Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > Fit Trix > Fit Shoes
Fit Shoes
Discuss Wheels & Tires for the Fit and Jazz
Forum Sponsor: Tire Rack
Welcome to Fit Freak!
Welcome to Fit Freak,
View Poll Results: Which Wheels would you buy
Voxx MG 27 39.71%
MB Drifter 41 60.29%
Voters: 68. You may not vote on this poll
Reply
  #1541 (permalink)
Old 06-04-2009, 09:15 PM
SupaKingKoopa's Avatar
SupaKingKoopa relies on Rep Points to liveSupaKingKoopa relies on Rep Points to liveSupaKingKoopa relies on Rep Points to liveSupaKingKoopa relies on Rep Points to liveSupaKingKoopa relies on Rep Points to liveSupaKingKoopa relies on Rep Points to liveSupaKingKoopa relies on Rep Points to liveSupaKingKoopa relies on Rep Points to liveSupaKingKoopa relies on Rep Points to liveSupaKingKoopa relies on Rep Points to liveSupaKingKoopa relies on Rep Points to live
you think these dr20's will fit on a lowered fit? if so how much neg. camber on the rear and front?
specs are 15x7 +10
  #1542 (permalink)
Old 06-17-2009, 01:32 PM
Firefly's Avatar
Firefly relies on Rep Points to liveFirefly relies on Rep Points to liveFirefly relies on Rep Points to liveFirefly relies on Rep Points to liveFirefly relies on Rep Points to liveFirefly relies on Rep Points to liveFirefly relies on Rep Points to liveFirefly relies on Rep Points to liveFirefly relies on Rep Points to liveFirefly relies on Rep Points to liveFirefly relies on Rep Points to live
Quote:
Originally Posted by mahout View Post
Ideal is not the same as MINIMUM. If you use a wheel with offset LESS than 42 mm you have a 90% chance of interference unless you use a way too small width tire.
And yes, 45 mm is ideal because it gives some room to lower if not too much. At 42 mm if you lower you get interference..
Just a follow up on my posts & questions about fitment for 15x7 +38...
Taking a risk, I went with my original choice of wheel & bought XXR 501s in black; they are 15x7 +38 offset. I had them mounted on my stock Dunlops (15x6.5) and there are no rubbing issues so far. I am not lowered, but was told I could probably still do a moderate drop and be okay.
Thanks for everyones input.
Heres a pic of them on:
__________________
08 BOM FIT SPORT ~ BLACK LEATHER
  #1543 (permalink)
Old 06-21-2009, 09:08 PM
awptickes's Avatar
awptickes relies on Rep Points to liveawptickes relies on Rep Points to liveawptickes relies on Rep Points to liveawptickes relies on Rep Points to liveawptickes relies on Rep Points to liveawptickes relies on Rep Points to liveawptickes relies on Rep Points to liveawptickes relies on Rep Points to liveawptickes relies on Rep Points to liveawptickes relies on Rep Points to liveawptickes relies on Rep Points to live
Let's say that I've got some 225/50r15 slicks, what offset wheels do I need?
  #1544 (permalink)
Old 06-22-2009, 01:51 AM
Fit4Trav's Avatar
Fit4Trav relies on Rep Points to liveFit4Trav relies on Rep Points to liveFit4Trav relies on Rep Points to liveFit4Trav relies on Rep Points to liveFit4Trav relies on Rep Points to liveFit4Trav relies on Rep Points to liveFit4Trav relies on Rep Points to liveFit4Trav relies on Rep Points to liveFit4Trav relies on Rep Points to liveFit4Trav relies on Rep Points to liveFit4Trav relies on Rep Points to live
Send a message via MSN to Fit4Trav
Quote:
specs are 15x7 +10
My SSR mesh were 15x7 +13 and i rubbed alot w/ no passengers, I was pretty low on coilovers too.
__________________
REAL FRIENDS > CAR CLUBS
FROM SEMA:
Quote:
Originally Posted by Courtney Day
Offset is everything
http://autoimportcraze.com/
  #1545 (permalink)
Old 08-02-2009, 06:13 PM
Likwid is infamous around these partsLikwid is infamous around these partsLikwid is infamous around these partsLikwid is infamous around these partsLikwid is infamous around these partsLikwid is infamous around these partsLikwid is infamous around these partsLikwid is infamous around these partsLikwid is infamous around these partsLikwid is infamous around these partsLikwid is infamous around these parts
How about 17x7.5? 43offset?
  #1546 (permalink)
Old 08-02-2009, 07:14 PM
Black01's Avatar
Black01 relies on Rep Points to liveBlack01 relies on Rep Points to liveBlack01 relies on Rep Points to liveBlack01 relies on Rep Points to liveBlack01 relies on Rep Points to liveBlack01 relies on Rep Points to liveBlack01 relies on Rep Points to liveBlack01 relies on Rep Points to liveBlack01 relies on Rep Points to liveBlack01 relies on Rep Points to liveBlack01 relies on Rep Points to live
Quote:
I was going through these questions before. The offset that works is +45. 17x7 and 205/40R17 should do the work.
__________________
MR Fit
K&N Drop in Air Filter
Windows tinted
OEM All season floor mats
Cargo Tray
2008 Honda Fit Full Specifications
  #1547 (permalink)
Old 08-02-2009, 08:17 PM
mahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to live
its not the wheel that rubs first but the tire.
