Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > Fit Trix > Fit Shoes
Fit Shoes
Discuss Wheels & Tires for the Fit and Jazz
Forum Sponsor: Tire Rack
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #1 (permalink)
Old 09-10-2008, 11:28 PM
geepondy will become famous soon enough
185/65/14 instead of 175/65/14 for snows?
Ok, I did ask this in the general forum last summer at the time of 08 Fit purchase but with winter coming sooner rather then later, I want to make really sure of this before it gets time to put the snows on.
As you know 08 Base fit has tire size 175/65/14. I have some still good 185/65/14 snows (Michelin X-ICE) from a previous vehicle. Other then changing the accuracy of the odometer and speedometer by a few percentage points, is it perfectly safe to use these tires, meaning no wheel wall rubbing or other improper size issues?
Sponsored Links
  #2 (permalink)
Old 09-11-2008, 10:34 AM
mahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to livemahout relies on Rep Points to live
The 185/65x14 tires will be fine UNLESS YOU CHANGE WHEELS from stock specs to a more radical specification on offset and rim width. They re almost the same diameter as the 195/55x15 tires (23.46 vs 23.44) standard on the Sport. If your speedo and odo were calibrated for 175/65x14 tires (22.92") then you could have a small error of 2% fast (read 60 at actual 61 mph) but I kind of doubt Honda did that. Probalty calibrated for 195/55x15 tire.
Nothing wrong with X-ices either.
Reply
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
