Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > Fit Trix > Fit Shoes
Fit Shoes
Discuss Wheels & Tires for the Fit and Jazz
Forum Sponsor: Tire Rack
Welcome to Fit Freak!
Welcome to Fit Freak,
View Poll Results: Which Wheels would you buy
Voxx MG 27 39.71%
MB Drifter 41 60.29%
Voters: 68. You may not vote on this poll
Reply
  #1 (permalink)
Old 07-01-2005, 08:22 AM
jgrage is on a distinguished road
RUBBING, OFFSET, QUESTIONS Answers
I would like to put some alloy wheels on my jazz its an o4 it came with 14 inch steel wheels with 175 65 tyers on.
dose any one know what the sizes and widths of wheels i can fit to it with out them rubbing on the arches or the insides
Sponsored Links
  #2 (permalink)
Old 07-02-2005, 01:35 PM
MYx's Avatar
MYx MYx is offline
MYx is on a distinguished road
hi jgrage,
I'm using 17" wheels, +43 offset, 7 wide and 215/40/17 tires... sad to say there's occasional rubbing at the back end. Maybe because I'm also using H&R springs with 1/5" drop. I've tried almost everything to get rid of the rubbing but alas, I have yet to find a real solution short of changing to skinnier tires.
Ken is using 195/55/15s on 40 offset 6.5 inch wide 15" rims, and he too is experiencing some rubbing. But it really just happens when you load the car with 3 or more people and if you approach a dip on the road with the passengers aboard.
I suppose in London you guys have flatter/smoother roads unlike us here in Manila, so that rubbing problem might not be as bad there.
  #3 (permalink)
Old 07-03-2005, 05:44 PM
Dojo is on a distinguished road
Jgrage,
You have a lot of choices at it all depends on how big you want to go and how much you want spend! Like MYx said you can go with 15", 16" or 17" wheels you just have to watch the offsets and the tire width to ensure you don't have rubbing on the rear wheel well.
7 x 15" +34 offset wheels with 190/50R15 tires should not rub
7.5J/16" +35 offset wheels with 195/45R16 tires should also fit without rubbing, depending on offset you may be able to use a 205/45R16 tire.
7.5J/17" +35 offset wheels with 205/40R17 tires should fit without rubbing if you want the big wheel look. I have seen a few fits with 18's but I don't know about rubbing issues with thoses sizes.
I hope this helps you guys out. MYx I think if you go to a 205/40R17 tire it should stop your rubbing even with 3 people in the back.
D
  #4 (permalink)
Old 07-03-2005, 10:08 PM
MYx's Avatar
MYx MYx is offline
Dojo,
FOr sure rubbing would be eliminated with the 205/40s... but with the terrible road conditions here in the Philippines, it wouldn't be practical. Heck, having 17s by itself wouldn't be practical here
But for sure there in the States or the UK, it wouldn't be too much of a hassle.
Here in the Philippines, we recommend 16" wheels to those who want to plus size. In our road conditions, this is the best compromise between practicality and form, espcially when we drop the car down.
  #5 (permalink)
Old 07-04-2005, 06:58 AM
sr20jet's Avatar
sr20jet is on a distinguished road
What's the offset of the Fit "Stock" alloy wheels in both 1.3(14") and 1.5(15") models? I'm assuming it's like their big brother Civic which is 45mm. I could be wrong.
__________________
JET-OUT
A Hopeful Future US F.I.T. Owner
My Daily Driver (Pic Update 10/31/05)
  #6 (permalink)
Old 07-04-2005, 07:09 AM
sr20jet's Avatar
With your current setup, you have an overall tire/wheel diameter of 22.96 inches. Width of a wheel if doing a upgrade over 14's is all depended on the offset. I always use this rule of thumb when going to a bigger wheel size, for every .5" width upgrade from stock wheel dimensions, take (-)2 or (-) 3 mm for offset. As for tires in upgrade size, stay within plus/minus .2 inches of your overall stock tire/wheel diameter.
