Discuss Wheels & Tires for the Fit and Jazz
Forum Sponsor: Tire Rack
Welcome to Fit Freak!
Welcome to Fit Freak,
I see there 15X7 up front. How flush are the wheels with the fender, what did you do to get them to fit. I'm curious because I have a set of BBS RS that I'm thinking of going with a 1.5" Lip making the wheel a 15X7.5 and I want to know as much info as I can before I get into it.
wheels slightly out the fender by a few mm. for the 7.5 a low 30+ is manageable, depending on how you want to do it really. how to fit it isnt much of a problem, rolling fender, fender line tuck and all that. 15x7.5 is rare combo, but i heard bbs wheels can modified their offset anytime.
__________________
s i m p l e | e - w o r x | s u r a b a y a
Yep I can take the BBS's apart and add a bigger lip witch basically changes the offset. right now the wheels are +38mm and if I go to a 7.5 wide wheel I think it changes the offset to +25mm. I real want to run the biggest lip as possible and its starting to look like its going to be a lot more work then I originally thought it would be.
need to dump it so hard on the Equips. awesome wheels
STTich: it is Awesome. that wheels used to be mine. Peejay both it from me and i replace it with Work equip01. whats your offset on you 01?mine is 15 x 7 +38. now my equip 01 is 15 x 7.5 +39
@Fit4Trav: The 01 that i have is a deep rim design. not the standard so the problem is the spokes is hitting the caliper so im running a 3/8" spacer on it. so ill be installing a longer stud bolts and will be putting a 1/2" spacer. so ill update the pictures.
Im not a baller like you guys w/ your work wheels!! LOL I did have some pearl green equip 03 copies but they had to go, my car is a DD so Im happy w/ my civic HX wheels
