped? will i need to rent a fender roller of some sort and a heat gun?
this is the first time i have swapped out rims on a car and the first time lowering it. any help would be apperciated so i wont be suprised when i go to do the job. thanks.
Reply
Tags
1954017, 40, fit, hfp, hieght, honda, hpo, low, mg, offset, rims, ss7, stock, voxx, weigh, wheel, xtatik
« Help!! | Question.. »
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Window Louvers, visors, photos, questions, installation, answers j_gusani80@hotmail.com Fit Exterior Modifications & JDM Styling 201 11-18-2009 07:57 AM
How to clean the interior? With questions, answers and suggestions sLiVeRwOrM Fit Care 98 09-07-2009 11:19 PM
Floor Mats, questions, answers, recomendations stacey14 Fit Interior Modifications 213 10-28-2008 03:52 PM
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