__________________
JET-OUT
  #7 (permalink)
Old 07-04-2005, 07:11 AM
sr20jet's Avatar
Once I know what the stock offsets, wheel sizes and tire sizes coming from the factory(all models), I'll put up some recommend wheel and tire sizes suitable for use.
__________________
JET-OUT
  #8 (permalink)
Old 07-04-2005, 12:36 PM
hi all your replys have been very use full but i am a little confused by "offset" could you explain sorry
  #9 (permalink)
Old 07-04-2005, 12:43 PM
Mojo's Avatar
Mojo is on a distinguished road
jgrage,
Try this page. It has an excellent explanation on offset
http://www.tirerack.com/wheels/tech/...jsp?techid=101
The offset of a wheel is the distance from its hub mounting surface to the centerline of the wheel. The offset can be one of three types.
Zero Offset
The hub mounting surface is even with the centerline of the wheel.
Positive
The hub mounting surface is toward the front or wheel side of the wheel. Positive offset wheels are generally found on front wheel drive cars and newer rear drive cars.
Negative
The hub mounting surface is toward the back or brake side of the wheels centerline. "Deep dish" wheels are typically a negative offset.
If the offset of the wheel is not correct for the car, the handling can be adversely affected. When the width of the wheel changes, the offset also changes numerically. If the offset were to stay the same while you added width, the additional width would be split evenly between the inside and outside. For most cars, this won't work correctly. We have test fitted thousands of different vehicles for proper fitment. Our extensive database allows our sales staff to offer you the perfect fit for your vehicle.
__________________
Mojo Rising
  #10 (permalink)
Old 07-04-2005, 12:50 PM
tanks mojo that dose help
  #11 (permalink)
Old 07-04-2005, 04:51 PM
ken1279 is on a distinguished road
Do you have wheel design in mind?
  #12 (permalink)
Old 07-04-2005, 04:52 PM
no not really. not closed so you can see the caliper
  #13 (permalink)
Old 07-04-2005, 05:04 PM
sr20jet's Avatar
Anyone have the specs(width & offset) of all the Fit/Jazz wheels from the factory?
14" Steelies, 14" Alloys and 15" Alloys
__________________
JET-OUT
  #14 (permalink)
Old 07-04-2005, 05:12 PM
Check this out. I'm thinking of getting either of the two:
http://www.worksuperwheels.com/wheels/emotion_cr.html
http://www.buddyclub.us/buddyclub/p1r2/p1r2.html
  #15 (permalink)
Old 07-04-2005, 05:38 PM
sr20jet's Avatar
The P1 Racing II doesn't come in 4x100.
__________________
JET-OUT
  #16 (permalink)
Old 07-04-2005, 05:42 PM
sr20jet's Avatar
I'm diggin the Work Wheel Nezart Spoke 2 as shown on this Veni FIT.
__________________
JET-OUT
  #17 (permalink)
Old 07-04-2005, 05:49 PM
Quote:
Opps wrong link.
http://www.buddyclub.us/buddyclub/p1r/p1r_f.html
P1 Racing II Plus
  #18 (permalink)
Old 07-04-2005, 07:32 PM
hondafit's Avatar
hondafit is on a distinguished road
whoa..nice Veni Kit..
hmm..mugen grill with a typeR Badge..creativity..
  #19 (permalink)
Old 07-04-2005, 08:57 PM
Mojo's Avatar
I have a weakness for polished lips
__________________
Mojo Rising
  #20 (permalink)
Old 07-04-2005, 10:13 PM
Quote:
Hehehe... Me too!
Reply
Tags
1954017, 40, fit, hfp, hieght, honda, hpo, low, mg, offset, rims, ss7, stock, voxx, weigh, wheel, xtatik
« Help!! | Question.. »
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Window Louvers, visors, photos, questions, installation, answers j_gusani80@hotmail.com Fit Exterior Modifications & JDM Styling 200 11-05-2009 07:55 PM
How to clean the interior? With questions, answers and suggestions sLiVeRwOrM Fit Care 98 09-07-2009 11:19 PM
Floor Mats, questions, answers, recomendations stacey14 Fit Interior Modifications 213 10-28-2008 03:52 PM
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