If you go with 205/40x17 or bigger you'll be pretty sure to get rubbing. If you go with 195/40x17 you may get away without it but why use 7.5" wide wheels? Just cost more for no benefit.
  #1548 (permalink)
Old 08-03-2009, 01:31 AM
Well the reason I am going with 17x7.5 with a 43 offset is because the wheels I am trying to buy are used and this is my only choice. But the wheels are worth every penny if they can fit.
They are going on a GE
  #1549 (permalink)
Old 08-03-2009, 03:43 AM
Benggolf's Avatar
Benggolf relies on Rep Points to liveBenggolf relies on Rep Points to liveBenggolf relies on Rep Points to liveBenggolf relies on Rep Points to liveBenggolf relies on Rep Points to liveBenggolf relies on Rep Points to liveBenggolf relies on Rep Points to liveBenggolf relies on Rep Points to liveBenggolf relies on Rep Points to liveBenggolf relies on Rep Points to liveBenggolf relies on Rep Points to live
You can use up to a 205/45 x 17 tire with those wheels. Install front camber bolts and run a slight negative camber (-1 degree or less) and you will have no tire-to-fender rubbing issues. BTW, my car is lowered with DF-210s.
Check out my ride.
__________________
Benggolf
2009 SSM FiT Sports Aut.
For more details on mods done: http://www.yarisworld.com/forums/fun...o=view&id=1015
  #1550 (permalink)
Old 08-25-2009, 01:56 AM
jimbrowski00 is an unknown quantity at this point
Hey guys... trying to find some info on what fits the fit!
Anybody have any advice on a successful "flush" setup with these cars?
I'm looking at Advan RGII's in the 16X8 +38ET. If I use the stock tire, would rolling be necessary? What kind of camber adjustment is necessary if any?
Thanks,
Jim
  #1551 (permalink)
Old 08-25-2009, 03:52 AM
Fit4Trav's Avatar
^^What model do you have GE or GD
__________________
FROM SEMA:
  #1552 (permalink)
Old 08-25-2009, 12:44 PM
I dont have one yet... It's going to be a GE though (2009 -2010)
  #1553 (permalink)
Old 08-25-2009, 12:47 PM
awptickes's Avatar
I have some 15x6.5 et 42 konig heliums, and they're pretty flush, much more so than the base steelies were.
  #1554 (permalink)
Old 08-25-2009, 07:24 PM
Quote:
The helium looks like a CE28 right? What size tires are you running? I'm looking to fit something with a concave face or a decent lip this usually means more width and lower offset.
  #1555 (permalink)
Old 08-25-2009, 08:03 PM
awptickes's Avatar
Yeah, there's no lip on the wheels I have. 195/55 on the 15x6.5. I don't really like lips on wheels, I prefer the flush look.
You could get a nice lip with some 40-ish offset 7-8" wide wheels.
  #1556 (permalink)
Old 09-02-2009, 12:07 PM
awptickes's Avatar
Has anyone fit 225/50 r15 tires on a fit yet?
  #1557 (permalink)
Old 09-02-2009, 01:08 PM
Platinum Honda FIT Vendor
jim@tirerack is on a distinguished road
The biggest we recommend is a 215/50R15. I would think you are going to need fender mods to make the 225/50R15 fit.
__________________
Jim@tirerack.com
800-428-8355 ext 364
Performance Specialist
  #1558 (permalink)
Old 09-02-2009, 01:42 PM
stalonehong relies on Rep Points to livestalonehong relies on Rep Points to livestalonehong relies on Rep Points to livestalonehong relies on Rep Points to livestalonehong relies on Rep Points to livestalonehong relies on Rep Points to livestalonehong relies on Rep Points to livestalonehong relies on Rep Points to livestalonehong relies on Rep Points to livestalonehong relies on Rep Points to livestalonehong relies on Rep Points to live
Send a message via AIM to stalonehong
hello
i need some help toooo. i have my ge8 lowered on eibach sportlines and i need to find out what rim size, tire size, and offset to use so that i dont rub. also i would like to fix the toe for the rear wheels. i probably will go for the volks ce28.
any help would be appreciated.
thanks guys.
__________________
2009 Crystal Black Pearl Honda Fit Sport w/ Navi
-35% Front Tints, 5% Rear Tints
-Clifford 50.7X Alarm w/ Remote Start
-JDM Non-LED Tails
-DIY Vertical Rear Wiper
-JDP CF Lip
-DIY Accord Horn
-Eibach Sportlines
-J's Racing Rear Pillar Bar
-Greddy SE Exhaust
  #1559 (permalink)
Old 09-02-2009, 02:23 PM
awptickes's Avatar
Cool, thanks. I'm trying to get a jump on tires for next autocross season by figuring out what fits right now.
  #1560 (permalink)
Old 09-02-2009, 02:32 PM
stalonehong,
What car are you working on?
__________________
Jim@tirerack.com
Reply
Tags
1954017, 40, fit, hfp, hieght, honda, hpo, low, mg, offset, rims, ss7, stock, voxx, weigh, wheel, xtatik
« Help!! | Question.. »
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Window Louvers, visors, photos, questions, installation, answers j_gusani80@hotmail.com Fit Exterior Modifications & JDM Styling 200 11-05-2009 07:55 PM
How to clean the interior? With questions, answers and suggestions sLiVeRwOrM Fit Care 98 09-07-2009 11:19 PM
Floor Mats, questions, answers, recomendations stacey14 Fit Interior Modifications 213 10-28-2008 03:52 PM
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
